E30 #2: 1990 Delphin: RHD ITB M20
  • 318aye
    • Jun 2010
    • 895
    #451
    Originally posted by ForcedFirebird
    Sam ol same ol. :)
    You said you disconnected the sway bar. Are you talking about the rear due to over-steer?
    Yeah. Decision Progression:
    Install 25 / 22 IE Bars
    Love it on the street
    Go to the track on G-Force Sports, absolutely roast them. Awful. Can't put power down on corner exit.
    Move to Azenis RT615K's. Better, but still not great. Car loves to slide (still fun), but would likely be faster with more grip.
    So we'll see how it feels at the end of June at Road A again. Love the throttle steer, love the rotation, just need more grip. Early testing seems to be beneficial.
    • ForcedFirebird
      • Feb 2007
      • 8300
      #452
      RA, my fav track! Too bad we got snowed out at the 14hr in Feb. :/
      Yeah we had the same problem at first and found the rear dampers lacking. We ran DZII's for a few years, then went to Azenis (both in 205 55 on 7's), now we run the BFG Rivals (in 225 45 on 8's). Same sway setup, but rear is adjustable and on the softest setting. We also use B8 Bilsteins from an F-Body modified to fit the rear, IE III springs. Also helped adding some clutches in the diff too. We roasted the diff at Sebring in Sept and the car was a bear to handle - ended up removing a sway link. Might be worth looking into your diff clutches.
      john@m20guru.com
      Links:
      • 318aye
        • Jun 2010
        • 895
        #453
        Hmm. Full setup refresher:
        • Eibach Prokits (-1.5" or so, nearly stock rates)
        • Bilstein Sports
        • IE 25 / 22 (Minus the 22 now)
        I had the IE's on full soft too and it was still bonkers. I think i'm going to go after some non-stock spring rates before I open the diff up.
        • ForcedFirebird
          • Feb 2007
          • 8300
          #454
          Don't necessarily have to open the diff. Just jack one side and see how much effort it takes to rotate one side. I could easily grab ours and turn one side, probably in the range of 10-15ftlb preload. One of the bellvue washers was toast and the clutches were glazed. Went with the 4 clutch kit and billet cap from diffs online, stockish preload. Really want to try a 2 way center with no decel lock.
          Also, you won;t have to pull the whole diff to pop the carrier out and swap the clutches if that's the case.
          Also, you can use the front bar to get a push in the front. Full stiff (or heavier front springs) can help keep it from rotating.
          john@m20guru.com
          Links:
          • 318aye
            • Jun 2010
            • 895
            #455
            Innnnnteresting, I'll give it a look!
            • 2mAn
              Señior Mod
              • 20989
              #456
              Love this car. Glad to see an update. Those brakes look nasty!
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              Make R3V Great Again -2020
              • 318aye
                • Jun 2010
                • 895
                #457
                Yeah they were pretty gnarly. I felt guilty.
                Bled them with a local shop yesterday, was very vindicating to see them have issues getting the air out too. We eventually did get more air out of them, and now the pedal is stiffer and more consistent. Pedal travel is still a little long, they're citing the fact that this is an ATE master replacing a Girling. I'm going to play with the brake lever clevis adjustment and see if I can sort some of that out.
                • whodwho
                  • Jun 2008
                  • 1547
                  #458
                  Good to see you back at it 8^)
                  My M20 Frankenbuild(s)
                  4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                  • 318aye
                    • Jun 2010
                    • 895
                    #459
                    Good to hear from you Keith! Someone was just commenting on the ECU setup in the car the other day and I got to drop your name. Hope you're doing well!
                    Dropped the HRE's off at EWW last week, looking forward to getting them back soon.
                    Got the new DD FJ80 sorted and took on rehabbing a wayward RX7 for a friend.
                    Click image for larger version  Name:	I2RqqUc.jpg Views:	0 Size:	84.4 KB ID:	9926339
                    Click image for larger version  Name:	bRmWCAN.jpg Views:	0 Size:	83.7 KB ID:	9926338
                    The E30 got very jealous and simultaneously popped the power steering feed line AND the oil cooler thermostat o-ring, so we'll be attending to those before another two day at Road Atlanta next month. Brakes are firm and consistent, excited to see how they feel with PFC08's.
                    • rzerob
                      • Jun 2013
                      • 2315
                      #460
                      Do you have a build on the Rx7? When I first saw it, I thought the paint was patina. Then I realized the glass looked the same and it was just dirty. I am curious to see it cleaned up.
                      • 318aye
                        • Jun 2010
                        • 895
                        #461
                        I don't, and sadly I think it'll move on to someone with deeper pockets. The majority of the car is in great shape, but there's a frame section that needs desperate attention that's going to punt it out of my friend's budget.
                        There was a car underneath all that though!
                        Click image for larger version  Name:	IMG_20200516_184110.jpg Views:	0 Size:	72.1 KB ID:	9927091
                        • 318aye
                          • Jun 2010
                          • 895
                          #462
                          Unfortunately FCP Euro's "12mm OD" fuel line is actually 12MM ID, but still made some non land cruiser progress today.
                          Fresh PS feed + return lines after the feed finally gave up the ghost. After feeling the crimp on the return, it didn't appear far behind it. Nice to have everything clean again!
                          Also resolved a pretty bad weep from the oil cooler thermostat seal. Things got complicated when I couldn't find my clamp, but managed to push it in there with a few 3/8" extensions and my jack while I secured the new snapring. We'll sort the fuel lines out next week and she'll be ready for Road A again.
                          • AWDBOB
                            hooptie connoisseur
                            • Aug 2013
                            • 4496
                            #463
                            Did you ever figure out a solution to retain cruise control?
                            • 318aye
                              • Jun 2010
                              • 895
                              #464
                              I haven't, still have all the original parts though. It would really only require a new main throttle bracket.
