M30 OEM Turbo project
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    #571
    Anyone else have this problem? My AT TPS sits much "higher" than the MT TPS, due to the larger plug. Even with the hood insulation removed, it presses against the underside of the hood and it made a dent :curse:
    • CorvallisBMW
      • 13039
      #572
      Solved (most) of my MS issues!
      I couldn't get the damn thing to idle, it would just hunt and die. I finally started messing around the the ICV hertz, and eventually found a setting (187Hz I think?) that made it idle. It's a bit high at 900rpm but it's better than 0rpm :)
      I also found out the issue with my tach being dead and TunerStudio not recognizing my AFR signal. When I tapped into the ECU harness to run the AFR signal, I accidently pulled up a wiring diagram for an m42 car , SO I ended up cutting the tach wire and trying to feed the LC2 signal in to it :rofl:. Now that I've corrected that, I have a working tach and working AFR reading. Hooray! Next step: test drive :mrgreen:
      • bradnic
        • Jul 2012
        • 3554
        #573
        that's great! did you end up doing anything with your auto TPS?
        HOWTOs:
        DB vert plastic bumpers
        OEM Keys
        MTech1 docs
        88 ix Lach/Card
        91 ic Calypso 3.1
        86 Cosmo 2.7
        OEM+ or bust!
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          #574
          Oops haha. Gonna need burn out videos..
          1991 318i 4dr slick top
          Mtech 2 turbo restoration
          • kronus
            • Apr 2008
            • 13032
            #575
            btw those plug housings you're missing are like $2.15 each
            cars beep boop
            • bradnic
              • Jul 2012
              • 3554
              #576
              Originally posted by thatoneeuroe30
              oops haha. Gonna need burn out videos..
              +100
              HOWTOs:
              OEM Keys
              MTech1 docs
              88 ix Lach/Card
              91 ic Calypso 3.1
              86 Cosmo 2.7
              OEM+ or bust!
              • CorvallisBMW
                • 13039
                #577
                It works perfectly but still hits the hood. Not sure what I'll do yet.
                Hopefully this weekend!
                Ya I know :sad: When I wired in these HIDs/Euro light slike 7 years ago I didn't realize you could buy them. But since I literally never drive this care in the rain, and that the fugly wires are covered by the black trim panels, I never bothered to fix them. Maybe if I get bored this summer :)
                • bradnic
                  • Jul 2012
                  • 3554
                  #578
                  You're attitude here is simply unacceptable! fix those things :hitler: lol
                  HOWTOs:
                  OEM Keys
                  MTech1 docs
                  88 ix Lach/Card
                  91 ic Calypso 3.1
                  86 Cosmo 2.7
                  OEM+ or bust!
                  • LJ851
                    • 7919
                    #579
                    If i was in your position, i would get the wires coming out of the TPS at a 90 degree angle without the connector and use a 90 degree heat shrink or boot to make it look factory-ish.
                    Lorin
                    The M30 is God's engine.
                    • ThatOneEuroE30
                      • Dec 2013
                      • 8626
                      #580
                      Just wondering what are you using for a motor mounts? Maybe your motor mounts are a little taller raising your engine causing it to hit the hood? Im using the revshift ones with no issues.
                      • CorvallisBMW
                        • 13039
                        #581
                        I have the urethane bushings from... I don't remember who exactly. He's here on the forums and sells them, but his name escapes me at the moment. Probably the best bet is for me to cut off the factory plug and try to install some little 90* connectors of some sort, make an ultra-low-profile plug.
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          #582
                          Those g-man mounts? But yea what you stated will be the easiest fix
                          • CorvallisBMW
                            • 13039
                            #583
                            That's it, G-man The Visionary. Really awesome mounts with zero NVH increase.
                            • car_gal_jenni
                              • Aug 2015
                              • 319
                              #584
                              what an awesome build! i just got done reading the whole thread & this is just intense. i don't think i'll ever do anything quite this crazy with my e30, but i have got to give you props on your thoroughness & oem look!!
                              Current daily: 2003 Mitsubishi Evo (Isabelle)
                              Gone, but never forgotten: 2017 VW Golf R 6sp (Maria, sold)
                              1989 325i 5sp (Lorelei, sold)
                              1991 BMW 318is 5sp (Michaela; totaled)
                              2000 Mitsubishi Eclipse GS 5sp (Selena, parted out)
                              IG: mitsugal_jenni
                              • Bearmw
                                • 1323
                                #585
                                I give you props man. Your M30 swap is unique and well thought out. We all stand to gain from your experiment. I bet it vwill rip.
