Aussie 318is - now S54B32 swap
  • AusScare
    • Jun 2014
    • 220
    Today the old diff was pulled out and wrapped up. I'll spend some time cleaning it before selling it. The new diff went in, minor issue with the speed sensor plugs not matching, but ended up using the old sensor, which is working great.
    New diff installed:
    '90 318is
    • AusScare
      • Jun 2014
      • 220
      I had some time tonight so decided to try and work out why the dash lights would only work intermittently. Often it would be after I had been playing with the fuses, then moving stuff around the ecu, so thought some sort of connection was loose, but couldn't see which.
      I pulled the lower cover off, and followed a quick guide to remove the headlight switch and panel. I found that the big connector plug was barely plugged into the headlight switch!!!
      While I was messing with the car I thought I would take a look underneath and see if anything looked dodgy. On the passenger side sway bar I noticed some fresh rubbing marks, and the drop link bushing looked to be on a wack angle - thinking it might need an alignment of sorts? Hopefully that will sort the rubbing (on full look I can hear it when parking at home):
      And now I can see why the PO had cleaned the gearbox before I inspected it, looks to be leaking slightly, but not enough to drip onto the ground where I park the car. Good thing I won't be using the gearbox anyway after swapping motors:
      Next on the list is to fit the rear brake rotors I have sitting here.
      '90 318is
      • petrolhead
        • 421
        Originally posted by AusScare
        Had a bit of a read and decided the 4.1 ratio was good to stick to - meant not having to mess with the speedo, and it would suit the sr swap.
        Changing final drive ratio doesn't affect what the speedometer shows on an E30.
        What gear box are you going to use, what kind of ratios does it have? What's the redline on that Nissan engine? Those things pretty much decide what final ratio one needs.
        -Jarno
        • AusScare
          • Jun 2014
          • 220
          Good point, I guess I'll grab out the speedo app when its all together and find out!
          '90 318is
          • petrolhead
            • 421
            Find out what? Essentially, the diff speed sensor reads the rear wheels' combined rotational speed. Only way that the speedo could go off is to change the rear tyres' outer diameter.
            • AusScare
              • Jun 2014
              • 220
              Sorry I was confused by your previous post, I know the diff ratio and diff sensor set the speedo. Your mention of final drive put me off....
              '90 318is
              • J3M93
                • 448
                What wreckers did you get the lsd from?
                Also, send me a PM once the m42 is out, been looking for an upgrade to the m40 and I'm also in Brisbane
                • AusScare
                  • Jun 2014
                  • 220
                  BMWreckers at Acacia Ridge, not the cheapest, but was exactly what I needed and had a 3 month warranty..
                  '90 318is
                  • AusScare
                    • Jun 2014
                    • 220
                    RHDJapan.com were having a big sale on clutches, so I picked an OS Giken STR2CD twin plate clutch kit for about the same as price as the locally made alternatives.
                    This is rated at 600hp, and claims to be close to stock feel (which I doubt but happy to be proven wrong!!).
                    Took two days to get here from Japan:
                    '90 318is
                    • DER E30
                      • Sep 2013
                      • 2349
                      This one bolt was sooo tough to get. Started by soaking it in WD40 for an hour, then gave it a few wacks with a hammer before having another go with the spanner (with mallet attached). Turns out they were covered in thread locker:
                      I was just here! I wasted an extra hour at least on those stupid bolts!
                      -Christian
                      • 2mAn
                        Señior Mod
                        • 20997
                        Painted with black bumper paint, then put back in place:
                        I need that vent with the wiper arm hole covered... I wonder what the part # on that one is since its obviously a factory RHD part. any chance you could see what it is?
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        Make R3V Great Again -2020
                        • petrolhead
                          • 421
                          Originally posted by 2man
                          i need that vent with the wiper arm hole covered... I wonder what the part # on that one is since its obviously a factory rhd part. Any chance you could see what it is?
                          51 13 1 904 573
                          • 2mAn
                            Señior Mod
                            • 20997
                            I just found it too!! thank you!! :) Now I just have to see if BMW USA can get me one :rofl:
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            • AusScare
                              • Jun 2014
                              • 220
                              Met up with some friends to work on the cars, plan was to change the fuel filter and some other bits, turns out my fuel filter isn't the stubby one under the left rear side, it's actually in the engine bay, so I'll be ordering a different filter now.
                              I had cracked the battery cover when the new diff went flying around in the boot, so attempted a quick fix. Bit of plastic glue to piece it back together:
                              '90 318is
                              • thriftshopclassics
                                • Nov 2014
                                • 19
                                Great to see another Brissy 318is. I remember seeing this car for sale on Gumtree while I was looking for an e30, stoked to see that it's gone to a good home.
                                Have you fixed up the aircon yet? I would love to ask you some questions about it when you do, I am looking at doing the R-134a conversion to mine sometime soon. I have found this thread on e30 tech to be really informative, might help you out too...http://www.e30tech.com/forum/showthread.php?t=113435
                                Cheers mate.
