86 Delphin m30 Turbo - Now with more turbo!
  • CRBR30
    • Apr 2015
    • 234
    #46
    Great work man. Would love to see that thing boosted
    '89 325i RoyalBlau Metallic - Kylie
    Follow me on IG! @its.christiannn
    • Chinampa
      • Jul 2013
      • 247
      #47
      did u not to start to progress in this build of construct.?
      - 90 325is
      • PimpinWalrus
        • Oct 2013
        • 170
        #48
        I've been slacking on both pictures and progress lately. For the most part the turbo is all hooked up and it starts. Now i just need to get it to stay running. The biggest set back right now is my lack of knowledge of megasquirt and tunerstudio.
        Here's a pic dump of the last 3 months.
        Finally got a wider/stickier wheel setup. XXR 530 16x8 with 245/45/16 Bridgestone Potenza re-11.
        That's it for now. Next step is to get it to the exhaust shop then off to the tuner. Can't wait to drive this
        '86 Delphin 335i turbo -
        '88 Schwarz 325i -
        '94 w124 e420 -
        Turbo m30b35 Build Thread
        • FreedomM3
          • Aug 2015
          • 191
          #49
          What manifold are you using?
          Our RestoMod Diary!
          El Mustache De La Resistance!
          • PimpinWalrus
            • Oct 2013
            • 170
            #50
            Goodntight t4
            Sent from my SM-N920V using Tapatalk
            '88 Schwarz 325i -
            '94 w124 e420 -
            • CorvallisBMW
              Long Schlong Longhammer
              • 13039
              #51
              Nice progress! It's really coming together.
              I'm in the same boat, can't wait to get this MS2 thing running, hit the exhaust shop for some last welds, and then get moving!
              • nomansland92
                • 1657
                #52
                Your center section might be to much of an angle to flow probably. I think the max is like 10 degrees or something with journal bearing atleast. Just something to check out but the build looks wicked and clean!
                IX being restored here
                Ix turbo build here
                • Tougerunner01
                  • Apr 2014
                  • 237
                  #53
                  Good Work
                  I can't wait to see this on the streets!
                  • MMIACSURVIVOR
                    • Sep 2015
                    • 34
                    #54
                    Goodbye headgasket work.
                    • Chinampa
                      • Jul 2013
                      • 247
                      #55
                      where the turbo tho
                      - 90 325is
                      • potatomash
                        • Nov 2014
                        • 203
                        #56
                        How'd you weld your coilovers? Is that max lowww?
                        T U R B O - M 2 0 - B U I L D
                        M U S C C O O
                        • efficient
                          • Feb 2012
                          • 3312
                          #57
                          Bad ass
                          • varg
                            Florida Turbo Man
                            • May 2014
                            • 3425
                            #58
                            Good wheel choice.
                            More updates!
                            IG @turbovarg
                            '91 318is, M20 turbo
                            • PimpinWalrus
                              • Oct 2013
                              • 170
                              #59
                              I don't trust my welds so i sent them to a local shop to weld them up. When i had the 15x7 they were loooooow but with the new wheels it sits at about h&r sport height
                              '88 Schwarz 325i -
                              '94 w124 e420 -
                              • PimpinWalrus
                                • Oct 2013
                                • 170
                                #60
                                Not much in the way of progress in the past couple months but I've got some updates.
                                I picked up some Kamotor flares to give the 245's some more room to work with but the condor offset bushings practically push the tires into the front valance.
                                Started driving it for a while and it began to misfire occasionally. Then it just started getting worse and worse and now bogs horribly under load. AFR sat at about 10.8 at idle... I haven't taken much time to diagnose it but I ordered msd coils for wasted spark so hopefully its ignition related. If not I might actually have to work on this car again
                                In other news, I may be starting another build thread! If everything goes smoothly this will be a comfortable daily driver build.
                                ... this car was supposed to be a comfortable daily driver build
                                '88 Schwarz 325i -
                                '94 w124 e420 -
