E30 #2: 1990 Delphin: RHD ITB M20
  • MPLFoster
    • May 2013
    • 1490
    #106
    Originally posted by tinkerputzer
    You're going to be missing out on some low end power with the y-pipe that close to the primaries. I like the direction of this build though.
    Where would the optimal place be for the merge?
    form.follows.function IG @mplfoster
    • tinkerputzer
      • Jun 2008
      • 508
      #107
      It's somewhat engine dependent but iirc it's somewhere around 30" from the end of the primary pipes. Check out digger's exhaust thread.
      • icebox
        • Nov 2014
        • 8
        #108
        What suspension setup are you on? thanks
        • kamotors
          • Nov 2007
          • 7102
          #109
          get this things running on ITB's:) I want to see if you have the same issues as mine.
          7speedshop.com
          • digger
            • Nov 2005
            • 6192
            #110
            usually a full on race engine with big overlap cam can make good midrange and topend with a short collector length but longer length seems to produce best overall power spread with bmw sixes, individual results may vary though
            • 318aye
              • Jun 2010
              • 895
              #111
              I think my merge is maybe 12" from the collectors. Once I get power numbers and a dyno chart, I'll get some location and length measurements on this exhaust system and look at what may need tweaking.
              The PO was kind enough to install Eibach Pro-Kit springs and Bilstein Sports before I purchased the car. That is how it sits today.
              Hoping to get the car firing with ITB's/MS by Sunday. What are you running into? :shock:
              I'll be tuning on a different dynojet than the one my baseline numbers came from (also a dynojet) but I'd like to get on that same one as well to try and get as "apples to apples" as possible. Hopefully then you can help me analyze the plot and brainstorm where to go next as far as midrange improvements. :D
              Remaining sensors arrived today. Thanks to DIY for the IAT. I'll sleep comfortably at night knowing that no matter what, my wideband harness will be long enough. ;) Every bit of 9 feet long. Should be a fun weekend!
              • Reichart12
                • Aug 2012
                • 2165
                #112
                Cool to see us both planning to do our car work this weekend. Hopefully its a little warmer where you are than it is up in Maryland, 50-60 all weekend.
                Instagram: Reichart12
                • 318aye
                  • Jun 2010
                  • 895
                  #113
                  Ended up doing more non-car stuff this weekend than I planned. I'm probably 12 hours overall into the project (including pulling the intake manifold, etc). I work slowly :).
                  Things I still have to tackle:
                  Fill PS System (New reservoir)
                  Install E36 throttle cable
                  Make Brake booster/FPR vacuum line
                  Potentially rewire TPS (waiting until MS is in to verify inverted counts issue)
                  Build O2 harness
                  Clean underside of the car (four cans of brakleen later...)
                  Install MS
                  Build bracket for the C101 connector
                  Sync throttles
                  Sort out some sort of catch can
                  Change oil (I think I got crap in the bitch tube hole, just precautionary)
                  Assembly Notes: Only things you can really delete under the intake manifold are the throttle body coolant lines (need two heater caps, different sizes), and the bracket that holds the main coolant hose to the engine harness. The dipstick bent over fine, and will hold itself. No bracket necessary. Will need a bracket made this week for the C101/friends connector. Thinking of going off the factory airbox mount. Other than that most of my time was spent degreasing. Everything went together incredibly well until the 5-6 bank. Serious interference with the engine harness and the provided TPS. Much yanking was involved. Not sure how everyone else routed it, but mine runs on the driver's side of the TPS. Routing to the other side would not give enough clearance for the TPS connector. I installed all banks "pre-assembled", with trumpets on and everything. I did 3-4 first to get the bitch tube taken care of, then 1-2 (slid together fine with the shaft links and everything). 5-6 required me to remove the keeper off the #4 shaft link, and then re-install. When you install, leave the fuel rail brackets off and install those later as it makes it hard to get to the top nuts on the manifolds. Also note that the fuel rail will need two (M6 I believe) nuts that you didn't need before. The RHD brackets are not threaded. I had two nuts that fit sitting around that came off some other part of the intake manifold. Didn't have to disconnect the fuel lines for this install. Fuel rail install also requires that you have the main throttle arm bracket removed, so assemble that ahead of time but don't bolt it to the manifold until you have the rail in. Hood clearance is tight. With socks will be even tighter. I also ran into the main fuse box connector on the #6 trumpet. Removed the plastic shroud (does nothing) and it clears.
                  Pictures:
                  • goarmy
                    • Nov 2011
                    • 622
                    #114
                    Well.. they at least match the header part of the exhaust, they are good for high end torque.
                    • 318aye
                      • Jun 2010
                      • 895
                      #115
                      Hoping so!
                      • 318aye
                        • Jun 2010
                        • 895
                        #116
                        Evening number three went slower than I would have liked (again). Hoping to start the car tomorrow. Remaining Items:
                        To start car:
                        Build O2 harness
                        Install MS
                        Change oil
                        wire IAT
                        To complete project:
                        Sync throttles
                        Install catch can
                        Powdercoat Valvecover
                        Install socks
                        Check hood clearance
                        Started off by accidentally "modifying" the throttle cable. It comes bent towards the passenger side of the car, which interferes with the brake booster. I attempted to bend the hardline portion of the cable cladding, and actually separated it from the firewall grommet cleanly. This ended up working out, allowing me to re-position the cable to point straight up coming out of the firewall. I then superglued the fuck out of it. Cable routes up over the fusebox connector. Used the stock booster and check valve fittings. Used 3/8" ID FI line from autozone. DO NOT buy this. Was super expensive and unnecessary. Also the fittings are 7/16" ID at least. I had to muscle this together. Used one T fitting for the FPR vac line. Plugged in the TPS, factory harness length reaches. We'll see if the pinout is correct.
                        Pictures.
                        • 318aye
                          • Jun 2010
                          • 895
                          #117
                          List got shorter this evening :).
                          Down to the following:
                          Mount IAT
                          Sync throttles
                          Install catch can
                          Install socks
                          Getting the throttles linked up this evening reminded me how much I need a proper small metric allen key and wrench set. Would advise if you're planning on buying this kit. Got the oil flushed. O2 sensor still fit the OE heat shield, fit the bung from eurowise perfectly. Zip tied the lower connector to the trans cross member, ran it tight up the firewall and over to the battery tray. Still excess length here, so it will stay coiled for now. O2 and IAT connectors went together smoothly. Big props to Keith (Whodwho) again for a killer MS implementation. Fired on second crank on his basemap. Revs nicely and idles. Very happy for the first start up. C101 bracket also worked out nicely. CNC plasma'd out of .100" mild steel. Would like to work out a mount for the IAT that spans between the lower bolts for the trumpet clamps on two adjacent banks and has a hole for the IAT in the middle. May have to weld to the C101 bracket to mount the catch can, we will see. Went to several nascar takeoff stores to source one locally, everything had gigantic fittings. Ordered this from Amazon:
                          http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
                          All in all, super happy with the car so far. Time to tie up a few loose ends in the bay and get on the dyno in two weeks.
                          Wiring References:
                          http://aemelectronics.com/files/inst...Controller.pdf
                          The NEW full standalone AMP Play-N-Play ECU for the 1987-1993 BMW E30 / E32 / E34, installs for most in under an hour.
                          Pictures:
                          She's alive :P (Click for video)
                          • 2mAn
                            SeƱior Mod
                            • 20992
                            #118
                            Cant wait to see what it makes after tuning. Congrats on getting it running
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            Make R3V Great Again -2020
                            • itskingsteelo
                              • Jul 2013
                              • 1340
                              #119
                              comment right heeeeeeere
                              Originally posted by dvck
                              • 318aye
                                • Jun 2010
                                • 895
                                #120
                                I know, can't wait. Probably going to rough in the tune a bit and drive it this weekend.
