Turbo Inka 4 Door: Stripped & street legal rotisserie build + Powdercoating Pr0n
  • eurolife
    • Jan 2013
    • 128
    #31
    From what I've read. The m54b30 crank is the very same (part number and all) as the s52 crank.
    • econti
      • May 2014
      • 1100
      #32
      That's really awesome.
      I love how BMW made everything so easy to chop and change and have basically every combo you can think of.
      • eduTechnic
        • Dec 2012
        • 400
        #33
        Yep that's true
        Yeah it's pretty sweet. A few friends are even blown away at the simple recipe for an m50 swap.
        Turbo M50 4 Door Build thread here 4 Sale thread
        • eduTechnic
          • Dec 2012
          • 400
          #34
          What a weekend. My bro-in-law and I headed to the SLC pick 'n pull to see what we could see. I didn't get the M50 swap parts out of the 95 525i I needed but I did get this lump.
          Rear sumps can suck it. We tried to jimmy that thang (thang = engine/trans/shifter) outta thurr with the front subframe attached. No go. So to the rescue came the IR cordless impact. Zzz zzz and loosen the steering linkage the whole subframe assembly crunched into the gravel below. Done.
          Biggest problem was after I paid for it and carted the engine/trans/intake/harness to my van and got my HF hoist out the hoist wouldn't jack up like it needed to be bled. At this point we'd been working in 95 degree weather for a few hours and were dying. After some cuss words we split the engine & trans, took off the harness/intake and heave hoe'd that sucker into my van. I'm pretty sure I popped some gaskets in my legs and back and bruised the crap out of my arms in the process. My bro-in-law is a good soul for enduring that crap.
          Got the engine home, slid it down some plywood onto a tire, vacuumed the leaves off it.
          Voila, M50B25NV out of a 92 e36.
          Other build notes:
          Ordered the following:
          F&R 5 lug hub adapter with e36/e46 M3 caliper brackets but no BMW parts, just the adapters
          Need:
          e36/46 calipers (minimum wheel size for each???)
          pads
          caliper rebuild kits
          do my SS lines for stock e30 brakes work?
          rotors (Brembo blanks)
          Euro grills from St!g in Iderho
          Used from a R3v member:
          M50 swap mounts from Condor
          G260 transmission cross brace (not sure if using G250 or G260)
          iX Brake booster
          10 deg twist UUC DSSR for G260 w/ M5X
          To do:
          Break down M50 and inspect
          Leak-test head
          Build blast cabinet (sheet metal, plexi, rubber cow-butt-hole-invasion gloves)
          build powder coat oven
          Plan out garage booth setup to be able to take down/put up easily for garage door opening
          bleed the #@$!@#$ing hoist
          get another engine stand if the m50 checks out
          Make a huge FS ad with all my m20 turbo thangs [read: HMU if you need m20 tarboh parts]
          • eduTechnic
            • Dec 2012
            • 400
            #35
            Did some work today.
            After trying to heat the bolt (MAPP), 10' pole on a wrench, 1/2" impact, 3/4" impact, my brother-in-law decided to combine forces and stacked the pole on the wrench with the 3/4" impact on the end and we finally got it loose. What a lil B.
            Looks like the HG went on cyl # 6.
            Cams look really good. Cyl walls look great besides some rust around the upper section on #6.
            Got my e34 pan/pickup/dipschtick stuff from a pick 'n pull e34 as well. It was disgusting, filthy little whore of a car.
            Sidenote, these are beautiful:
            • eduTechnic
              • Dec 2012
              • 400
              #36
              Did some work and got the M50 all broken down. I've just been cleaning and organizing since I could barely walk into my shop still having boxes and parts everywhere. I threw some old e30 stuff away, and generally made room for the m50 disassembly.
              M50 side of the shop:
              Looking at bearings everywhere things look great except for a main bearing next to cyl #1. At first I thought there was a groove worn in the bearing but it was just discoloration and had no edge to it. Crankshaft didn't have any wear that my fingernail could catch on either.
              As far as cylinder walls go, the hi-wear areas at the top and bottom were noticeably different diameters from the non-wear areas at the very top and bottom. If I decide to use the m54b30 crank I'll def be making a trip to the machine shop with a slight overbore. I took a video of the cross-hatching with my phone flash on and it really exaggerated any lines with the harsh light on them. I'll link that up later (for you Chris).
              All I gotta say is I'm glad to have this thing cracked apart, coolant and oil cleaned off the floor so my kids don't lick it, and the fact that I dont' have to pick up the block any more to get it in the stand...forgot to remove the rear main seal pieces when I got the block up for piston/rod removal...my old back...
              My wife is taking the kids to my parents for like 5 days before the long weekend and I'm a little stoked and a little sad to have them go. I'm conflicted. I really need to get my oven built and a make-shift blasting area setup outside the garage and start cleaning some things.
              Next up:
              • Head water leak down test
              • Disassemble head and check all the valves out
              • Lear about engine rebuilds from YouTube for as much misinformation as possible and read all the comment fights to come to a decision, then ask my BIL wuts wut.
                Get a notebook and check all the bottom-end parts
                Ring-gap measurements
              • Check cyl #6 components for bends (coolant in this cyl)
              • Get the sheet metal & insulation (fiberglass board/rock wool?)necessary for the oven build
              I also got the car on its side.
              The rotisserie bumper bar mount thing is just long enough to bump the rotisserie end but I threw my breaker bar down there for a little insurance
              Got started with the wire wheel
              I may try some dry ice and a rubber mallet for the undercoating...this isn't fun. It all turns into silly string as you go.
              • eduTechnic
                • Dec 2012
                • 400
                #37
                Leak tested the head tonight by sticking some playdough in the spark plug wells (I thew away the plugs, it's all I had okay!) and letting water sit on top of the valves. I still plan on runnign water straight into the ports with the head on its side, I just ran out of time last night.
                Setup:
                Leak down results so far: Looks like I'd expect after 100k+ with oil vapor recirc.
                Blue = water leaks.
                I checked out each rod and letting them sit on a flat counter and eye balling them none look bent. I spent extra time with #6 since it had the coolant in it at some point.
                Main bearings:
                #1 Main bearing weirdness: Anyone know what would cause such wear? It def caught on my fingernail. The matching crank bearing journal looked fine and didn't have any wear I could feel at all.
                I need to make a call about pistons/rods to go with a 3.0l crank anyway I suppose but it's nice to know I've got a backup.
                I pulled a G250 from the pick 'n pull with this motor but a 99 328is manual just showed up so I might have to exchange this trans and go get the ZF320 and DS from that 328
                • eduTechnic
                  • Dec 2012
                  • 400
                  #38
                  Small update.
                  I got the car on it's side after connecting the rotisserie base with some chain and a tie down connected to some small hooks & carabiners. Works great.
                  Also got started on the powder coating oven a bit. I removed this fridge from an elderly lady's home after posting an ad on local news/classified site free of charge. I was looking for a single-door, sheet metal fridge that would fit the rear subframe, since that is the biggest item I'll be powder coating.
                  The fridge was a total B to get out of the house. I had this HF dolly with big ol tires on it and the fridge was on the 3rd floor with access by way of a rickety wooden stair case external to the house. It was absolutely awful to get down the stairs after having to remove it from the dolly and turn it 4x.
                  Anyway, the compressor sat on the back of the fridge and needed the shape cut out of the outter skin and the inner tub all the aesthetic fridge plastic mounted too.
                  Got out some tools.
                  Between the sawzall, cut-off wheel, and the above I managed to get the lower portion removed from the outer and the angled piece of what will be the inside of the oven bent out a bit.
                  The floor was rusted out as well so that all came out with the compressor indentation.
                  My wife said there's no way in all of heck this lovely little monster is going to be out for our family get together this weekend, so away it goes...
                  Having the car on it's side really opens up the garage as well wow...
                  [/url]
                  Next will be re-boxing in the outer and inner compartments and putting the 2" of fiberglass/rock wool insulation in. Then it's time to transfer all the guts from the kitchen oven over and do that part of this flawless oven build.
                  • eduTechnic
                    • Dec 2012
                    • 400
                    #39
                    Been a long time since I've updated anything. Haven't worked on the car as much though.
                    Started in on the powder oven.
                    Tore the oven apart and found some useful sheetmetal to use to patch the back of the fridge.
                    Zipped the rust off this lovely piece
                    Tacked it onto the base of the oven
                    Now to patch the back where the compressor resided
                    Picked up a cheap HF rivet gun. Kind slick
                    Outer tub complete
                    On to the inner tub of the fridge. This piece needs patching for the compressor cutout as well. The insulated oven window will also be going in the door or the side. My wife said I can't put it high in the door because the pretty diamond shapes will get ruined. Can't argue with that.
                    Picked up some cheap, 2"-thick, $10/roll fiberglass insulation
                    Rock wool didn't seem worth the price
                    Then I scrapped the whole plan since I found a bigger fridge out on the curb with a sign that said "FREE." Problematic since it's got french doors. I'll tear it down and see if it's usable. The plan would then be to build out from the fridge sheet metal with some square tubing, add insulation, and rivet/screw some sheet metal to the outside, then add the heating elements. I'm glad I found this thing, the rear subframe was a tight fit in the single-door fridge.
                    I also went down to help out my brother in law on his '78 Datsun. He bought my 17x9/10 wheels so he's working on the rear quarters in glass
                    We laid up the other side after this using flourescent fixture difuser plastic. He's not too worried about the inside of the flares, and that's pretty practical. Pretty cool to see his process and learn some wet glass layup. Still haven't decided if I'm going sheet metal flares or buy some stuff from the Pesch Poles.
                    • Q10
                      • Jan 2013
                      • 25
                      #40
                      Ive enjoyed reading thus far. Keep the updates coming!
                      • Luis325
                        • 3847
                        #41
                        Nice man! Cant wait to see more!
                        1986 "C2 2.7 Alpina" Sedan
                        1987 325ic Black Vert
                        • TimeMachinE30
                          • Jun 2014
                          • 3749
                          #42
                          Caliper rebuild kit still for sale? Brand, details?
                          Thanks. Great build thread. Nice powdercoating oven!
                          ACS S3 Build / Dinan 5 E34
                          • eduTechnic
                            • Dec 2012
                            • 400
                            #43
                            Thanks! I'll have a giant ad up this week. I may just rebuild the calipers and sell them refurbed.
                            • eduTechnic
                              • Dec 2012
                              • 400
                              #44
                              Thanks for reading!
                              Been tearing down this fridge someone abondoned a few houses down. It's a classy neighborhood what can I say
                              The french doors aren't ideal but whatevs
                              Smooth foam surface under the inner plastic. I held the heat gun on high at like 1150 deg F and it didn't even budge or discolor
                              Outer "tub" all done
                              I couldn't be bothered to get nice fiberglass so I got the $10/40'x3 1/2" rolls and sprayed the paper backing with this stuff. I've used it on cardboard right next to the stick welder for up to a minute with no flames; fire retardedly cool
                              I made some ghetto double-sided aluminum tape to get it to stick in there long enough to shove the inner tub (need to buy the square tubing and sheet metal still). and sprayed between it with the fabric fire repellent. This fiberglass is so cheap, I'll have to insulate the garage this winter and make it less of a wintry hell to turn wrenches.
                              Tonight I got the outer tub (read: the fridge) all fluffy and pink. Who wants to curl up in this little heat haven?
                              This mess from tear down alone is getting out of control. Going to be a midnight raid on the neighbor's garbage cans before trash day
                              The door plastics were lightly glued but were a female dog to get out and splintered all over the place. The water & ice dispenseres were encased in carbonite and took forever to chip out & rip out. The door on the left is upside down but I plan on enlarging the hole and putting in inslated oven window in there.
                              The condenser fan will work well to try to get some air moving in this thing
                              Off topic but exciting. I share a lot of tools with my bro-in-law and he picked this up for a steal. Going to power it with my stick welder. It's got push button start and a gas shutoff timer so as soon as I get a bottle I'll break out the '85 shell and get practicing on BMdub sheet metal.
                              • eduTechnic
                                • Dec 2012
                                • 400
                                #45
                                Got something in the mail today. I've got to stop making fantasy carts at VAC & Bimmerworld. Making me weak.
                                That is all.
