Slammin' finished something....
  • slammin.e28
    שמע ישראל
    • 12054
    So I disassembled an 850 for a friend.
    In 6 hours it was nothing but a rolling hulk....with subframe fasteners loosened for easy removal pre-scrapping.
    ...and in the end, I got this:
    ...and oily, greasy ball of aluminum.
    Plan is to reseal it. About $300 in gaskets, etc. Missing some hardware on the upper timing cover, hopefully not broken off....
    Probably end up doing a timing chain, guides, basically everything I can do without removing the heads....but should I find something like a broken head bolt.....I'll go there.
    I've made up my mind what this engine is going in to. I'm hesitant to say. It'll pretty much bolt in with the right bell housing, if that gives any indication. Also it'll be easier to install this engine than to put an M60 in an e30.....
  • E30NJ
    • Aug 2013
    • 921
    How hard was it to yank out that engine? Nice work.
    • slammin.e28
      שמע ישראל
      • 12054
      Not difficult. Didn't cut any wires. Everything was unhooked via connectors. I later went through and harvested pigtails though....mostly so I can use the stock wiring connectors in the new home for this engine.
      I also literally cut the front off the car. Made it soopah easy.
      • E30NJ
        • Aug 2013
        • 921
        I've heard people do that with E36's to make it easier to yank out. Keep up the good work.
        • Dj Buttchug
          • Jun 2010
          • 7688
          yesss
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • ST1G
            • Oct 2012
            • 6690
            So if I understand correctly, you are going to have v12 e30?
            • slammin.e28
              שמע ישראל
              • 12054
              No pls. No.
              Better.
              • rturbo 930
                • Dec 2005
                • 2629
                V12 Land Rover?
                • ST1G
                  • Oct 2012
                  • 6690
                  no pls. No.
                  Better.
                  maybe if you would respect the constitution and learn the native language next time you immigrate somewhere people would understand you more better. Your here cuz we let u b here. Never forget that!!!!!1!!1
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    whuut.
                    • ST1G
                      • Oct 2012
                      • 6690
                      whuut.
                      I was just being defensive since I didn't understand.
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        Oh, lol.
                        It'll be a long way out, but yeah, dis goin' be good....
                        ....and it'll probably be done before the v8 e30.....
                        I have more pics on my phone....but my phone decided to not let me "slide to unlock"......douche.
                        • ST1G
                          • Oct 2012
                          • 6690
                          Oh, lol.
                          Yeah.... did you hard reset it?
                          • slammin.e28
                            שמע ישראל
                            • 12054
                            My power buthoon is broken, so I have to wait for it to die. Got Siri to play music all day....and I'm only at 56%.
                            Tried getting GPS to turn on via Siri, but then it wants the passcode. FAK
                            • ST1G
                              • Oct 2012
                              • 6690
                              So the screen as a whole is unresponsive? Do you have assistive touch on?
