M20 B3x Naturally Aspirated Stroker build past, present and future
  • fporro
    • 1859
    #166
    So much refinement Digger, I'm digging it ;)
    • digger
      • Nov 2005
      • 5945
      #167
      I designed this vacuum rail to mainly use Closed Loop Idle Control which is important for cold start (mine never starts properly without it, now it starts better than OEM) and fast warmup, the intention was to make things neat and tidy compared to the monstrosity i have been using. Its 20 x 20 x 1.5 mm hollow aluminium tube with a cap at each end. has tapped bosses with M6 threaded 6mm nipple for each runner and another for the FPR which has a t-piece for using a vacuum gauge or running to the ECU internal map sensor (currently T-piece is capped off as im using ALPHA-N). its basically a similar design to the fuel rail
      made the parts and had a guy i know with a TIG weld the bits together
      some pics of it fitted. it cleans up the bay alot. there is a fitting on the bottom of the airbox that fits into the open hose. i convrted to the L-shaped ICV in the process.
      hoses for runner 1 and 2 feed between runner 1 and 2 to avoid fouling with linkage, similar for 3-4 and 5-6
      here is what i replaced (used to sit under where the rail is now, note that the actual hoses i used with the old system were about 12" longer than shown as they need to be the same length, i cut the old ones and reused them. there were hoses all over the place but now the hoses are only 8" long vs 24" previously and its all tucked away
      seems successful, idle is the same so no adjustments required which is good
      • digger
        • Nov 2005
        • 5945
        #168
        next task is relocating the catch can to under the airbox (currently its just infront of washer reservoir) and routing the valve cover breather to the new location. i need the old spot for something else.... ;)
        • LJ851
          • 7918
          #169
          Nice work digger, glad to see some progress.
          Has the new engine been dyno tuned yet ?!
          Lorin
          The M30 is God's engine.
          • digger
            • Nov 2005
            • 5945
            #170
            i have to build it first ha, ive been busy and out of the country for a few months.......
            • digger
              • Nov 2005
              • 5945
              #171
              Anyone ever fitted an electric vacuum pump to supplement boost vacuum for the booster on a cammed m20 or similar? I’m only getting 8-10” at hot idle and much less when cold with fast idle. It’s been this way for years but it’s the reason I’m not happy with the stock brakes as the amount of assist I’m getting is marginal. When I build the engine this is likely to get worse with a little more overlap.
              Hella make some good pumps that are compact, quiet as they are for OEM and electric vehicles but they don’t come with the relays and vacuum switch etc so implementation is a little more involved electrically
              The UP28 is to supplement vacuum and UP30 can work as a standalone system. The UP28 is found on Audi’s etc so is OEM quality and can be had for cheap used.
              • ForcedFirebird
                • Feb 2007
                • 8300
                #172
                Where are you drawing vacuum? I have been running them behind the throttle plate on the ITB builds and haven't had any issues with assist (cams smaller than yours, I'm sure, though). With a vacuum gauge on a single runner and a 272 cam, it was pulsing from 7-11" or so.
                john@m20guru.com
                Links:
                • digger
                  • Nov 2005
                  • 5945
                  #173
                  i'm getting 8-10" at hot idle feeding off 3 runners which feels borderline, it still works ok for the main part but its worse than it was with OEM manifold especially when cold where its 4" or even less with ICV working alot.
                  at low speed when ive applied the brakes a few times but not had enough revs to draw vacuum back down sometime the pedal feels noticeably harder quite often so you really feel it at low speeds.
                  when you lift off at speed the vacuum is higher and it feels normal when you start to brake. new cam will have much more overlap so its more about looking to the future than anything.
                  • 2mAn
                    Señior Mod
                    • 20178
                    #174
                    Originally posted by digger
                    EXHAUST
                    Did some exhaust mods a few years back, everything I did went backwards and by a lot….lol
                    Run 1 to run 2 was a catalytic converter change out where the new cats were moved closer and side by side as opposed to staggered
                    Run1
                    Run 2
                    Further investigation into this never found out what happened. I even put back a similar set of cats and used photos to position them as close to where they were but it didn’t do squat. Perhaps it was something to do with the dyno setup on Run1 and as such it is not real or there was another issue at play…..
                    Run 2 to run 3 was a x-pipe relocated closer to the engine...Exhaust from run 3 notice the x-pipe is closer to the engine
                    .... the real problem is the relocation of the x-pipe
                    I want to redo the exhaust before the new build so will be doling that over coming month or two though not 100% sure on what to do yet
                    Sorry for digging this back up, but I wanted to ask your input on what I gathered from your experiments...
                    It seems like the staggered cats being equal-length from the exhaust manifold/ headers was the optimal setup and having a "x" pipe further back was the best way to go.
                    Any thoughts as to having a "Y" pipe instead of the "X" and keeping it ~3" from there back?
                    Simon
                    Current Cars:
                    -1966 Lotus Elan
                    -1986 German Car
                    -2006 Volkswagen Jetta TDI
                    Make R3V Great Again -2020
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      #175
                      Put the x-pipe near the drive shaft CSB.
                      Digger, because of 2mAn's post I read back and realized something. MM's intake with those "pulse tuned" manifolds are interesting. They would increase the runner volume without increasing length. Makes me wonder what kind of testing was involved to come to the conclusion of a "tuned" length with a various diameters.
                      john@m20guru.com
                      Links:
                      • digger
                        • Nov 2005
                        • 5945
                        #176
                        probably the Y and X behave much the same especially if the cross sectional area of the single pipe matched the dual pipe, i was very close to changing to a Y and single 3" and feel it be very similar. main reason i didnt was because i did want to get another muffler and with cats two cats flow better than 1 (not an issue if you get high flow cats tho)
                        • digger
                          • Nov 2005
                          • 5945
                          #177
                          given when i went to the RHD manifold i got the same sort of gains as others with stock manifold id say its much of a muchness over OEM, they did claim 20% more midrange torque. When i did some testing of it i had change to a different cam and a bunch of other stuff and there was noticeably more midrange but the contribution from the manifold alone could not be differentiated
                          • SNEAK413
                            • 33
                            #178
                            Digger,what piston dome shape are you using with your head? I'm doing your build with an 885 head and I just got my Pistons from JE and they are pretty much flat.
                            • digger
                              • Nov 2005
                              • 5945
                              #179
                              I’ll be using OEM shape to match the 885, if you want these Steve from topend can get JE made to this style or Andrew at IE can do them to now by Mahle and maybe Ross.
                              • SNEAK413
                                • 33
                                #180
                                What did they do to the 885 on this part marked by the smiley face? I can't tell if they completely removed it or just polished it.
