Slammin' finished something....
  • slammin.e28
    שמע ישראל
    • 12054
    #76
    • The Dark Side of Will
      • Jun 2010
      • 2796
      #77
      I've read that the EML throttles from the M30 535i's can be swapped onto an M70, and are larger than the M70 units.
      I put 40k miles on such a car and never had problems with the EML.
      • slammin.e28
        שמע ישראל
        • 12054
        #78
        Not sure if I want to make the EML work or not. Just pulled the throttle off a e34 535 to sell. Harness was cut.
        If that'll bolt up, then a standard M30 throttle should. Just have to figure out how to make the ECU see the position. I wanna get it running on the OE configuration....
        • Peterkaczynski
          • Nov 2008
          • 2587
          #79
          this is going to be great
          e24 e9 e30
          IG: peterkaczynski
          • Holland
            • Nov 2008
            • 7176
            #80
            Glad I didn't miss this one.
            Originally posted by DEV0 E30
            • blck325is
              • Apr 2006
              • 1749
              #81
              There is something about big cars moving quicker than logic dicates they should that just makes me giddy...do hurry up and get that beast rolling.
              Originally posted by csermonet47
              Vlad, you are handling this quite unprofessionally.
              Also, you are a cock with tacky taste.
              That is all.
              • Andrew325is
                • Jan 2008
                • 1203
                #82
                This is a very interesting swap you are undertaking! Now we'll both have DBW Landys. :) I bet you could use a modified Freelander gas pedal like I am, but replace the potentiometer with the E31 unit.
                Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
                • Swanny
                  • Mar 2012
                  • 2834
                  #83
                  Glad i didn't miss the reintroduction of holland! The fuck you been hiddin brah?
                  Swanny!
                  SUCKERS.
                  • PatriaCoutee
                    • Oct 2014
                    • 1
                    #84
                    As you know that the mobile phone signal jammer can cut off the signals of the mobile phones and soon make it impossible to make phone calls or send messages. In this way when you need the peaceful condition and want to stay in it, you can just use the best mobile phone jammer to help you achieve your goal. And now as the technology develops with high speed the advanced Cellphone Signal Jammer has come into the market and are well welcomed by the group of people who need the jammer product.
                    • Alpina
                      • Oct 2004
                      • 838
                      #85
                      This is really cool..........
                      I would recommend one thing... since you are changing so many gasket and seals..
                      take the head off also .. its dead easy,,
                      i took my M70B50 totally apart and changed everything except pistons and rings,, all bearings etcetc
                      timing the M70 is also dead easy... the M70 use the same tool as M40,, and can be made by your self
                      Since you are using the oem manifold gasket again (as i did) i really recommend that you contact Max Lumens... on Bimmerforums,, he makes a thin siliconegaskets that you put between your oem on head and manifold... cheap,, and brilliant solution
                      if you want any info ,, you are welcome to contact me
                      i wish you all the best with this project
                      nothing beats the V12........... look and smoothness
                      Sveinbjörn Hrafnsson
                      E30 CABRIO V12 M70B50 ///
                      ALPINA B10 BITURBO 346 @ 507
                      E34 550 V12 JML
                      Finnish wisdom : If you want to Win,, hire a Finn
                      http://alpina.123.is/pictures/
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        #86
                        Hmmm.......I'll have to look into this. I'm really stuck.....do I go Megasquirt, or OE. OE you can get chips for $500 and get a nice bump in power.....but with MS....for $500 I can get this all setup and probably do better than what the chips get.....plus it leaves me open to force air into the engine.
                        Oh yeah, been following you. Going to check a rod bearing when I reseal the oil pan. If it's good I'll seal 'er up. I'm really adverse to pulling the head unless there is an issue requiring it. Def going to hit up Max for the gaskets.
                        I drove the truck today.....Jesus.....can't wait to get 6 more cylinders in there. Interstate driving is so agonizing.
                        Still love this truck, lol.
                        • deutschman
                          • May 2008
                          • 5958
                          #87
                          Cool project
                          • Massimo
                            • Jan 2008
                            • 3207
                            #88
                            I think.
                            You should...
                            Turbo?
                            • E30_Pare
                              • 7801
                              #89
                              How big are those tires? We only went 2 inches taller than stock on the p38 and hill climbs hurt.
                              DREWLIENTE
                              1$ PShops PM me
                              • slammin.e28
                                שמע ישראל
                                • 12054
                                #90
                                Originally posted by Massimo
                                I think.
                                You should...
                                Turbo?
                                We'll see. 8.8:1 compression is tempting.
                                33" lol
