Kadunza S54 ITB Adapter Plate Project
  • blackm50
    • Jul 2015
    • 16
    #91
    subscribed for updates , got a set of s54 itbs sitting in the garage.
    • RobertK
      Kicked cancer's ASS.
      • Jun 2005
      • 5864
      #92
      Still slowly waiting for my fab guy to finalize a throttle linkage assembly. Will post updates as they come.
      • ForcedFirebird
        • Feb 2007
        • 8300
        #93
        Originally posted by Jalves619
        For someone running a standalone, will the vacuum "log" provide an adequate map signal? I wouldn't want to run alpha N because I intend to run FI as well.
        I have not had any luck tuning ITB's in Speed Density. It CAN work, but the resolutions sucks as you will be reading about 80kpa at idle. I have read where people use a large vacuum manifold and buffers to slow/mix the pulses. I put a vacuum gauge on a vacuum block and the needle bounced erratically and was only pulling about 8" on average with a huge swing between.
        We will be putting a turbo on an ITB m20 soon. I plan on using a hybrid alpha-N speed density (MAP), but will have to cross that bridge when we get to it. Hoping I can have the MAP signal in the plenum (pre-throttles)
        john@m20guru.com
        Links:
        • digger
          • Nov 2005
          • 6181
          #94
          i've heard that some ECUs can sample at a defined crank angle and therefor you can sample at 1 runner only when the piston velocity is high and get a really good signal
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            #95
            cant wait for this. plan for mt2 car is s52 itb
            1991 318i 4dr slick top
            Mtech 2 turbo restoration
            • Bimmer_man
              • Jan 2013
              • 1477
              #96
              I hope your fab guy gets these done this is such an amazing idea.
              Float like a cadillac sting like a Bimmer!:)
              • E30 Wagen
                • Jul 2005
                • 3434
                #97
                Originally posted by digger
                m50 runners 1&4 drawing (flow is 3.2L 100% VE 8000rpm) 11% variance
                angled entry runners 1&4 drawing (flow is 3.2L 100% VE 8000rpm)
                2.5% variance
                no questions that the angled entry provides better distribution. with the OEM runners 3 & 4 see more flow than its neighbours due to the poor design. air just dumps into the volume and the velocity of the air means it has difficulty turning corners.
                most people flow test individual runners but that is useless for looking at distribution
                I've never seen these pictures before. Wow... I guess I've never considered there were would be such a flow imbalance on the stock manifold, and now I get the purpose of the angled manifold design. Learn something new everyday... I'm guessing the m20 design is actually better than the m50 at distributing air flow?
                My Feedback
                • digger
                  • Nov 2005
                  • 6181
                  #98
                  Not really, imo where the throttle body bolts on the two closest runners 3&4 are located poorly that air will have difficulty making the sharp bend . Also the shape of each runner is different with some having really tight bend.
                  • RobertK
                    • Jun 2005
                    • 5864
                    #99
                    I actually took the project from my original fab guy and it is now been given to Evolution Motorsport Fabrication to help finish the throttle linkage development.
                    • blackm50
                      • Jul 2015
                      • 16
                      #100
                      @Robertk so your adapter is finalized and just waiting on the linkage?
                      • RobertK
                        • Jun 2005
                        • 5864
                        #101
                        Yes. I got word this past week from my new fab shop that they are very close to having it sorted out.
                        • blackm50
                          • Jul 2015
                          • 16
                          #102
                          So how's the progress on this going? Any pictures??
                          • RobertK
                            • Jun 2005
                            • 5864
                            #103
                            New fab guy says he's pretty close to having a final solution. I should see him tomorrow so I will check progress.
                            • Kershaw
                              • 11822
                              #104
                              Very cool, in for updates.
                              AWD > RWD
                              • blackm50
                                • Jul 2015
                                • 16
                                #105
                                How's it coming along , any good news?
