325IX restore and build continued(turbo, e34ix diff, DCT)
    • 34839
    #136
    cool! glad you're making use of them - gives me some ideas for my own frankenpan.
    Actually, do you need that ix inner piece? Maybe I could use it to get my frankenpan rolling? I'm sort of doing the opposite, putting an ix front diff on another pan..
    • nomansland92
      • 1657
      #137
      I may need it for a couple weeks just for double checking measurements and alignment but after that its all yours
      IX being restored here
      Ix turbo build here
        • 34839
        #138
        sweet! yeah I have a pan to cut up, but I'm a little afraid to start cutting into it until I have a better plan. Kudos to you for going for it. :)
        are you going to weld on another tab to add a 3rd bolt?
        if you haven't figured it out, the CV shafts are nearly bolt on. You need to transfer the ABS rings, and the face of the stub axles needs turned down a little so it fits into the hubs, but otherwise they are perfect - and I think the slightly longer length is actually a benefit, because when you get really low the stock ix axles bottom out.
        • nomansland92
          • 1657
          #139
          I'm going to weld a long brace along the top of the diff then built a bracket that will mount to the motor mount that way it will reduce any stress and rotational force on the welds. Well that's the plan atleast,I've got a long ways to go still haha.
          Ix turbo build here
          • nomansland92
            • 1657
            #140
            Did some playing around today. I got the spare driveshaft from another forum member for a spare but it turned out pretty bent. Not sure how anyone could bend one haha bud nothing a press can't fix. I chucked it up in the lathe and gave it a spin. You can clearly see the high spot.
            It was .060 out in the middle, I got it down to .007 when I was done so I'd say it's close enough for me.
            I got the spare because my driveshaft has leghtened splines which don't fit because the diff sits farther back. The good thing is with a stock driveshaft you get a lot more spline engagement with a little modification.
            Also did some cutting with the pan
            325ix meet your new friend 525ix
            Still needs a little more trimming but it's about 1/8 away from were it needs to be. As you can see there is a big hight difference so there will be a little lose of ground clearance.
            Ix turbo build here
            • Nisse Järnet
              • Aug 2013
              • 1221
              #141
              Yes! Nice work man!
              I think I only had to machine the diameter of the outer CVs, if I remember correctly :P In like 3-4 different places.
              E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
              E30 M50 6 spd 764whp @ 24psi.
              E30 M20 6 spd 675whp.
                • 34839
                #142
                Are you welding it back together yourself?
                One of the things I've struggled with on my N52 is the fabrication of my pan, I know I could cut it up similar to what you did there (that core piece will help me a lot I think), but I need somebody who can jig it and weld it up for me.
                • nomansland92
                  • 1657
                  #143
                  I don't think I'm going to, I have a tig and I'm OK with it, well at least my turbo manifold is still holding up so that says something haha. But I'm not the best with aluminum especially a contaminated oil pan. There's a local Subaru race shop by me and there welder is very good with aluminum and he said he should be able to do it no problem.
                  I'm going to start making the fillers this week and try to find a way to avoid the ground clearance loss then I'll be taking it to get it welded hopefully soon.
                  Sent from my SAMSUNG-SM-T817A using Tapatalk
                  Ix turbo build here
                  • boogle2
                    • Dec 2014
                    • 115
                    #144
                    Oh my god. I go dormant for a few months during the winter (no heated garage = no wrench turning) and the build I planned on following and emulating has turned into the most badass iX build in north america. Jesus. I am so jealous.
                    Steve since your power goals have changed dramatically, if you are looking to sell any of your old setup I would be more than happy to take it off your hands.
                    This is awesome!
                    2011 335i xDrive Msport - sold
                    2002 M5
                    '88 325ix turbo build :D
                    • nomansland92
                      • 1657
                      #145
                      This is awesome!
                      Haha thanks, as with any turbo project nobody's ever satisfied until to you push the limits. Ya my power goals have changed as we'll as a lot of other things. I'll be using haltech elite with e85 with a flex sensor and hopefully full sequential fuel and spark(if I can get a cam sensor) and with of course the e34 front diff with 3.38 gears :) I not going to be changing to much of my existing setup besides the megasquirt, injectors, and my gfb boost controller.
                      The ms2 is built my whodwho but it's a older one and the idle control doesn't work, I think it's a blown transistor or something. I was also having problems with my iat sensor but that may have been a wiring. I'll be selling it cheap. Probably around 300 with WiFi setup.
                      The injectors are deka 60lbs. I only put around 5k on them. Probably sell them for around 200ish. I forget what they normally go for.
                      And the gfb boost controller is the g force 2 electronic controller. I'd say like 200 bucks for that too.
                      Let me know if you want anything but I'm not looking to sell until I get my new parts just in case something comes up. It will probably be late winter when I'll be ready to sell everything. I have to finish the driveline swap before I start the haltech setup and wiring.
                      Ix turbo build here
                      • Nisse Järnet
                        • Aug 2013
                        • 1221
                        #146
                        Looking forward to the result! 3.38 is going to be great with the Getrag and M20 turbo!
                        Cam sensor is easy fix :)
                        • nomansland92
                          • 1657
                          #147
                          I know I can't wait for 3.38s, my first gear is useless right now haha. I've seen a few people build there own cam sensor but I'm a little lost on placement of it. I've seen them in a few different spots on the m20. I really just haven't had time to sit down and do some research though.
                          Ix turbo build here
                          • Nisse Järnet
                            • Aug 2013
                            • 1221
                            #148
                            I got a PPF sync cover and a Hall sensor then your done :) Oh you have to make a trigger but that's easy, won't be a problem for you !)
                            • nomansland92
                              • 1657
                              #149
                              Actually I think I have heard of them before. Anyhow I just checked out there website and thanks to Google translate I found one for the m20. Even says it comes with a pick up.
                              http://server.pure-pf.com/webshop2/i...duct&id_lang=1
                              Ix turbo build here
                              • nomansland92
                                • 1657
                                #150
                                About were it needs to be
                                Here is the ground clearance lost. However it's inline with the wheels so as you run anything over the pan will move with it. Unless you were straddling something of course.
                                Start of a jig to hold it in place
                                I'm going to order some aluminum this week to start putting it together.
                                Unfortunately I work in construction and I'm going on night turn for now. So it might get hard to find time to work on it besides weekends.
                                Ix turbo build here
