Slammin' finished something....
  • delamaize
    • Nov 2013
    • 1461
    #226
    Originally posted by Nesset
    In for sideways V12 Bimmer video.
    This.
    Dumpster Fire Pilot
    • slammin.e28
      שמע ישראל
      • 12054
      #227
      OFC I'm the no burnout guy....so don't expect anything.
      I've got to fix the oil leak before I do any hooning.......
      • Nesset
        • Mar 2014
        • 672
        #228
        No burnout. Only sideways in a cloud of smoke with that beautiful V12 singing me a tune.
        -1976 2002 daily (Sold)
        -1986 528e 5 speed daily
        • ST1G
          • Oct 2012
          • 6689
          #229
          OFC I'm the no burnout guy....so don't expect anything. .
          Pls. We don't.
          • ST1G
            • Oct 2012
            • 6689
            #230
            bump
            • slammin.e28
              שמע ישראל
              • 12054
              #231
              Originally posted by ST1G
              bump
              • slammin.e28
                שמע ישראל
                • 12054
                #232
                Is this thread about a Land Rover or a 750iL?
                IDK.....whatever.
                I deleted the SLS on the ten-till-8 the most right way.
                Rear struts are standard from a 735i. PS pump has the one way valves gutted and the opening for the suspension line plugged with a shaved down oil drain plug.
                Next up.....upper oil pan gasket....fun fun.
                • ST1G
                  • Oct 2012
                  • 6689
                  #233
                  I don't know if anyone knows what this thread is about.
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    #234
                    I'd make it about you but then Lambo would be all jelly.
                    • slammin.e28
                      שמע ישראל
                      • 12054
                      #235
                      Oil pan adventure done.
                      WHAT FUN
                      Have to drill those two holes to get to two of the bolts. Otherwise, the factory way, you have to remove the transmission....
                      Did the engine mounts.....the one on the right is from the left (driver's) side....so it see all the engine tq when revved.
                      It's also in a position where you cannot replace it without dropping the subframe.
                      I hope to not have to see this side of this oil pan for a loooong time.....if ever.....
                      But really, it isn't that bad of a job to do. I would have had it done quicker but I decided to get and install the engine mounts.
                      ....and all buttoned up.
                      Sadly I don't have pics of the subframe(s) hanging down and the bottom end of the engine. Nothing was found laying in the pan. I was impressed.
                      Next chapter will be the valve seals and the peeling back of the layers to replace those.....
                      • CorvallisBMW
                        Long Schlong Longhammer
                        • 13039
                        #236
                        I don't even know what car you're working on....
                        • slammin.e28
                          שמע ישראל
                          • 12054
                          #237
                          They all just kinds run together for me too.
                          • Dj Buttchug
                            • Jun 2010
                            • 7680
                            #238
                            im a huge fan of the activities displayed here
                            Turbo M42 Build Thread :Here
                            Ig:ryno_pzk
                            I like the tuna here.
                            Originally posted by lambo
                            • ST1G
                              • Oct 2012
                              • 6689
                              #239
                              That's really cute slammin.
                              • slammin.e28
                                שמע ישראל
                                • 12054
                                #240
                                Man, after reading those comments I had to check and make sure I didn't post those dic pics that were meant for Blunt.
