Panici's '87 325is E30 - Restomod, M52 Swap, Standalone ECU, Custom Paint, Turbocharged
Comfortable - Classic - Sporty
Index:
15 posts/page
Page 1: Specifications, Purchase story. E39 m52b28 Removal, Getrag 260 Removal.
Page 2-3: Timing Belt, Brakes, Suspension.
Page 5-6: Manual Transmission Refresh and Swap, Lower Control Arms.
Page 8: Front End Cosmetics, Sunroof Repair.
Page 8-10: Rear Subframe Restoration.
Page 11-12: Two Evenings at the Racetrack!
Page 13-14: Houndstooth Repair, New Garage, Central Locking Fixed, Fuel/Evap System Refresh.
Page 14: E28 535is Pfeba Heckspoiler, 1987 325is Air Dam.
Page 15: Hidden Radio, Exhaust Repack, Rocker Arm Replacement, Camping, Tedfest 2018.
Page 16: 15" Euroweaves, Ride Height Adjustment, DIY Startec Replicas, Rear End Cosmetic Refresh.
Page 17: LED Bulbs, Hidden Stereo v2, E36 M52B28 Removal & Prep, Standalone MS3X ECU Wiring.
Page 17-19: M20B25 Removal and Bay Prep, More Rust Repair, M52 Installation & Tuning
Page 20-21: M50B25 Manifold Install, Tuning. Rear End Crashed, Rear End Rebuild
Page 22: Window Tinting, Hushmat, More LED Lighting, 2-Step Launch Control, Custom Wideband
Page 22-23: Rust Repair/Paint Prep. Front Subframe Restoration.
Page 24-25: M52B28 Engine Refresh, Bodywork & Paint.
Page 26-28: Engine Install, Reassembly After Paint, Turbo Install, Sound Deadening v2.
Page 29: Euro Grilles, Car Show, 2.93 LSD, Muffler.
Page 30-32: Rear Subframe + Trailing Arms Reinforcement & Upgrades. Swaybars, Exhaust & Shifter Mods.
Page 33-34: Full Reassembly, PPF, Ceramic Coating.
Page 35-36: COTM Beauty Shots, Startec (new-run) Taillights
Page 37: Jetfighter Compressor Housing (T51R Mod)
Modification & Restoration:
- Suspension, Wheels, Brakes, Steering
- H&R Sport Springs (w/ 1/4 inactive coil cut from front)
- Bilstein Sport Dampers (w/ cut front internal bumpstops)
- AKG Front Swaybar Reinforcement Plates
- E90 Drop Hats (10-15mm drop)
- 318i 3mm Front Spring Pads (6mm drop)
- 5mm Rear Spring Pads (top & bottom)
- Lemförder LCAs (both sides)
- Lemförder E30 M3 Offset Control Arm Bushings
- Stoptech Street Performance Pads
- Rear Subframe Restoration v2
- Weld-in reinforcements for Rear Sway Bar, Differential Mount Point, Rear Shocks, Trailing Arms
- Garagistic Secondary Diff Mount
- RaceGerman HD Differential Stud Kit
- Revshift 80A Polyurethane Differential, Subframe, Trailing Arm Bushings.
- Trailing arms replaced with a better (used) set
- Outer subframe ta mounts reinforced/welded
- Subframe beam, trailing arms, and rear differential: Stripped and coated with por15
- Replaced rear wheel bearings
- 2.93 LSD Differential side seals, o-rings, input shaft seal replaced.
- Fuel filler hose replaced
- Thinner spring pads (upper and lower)
- Painted (blue) set of rebuilt brake calipers
- Four ATE soft brakelines
- Subframe hard brakelines replaced with copper-nickel.
- Body-side hard brakeline replaced with copper-nickel. New brass "t" distribution piece.
- New E-brake cables
- Stainless shock mount reinforcement plates - made by r3v member "conway"
- Turner motorsport rear shock mounts (hp aluminum/rubber)
- 15x7 BBS "Euroweaves" [et-24] w/ Yokohama Advan Fleva V701 (205/55R15)
- 5mm front & 15mm rear hubcentric/wheelcentric spacers w/extended lugs
- Z3 steering rack (2.7 turns lock-to-lock)
- Chase Bays Brake Line Relocation kit
- Reinforced Chassis-side Rear Swaybar Mounts
- 19mm ST Suspensions Rear Swaybar
- 22mm ST Suspensions Front Swaybar
- HDT Automotive Upgraded Driveshaft w/1310 Spicer U-Joints
- Engine & Transmission
- SPAL Electric Radiator Fan (16" - 30100401)
- Fuel system refresh (gas tank, fuel lines, evap, etc)
- Motormaster Eliminator ultra sealed AGM battery
- Bavarian restoration performance power and ground cable kit.
- 1996 M52B28 Motor Swap
- Standalone ECU - Megasquirt MS3X
- Full Sequential Spark & Fuel, Knock Sensors, Dual MAP Sensors (Altitude Compensation)
- GM Open Element IAT/MAT Sensor
- Tuned Entirely By Myself!
- Two Dash Warning Lights (Check Engine & Park Brake) set to show Lean AFR Warn, Timing Pull due to Knock, High CLT
- SPAL Fan Control
- AFR Safety System
- 2-Step Launch Control
- Partially Shaved & Wire Tucked Engine Bay
- Custom made wiring harness
- Removable Core Support
- Racehead (RHD) 7.5lb Chrome-molly steel flywheel
- RHD E39 M5 23mm Clutch Slave Cylinder
- Relocated Relay Box
- Relocated Cruise Control
- Throttle body heater delete
- M42 Radiator
- E83 X3 Brake Booster w/ 2002 Reservoir
- Chase Bays Windshield Washer Res
- M50B25 Intake Manifold
- Engine Refresh, Turbocharger & Supporting Modifications
- Conversion to single Aeromotive 340 Stealth In-Tank Fuel Pump
- ARP Head studs
- SCE/ATHENA Vulcan "High Boost" Cut Ring Headgasket
- Rebuilt VANOS w/Anti-Rattle Kit
- Replaced timing chain guides, water pump.
- New Front & Rear Main Seals, Belt Tensioner, Exhaust Manifold Studs
- 176F/80C Thermostat w/Metal Thermostat Housing
- POR15 Engine Enamel Black
- Level Motorsport 24v Upgraded Engine Arm.
- Turbo Oil Drain bung welded to timing cover.
- DEI Reflect-A-Gold
- ZF320 Transmission - Refreshed seals, shift detents, etc.
- SPEC Stage 3+ Street/Track Clutch Kit
- Level Motorsports Twin Scroll Tubular Exhaust Manifold.
- Custom 3" Turboback Exhaust System.
- Precision 6062 Ball Bearing Gen2 Turbocharger. T4 Divided .84 A/R
- Heatshield Products Lava Turbo Blanket (300074)
- Modified Garagistic DSSR.
- MaximumPSI M50 Boost-proof ICV hose kit, Billet ICV fitting, 3” elbow
- RallyRoad Billet Fuel Rail
- Injector Dynamics ID1050x
- 034Motorsport injector adapters
- JEGS fuel pressure gauge
- Dual TIAL MV-S Wastegates
- DEI Titanium Exhaust Heat Wrap
- 14point7 Spartan 3 wideband O2 with LSU ADV sensor
- Aeromotive Compact Fuel Pressure Regulator (13136)
- Aeromotive Fuel Pressure Gauge (15633)
- Treadstone Front Mount Intercooler
- TIAL Q Blow Off Valve
- BMS Silicone Single Turbo Filter
- 2.93 LSD
- Dynomax Super Turbo 14" Muffler (17744)
- Turbosmart Boost Tee (TS-0101-1102)
- Interior
- 370mm M-Technic 1 Steering Wheel
- Custom digital voltmeter
- VDO Vision Black Water Temperature, Oil Pressure, Oil Temperature Gauges
- VDO Boost Gauge (Vintage, c.1978)
- Hidden headunit/radio - Alpine CDE-141 in the glovebox
- Replaced driver's seat bolsters.
- Wideband Gauge. Custom Defrost Switch Mounting.
- HushMat
- Dual Trunk Lid Lights
- CAtuned Black Headliner
- CRS Chassis Mount Shifter w/Delrin knob, custom DSSR
- Lloyd Mats Ultimat Floor Mats (Black) Front, Rear, & Trunk
- Exterior
- Repainted front kidneys. Made Both Chrome & Black options. (4 coats duplicolor trim paint)
- Repainted hood blanket (5 coats duplicolor fabric paint)
- Repainted bumper trim and surrounds (7 coats Duplicolor bumper coat - would not recommend, flaked after 4 months)
- E28 535IS Pfeba Heckspoiler
- 1987 is front air dam repaired, painted, and mounted.
- Better condition replacement front bumper w/custom license plate delete.
- Euro rear plate filler
- Repainted Cowl Vents
- 3M Ceramic IR Window Tint (70% Windshield, 50% Sides & Rear)
- Repainted Euro Grilles
- Xpel Ultimate Plus PPF
- SystemX Diamond Ceramic Coating
- Lighting
- Hella US Ellipsoids
- HID Lowbeam - Morimoto XB AMP 5000k 50W
- Startec Rear Lenses (2023 reproduction run)
- LED Front Running Lamps - Tuincyn 600lm (21x 2835 Diodes)
- LED Rear Running Lamps - Tuincyn 900lm (33x 5630 Diodes)
- LED Brake & Rear Fog Lamps - Tuincyn 900lm (33x 5630 Diodes)
- LED CHMSL/Third Brake Light - Tuincyn 900lm (33x 5630 Diodes)
- LED Rear Turn Signals - Hsun 1280lm (16x 3030 Diodes)
- Rear Fog Conversion to Brake Lamps
- LED Reverse Lamps - Tuincyn 900lm 8000k (33x 5630 Diodes)
- LED Side Marker Lamps - Auxito 200lm (24x 3014 Diodes)
- Bodywork
- Full Respray in Audi Ipanema Brown Metallic (IPANEMABRAUN).
- Colourmatched bumper trim, cowl vents, brake booster, blower motor cover, hood latches, CAtuned rad support, and Kamei rear valance.
- Colourmatched & smoothed rocker panels and rear sheetmetal.
- Removed ground terminal on passenger side strut tower.
- All engine bay seam sealer redone by hand.
- Quarter hood w/ shaved badge.
- Replaced all sunroof drain hoses. Front hoses no longer drain into rocker panels.
- Replaced seals & locking strips for windshield & rear glass.
- Eastwood Internal Frame Coat in the rocker panels
