M30 OEM Turbo project
  • AndrewBird
    The Mad Scientist
    • 11898
    #586
    Can you flip the TPS 180ยบ so the plug is facing downward?
    • CorvallisBMW
      Long Schlong Longhammer
      • 13039
      #587
      No, the shaft is keyed so that it can only go on one way. But here's what I did:
      Took some of these 90* end plugs that are inside a lot of the various electrical connectors for the engine (these were from the aux fan switch plug) and fitted them to the three pins that are used for the Megasquirt variable TPS signal. Unfortunately the old plastic is really brittle and cracked in a few places, but it will work for now until I can find one at the junkyard in better shape.
      Once the dust boot is installed, you can hardly tell the difference
      Until you look at it in profile
      Plenty of clearance now :)
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        #588
        No burn out vids yet... I am disappointed
        1991 318i 4dr slick top
        Mtech 2 turbo restoration
        • CorvallisBMW
          • 13039
          #589
          Well the good news is that I'll take it to DEQ tomorrow to get new tags (since they expired in October last year...) at which point it should be legal and driving. I actually took it for a spin Sunday morning and it did great! I need to adjust a few settings on the enrich map and idle control, but so far so good :up:
          So burnout vids will be coming... soon...
          • CorvallisBMW
            • 13039
            #590
            I have extra stainless steel heat shields for sale: http://www.r3vlimited.com/board/showthread.php?t=383164
            If you are running the factory m106 manifold, you need these!!
            • CorvallisBMW
              • 13039
              #591
              Made some adjustments to the MS2 system yesterday to try and get it running a little nicer.
              - Switched from MAP-based enrichment to TPS-based, seems to have helped the hesitation I was getting when I suddenly snap open the throttle. Still trying to dial in the TPSdot threshold for maximum response. https://www.diyautotune.com/support/...el-enrichment/
              - Fixed the bucking on deceleration by running 100% fuel cut instead of 80% fuel cut
              - Still trying to work out my hunting warm idle. I got some advice to turn off the ICV, but that just causes the engine to die (obviously). So I'm not 100% sure where to go with this one. It's running in closed-loop mode right now, I might try changing that to open-loop and seeing if it improves. Otherwise it could be something else??
              • cleanasse30
                • Jan 2014
                • 436
                #592
                Couple of tips that helped me with tuning:
                -Watch this video on accel enrichment. It helped me get rid of my hesitation on tip in completely.
                -On my m20 I run no ICV, and use open loop. To disable the ICV you need to manually open the throttle screw for idle (be careful, mine snapped and I had to use a bolt. Also use locktite and let it gum up if you replace the screw...) Closed loop is harder to get to be stable from what I've read. Open loop will not compare your real time afr to the target afr table and make adjustments, so tuning idle with open loop is a bit easier to get it to be stable. Once you get a stable idle using open loop then you can go mess around getting closed loop dialed in if you feel like it later on.
                Hope that helps. Get that burnout vid up soon! :devil:
                2.7i Stroker Turbo Build Thread
                90 325i | 95 Miata
                • CorvallisBMW
                  • 13039
                  #593
                  I was thinking about doing that (deleting the ICV) as I don't really like the way it looks attached to the m106 intake tube. Also I could use the manifold nipple for reconnect my evap canister, which would be cool.
                  So if I'm understanding correctly, I can run with the ICV in open loop OR remove it and use the screw adjustment also in open loop, yes? Any downside to the screw, like hot vs cold idle speed differences?
                  • cleanasse30
                    • Jan 2014
                    • 436
                    #594
                    Yeah that's correct, you can use the ICV in open loop or disable/remove it entirely and use the screw to adjust idle. Idle speed will vary with engine temp though, mine is a bit low until it warms up. I think mine goes from about 750rpm cold to 1000rpm warm.
                    90 325i | 95 Miata
                    • CorvallisBMW
                      • 13039
                      #595
                      Good news! I passed emissions... After taking out like 30ms of fuel from my idle and leaning it out to ~16 AFR :p
                      Also took the opportunity to "get the cat nice and warm" with a quick trip through wine country
                      • bradnic
                        • Jul 2012
                        • 3554
                        #596
                        YES!!!!!!!!!!!!!!!!!!!!!!!!!
                        way to go
                        can't wait to hear this beast - vid please
                        HOWTOs:
                        DB vert plastic bumpers
                        OEM Keys
                        MTech1 docs
                        88 ix Lach/Card
                        91 ic Calypso 3.1
                        86 Cosmo 2.7
                        OEM+ or bust!
                        • Bearmw
                          • 1323
                          #597
                          Passed the visual. Impressive work.
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            #598
                            and no burn out vids... car looks awesome though
                            • AndrewBird
                              The Mad Scientist
                              • 11898
                              #599
                              No visual in Portland. All they do is test emissions. As long as you pass, they don't care how you got there.
                              • efficient
                                • Feb 2012
                                • 3312
                                #600
                                That sounds so cool. California should adopt that method.
