Use studs on the header. Over the years, I have never had luck with aluminum heads and header bolts. Studs with stover nuts has been the choice.
Also, if you bead roll or put a weld bead on the end of your pipes, you will eliminate coupler leaks. (I have also seen the "poor man's" strap where they put a strap from pipe to pip over the coupler to keep them from popping, sorta like this...
Too bad you moved so far north. I probably have a CHRA you could borrow and/or a stock exhaust so you could go to Spectoberfest. :/
