M30 OEM Turbo project
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    #556
    Also I cannot get TunerStudio to display the correct AFR. My GG display shows a 13-14ish but TS shows a unmoving 9.70, even though I've set my AFR to LC1-LC2 and even custom input the curve (0V=7.35 AFR, 5V = 22.39 AFR). Ideas?
    • potatomash
      • Nov 2014
      • 203
      #557
      Where's your gauge grounded?
      Sent from my HTC One M9 using Tapatalk
      T U R B O - M 2 0 - B U I L D
      M U S C C O O
      • CorvallisBMW
        • 13039
        #558
        Gauge and LC2 are grounded to the shock tower (same place as the ECU)
        • CorvallisBMW
          • 13039
          #559
          While my charge pipe is getting welded up I can't start the car (no IAT sensor) so I managed to do a couple of other things.
          Replaced the ebrake cables since the threaded adjusters at the handle were stripped; I couldn't tighten them down enough to really grab. Not a hard job, just a PITA because you have to disassemble the entire rear brake and ebrake assemblies in order to unhook the cable end.
          Changed out my 25-year-old fuel pump for a Walbro 255 l/hr unit. Something tells me that 3.5L and 36 lb/hr injectors were going to kill that poor OEM pump designed to work with 2.5L and 17 lb/hr pieces.
          • CorvallisBMW
            • 13039
            #560
            Got some shit done last night, but of course forgot to take pictures... I always forget to take pictures, but I'll try and snag some tonight
            All new headlight mounting fasteners went in, so now all 4 headlights are aim-able and no more rusty screws and broken mounts. Yay! It's so nice to be able to just use a flathead screwdriver and quickly, smoothly adjust headlights without cursing and breaking shit. Re-attached the grills as well and now the front end is all bolted up and ready.
            Charge pipe should be done tonight!
            • 2mAn
              Señior Mod
              • 20969
              #561
              I need to do this with mine, did you buy them new from the dealer or ?...
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              Make R3V Great Again -2020
              • CorvallisBMW
                • 13039
                #562
                Blunt, p/n 63131385397 for the adjusters with brackets, and p/n 63121378369 for the little plastic buckets that the adjusters snap in to. 2 required per lens, so 8 for a whole car.
                • 2mAn
                  Señior Mod
                  • 20969
                  #563
                  thank you
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  • CorvallisBMW
                    • 13039
                    #564
                    Here's a few shots of the new headlight adjusters installed. Not glamorous, but it's progress. Installed my vintage Hamburg BMW badge too.
                    Also this arrived... Anyone want to guess why? :mrgreen:
                    • e30m3s54turbo
                      • Jun 2010
                      • 3290
                      #565
                      Is it suppost to say 345i?
                      I use to own Mike Deitel's Alpina 345i.
                      • CorvallisBMW
                        • 13039
                        #566
                        Got my charge pipe back from the welder! Looks super good.
                        Good looking welds, of course they should be considering this guy has been building car exhausts for 30+ years
                        IAT sensor + bung
                        Nipple for 1" BOV
                        A little shot of a project he's got going for another customer. '55 Bel Air with a Viper V10
                        He also had this awesome vintage sticker on his toolbox
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          #567
                          I like all of this.
                          How much did he charge you to weld that? I'm going to need a guy to weld my intake box together on the MG when the time comes.
                          • CorvallisBMW
                            • 13039
                            #568
                            He charges $50/hr, my pipe ended up being $200
                            • dahows
                              • Nov 2009
                              • 583
                              #569
                              Who's your guy Darin? I'll need some exhaust work one of these days.
                              84 323i
                              • CorvallisBMW
                                • 13039
                                #570
                                Tom Phillips out of Vancouver. I'm not sure how much time he has right now but I'll ask if he's OK with me giving out his number (he just does it in his spare time nowadays)
