E30 #2: 1990 Delphin: RHD ITB M20
  • digger
    • Nov 2005
    • 6196
    #316
    Originally posted by e30 gangsta
    I assume now with the airbox on the street you are no longer having heat soak issues with the trumpets?
    the exhaust radiation and coolant temp will still be the same, and if there is not enough airflow i.e. if youre sitting in slow traffic on a hot day everything under the hood simply gets hot. The airbox if ducted well means the engine breathes cooler air because you limit how much air from under the hood is ingested. it doesnt solve a heat soak issue it solves an IAT issue
    • 318aye
      • Jun 2010
      • 895
      #317
      Originally posted by alas
      I'd also like to know as I'm about to restore those same bits plus my mirrors very soon.
      Great write up so far!
      Thanks, see above.
      Interesting. Nice to see that the airbox finally helps. I assume now with the airbox on the street you are no longer having heat soak issues with the trumpets?
      As with most things, what digger said. It allows you to maintain all the port velocity and tuned length runner benefits while also mitigating IAT's.
      • e30 gangsta
        • 3877
        #318
        Originally posted by 318aye
        Thanks, see above.
        Understood. I just didn't like the fact of open trumpets on a street car. Too high ait's and no filtration for the engine which is bad. Then you run socks or filters on the stacks and you lose power. Kind of a dumb setup if you ask me.
        Now if you get more power, lower ait's, and a proper filtration while running the airbox setup, then it is the only way to go in my eyes.
        With the kit can you maintain stock cruise control?
        • 318aye
          • Jun 2010
          • 895
          #319
          It's certainly incomplete, but definitely fun. I never had any serious issues, but I also didn't daily drive the car with open stacks, and had screens to prevent any big debris. Airbox fixes these things ;).
          I'm planning on putting cruise back on the car. It is in no way tied to the ECU IIRC, and everything would fit back up (as long as my ducted solution for the filter doesn't get too bulky, still interested to see what Kam does). I will need to get new brackets cut locally to allow for mounting of the cruise throttle cable, in red below:
          The rear bracket is pretty easily redone, but the bracket on the master link is going to require thought. There's not a whole lot of room when you move through its range of motion.
            • 37833
            #320
            I just spend a long time going through this thread. How did I not see this before?
            Great work, I love your documentation of everything!
            I think 180whp is damn impressive.
            Grover Beach, California
            BimmerHeads.com
            • 318aye
              • Jun 2010
              • 895
              #321
              Thanks! I try to be helpful.
              I'm hoping to build a high compression 3 liter next year, should be fun!
                • 37833
                #322
                Let me know if I can help in any way! 8)
                BimmerHeads.com
                • EuroChriz
                  • Jun 2014
                  • 588
                  #323
                  Such a great build! Keep up the great work!
                  I'd pay to get my cluster converted that way!
                  • 318aye
                    • Jun 2010
                    • 895
                    #324
                    I definitely will.
                    Thanks. Definitely doable on your own, I think the parts were ~120. BavRest will also do everything for you + refurb your cluster if you're into that.
                    • 318aye
                      • Jun 2010
                      • 895
                      #325
                      Put another 350 miles on the airbox. No rubbing on either end, everything held up great. Weather held up nicely at The Vintage as well, Hot Springs is a killer venue. Thanks to Reichart for the 19# injectors that will get me some fuel headroom, and Levent @ GPS for the stainless brake lines! Also looking at overhauling the cooling system as the car does like to creep a bit when the weather is warm.
                      Got the drone out for a bit.
                      • bradnic
                        • Jul 2012
                        • 3554
                        #326
                        Kills me that I missed your car there. I did see Andre and Dan though. next year I hope
                        HOWTOs:
                        DB vert plastic bumpers
                        OEM Keys
                        MTech1 docs
                        88 ix Lach/Card
                        91 ic Calypso 3.1
                        86 Cosmo 2.7
                        OEM+ or bust!
                        • spike68
                          • Apr 2009
                          • 1185
                          #327
                          Ugh. Your car....and your wheels. I want all of it
                          Sent from my SAMSUNG-SM-G925A using Tapatalk
                          I don't even own this car anymore, but I'm too lazy to change the picture.
                          • Reichart12
                            • Aug 2012
                            • 2165
                            #328
                            Thanks to Reichart for the 19# injectors that will get me some fuel headroom.
                            Hey it was good meeting you the other day. They should be the 21# pink top injectors so even more headroom than 19s. I should have a picture or two of your car Ill be posting in the coming days once I get around to going through them all.
                            Instagram: Reichart12
                            • 318aye
                              • Jun 2010
                              • 895
                              #329
                              I did get to see your car, looked slick!
                              18K.
                              Yeah, good to put a face with the name. You were right, I had them flow checked and cleaned today and they flow 22.3 Lb/Hr @ 3 Bar. Looking forward to pics.
                              • digger
                                • Nov 2005
                                • 6196
                                #330
                                Those look like 24v injectors
