M30 OEM Turbo project
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    #601
    Did some things. First off was an oil change since my old oil wreaked of gasoline after all the Miller BS and running rich for months. Nice new Mobil 1 15w50.
    Next I pulled and wrinkle-painted the new charge pipe to match the rest of the engine bay. I also wrapped the area closest to the exhaust manifold in exhaust wrap to help keep the temps down.
    Then I decided it was probably a good idea to check the oil bar bolts and do a valve adjustment, since I have literally never done either of those things in as long as I've owned this motor (which is 9 years...)
    All the valves were good, if maybe a little tight. Set to 0.012" now. I also ordered new NGK BP7ES plugs which should be here tomorrow!
    • AndrewBird
      The Mad Scientist
      • 11898
      #602
      Burnout video?
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        #603
        Originally posted by AndrewBird
        Burnout video?
        this....
        1991 318i 4dr slick top
        Mtech 2 turbo restoration
        • CorvallisBMW
          • 13039
          #604
          Burnout video?
          Sure, got some bottlecaps you want to give me? :P
          • CorvallisBMW
            • 13039
            #605
            I finally found an air box that fits! Sort of... It's a 540/740 M62 airbox. Definitely big enough to flow for my engine and the inlet/outlet are in the right locations and the right size. But I still had to do a bit of modification.
            First the bottom had to be cut near the wheel well since I'm installing it roughly 45* rotated from its normal position
            Then I laid down two layers of glass and resin. It doesn't have to be super strong, just hold its shape.
            And installed
            Also, a little teaser.....
            • 2mAn
              SeƱior Mod
              • 20825
              #606
              Looking good! I hope your numbers are high and your intake temps low
              Simon
              Current Cars:
              -1966 Lotus Elan
              -1986 German Car
              -2006 Volkswagen Jetta TDI
              Make R3V Great Again -2020
              • bradnic
                • Jul 2012
                • 3554
                #607
                ^ this
                HOWTOs:
                DB vert plastic bumpers
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                • cleanasse30
                  • Jan 2014
                  • 436
                  #608
                  MMMM dyno time! Who is tuning your car?
                  Also very nice work on the install, it looks very OEM
                  2.7i Stroker Turbo Build Thread
                  90 325i | 95 Miata
                  • ZenitramNaes
                    • Jul 2012
                    • 150
                    #609
                    That box is very nice. Good work on it.
                    Sent from my SM-G920V using Tapatalk
                    '89 535i/5 Holset WH1E turbo
                    Follow my m106 megasquirt build thread: http://forums.bimmerforums.com/forum...Squirt-content
                    • ThatOneEuroE30
                      • Dec 2013
                      • 8626
                      #610
                      If your not gonna do burn out vid at least a dyno vid i cant even deal anymore.... must hear this beast....
                      • Kershaw
                        • 11822
                        #611
                        Is this the turbo prayer?
                        That looks really good and very OEM.
                        AWD > RWD
                        • kamotors
                          • Nov 2007
                          • 7102
                          #612
                          very nice:)
                          7speedshop.com
                          • Bearmw
                            • 1323
                            #613
                            Bear approved.
                            • CorvallisBMW
                              • 13039
                              #614
                              Right, time for goodies! But first, a small disclaimer. We had problems with the factory wastegate as it would not allow any boost levels above ~7psi. I've been doing some research over on the FI section of mye28 and the e23 section of bf.c, and the factory wastegate should be capable of putting out roughly 15psi, which means mine is likely defective. We tried two different manual boost controllers and had the same result. So sadly my boost was limited and I couldn't get to the 10psi goal I had in mind. I'll either need to find another m106 wastegate, find a way to adapt and aftermarket model, or pick up one of the Miller custom pieces.
                              The stock tune that ships with the whodwho MS2 box is damn good. The tuner ended up pulling about 3 degrees of timing out to be safe (there was zero decrease in HP, meaning it was already on the plateau just before knock would have set in) and adding roughly 10% more fuel across the board to get AFRs down around 12.
                              Final numbers were 250whp and 280wtq. This is on a Dyno Dynamics 4WD dyno, totally uncorrected for driveline losses. It's obvious this is old-school turbo tech, look at that lag!! :p
                              Here's the AFR and boost graph. Note the boost peaks around 7.5psi before tapering off to 6psi. All indications point towards a faulty wastegate, likely with a torn diaphragm.
                              I really wish I had a video of a full pull, but since I was assisting the tech with the boost issue, I didn't get one. You'll have to settle for a partial pull :)
                              Sorry, we couldn’t find that page
                              • 2mAn
                                SeƱior Mod
                                • 20825
                                #615
                                not bad for 7psi!
                                Simon
                                Current Cars:
                                -1966 Lotus Elan
                                -1986 German Car
