Bronzit E30 - OBDII S52 shaved bay - weekend/autox toy - Journey
  • 2mAn
    SeƱior Mod
    • 21038
    #301
    Get the tune. I dont think our cars really need a BBK. Good set of pads, fresh fluid and rotors that arent cracked. Thats the recipe I plan on using to prep for the track day
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • Sh3rpak!ng
      • Jan 2014
      • 2667
      #302
      I'm already on a new set of brembo rotors, stop tech street power pads and fresh quality fluid. The brakes are weak... tough to even engage abs while stomping on them. It's probably mostly due to the 944 booster paired with the oem MC.
      After driving the e36 with the 4 piston bbk on all 4 corners it's a MASSIVE contrast. Granted, I may just need to change the booster/MC and/or change pads, but it's still something I'd like to do.
      Also I'd be lying if I didn't say part of the appeal is for the bling. Plus I already have 2 sets of the modified Corrado rotors :D
      Anyway, I don't think I'd really be able to take advantage of the brakes without the wheel/tire upgrade, or vice versa. So I'll likely go with the tune now, and save for wheels, tires and brakes.
      Sent from my SM-G920T using Tapatalk
      Shadetree30
      • 328ijunkie
        • May 2007
        • 3961
        #303
        I run dtc60s on stock blank rotors at all the tracks in the southeast and dont have any problems stopping, they just get consumed at an alarming rate :)
        Check Us out on Facebook
        Full Product Line Tuning
        • 2mAn
          SeƱior Mod
          • 21038
          #304
          What did you run in the back? Ive been trying to figure out a stock daily setup and the track setup
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          • 328ijunkie
            • May 2007
            • 3961
            #305
            Dtc70
            • Sh3rpak!ng
              • Jan 2014
              • 2667
              #306
              Thanks for the info! I'll keep that in mind!
              Right now, I'm thinking that I'll have the S52 cams out of my E36 reground while it's apart, swap them for the cams in the E30 and get a tune.
              Shadetree30
              • TimKninja
                • 2131
                #307
                You might want to try a new booster first. I just changed my 944 booster out with a different one after the original died. I was having the same problem as you, while the brakes worked fine there was not enough assist. popped in a new booster and now the brakes feel 100% better. Im also running e36 brakes all around. they feel great now.
                1985 325e M50TU(Sold)
                1991 318is Slicktop (Sold)
                1990 325is Brilliantrot S50/5 Lug Swapped.
                1992 525i Manual shitbox Winter Beater
                • Sh3rpak!ng
                  • Jan 2014
                  • 2667
                  #308
                  Yeah I've suspected the booster for a while now. I think I hear it leaking vacuum, but just haven't had a chance to test it. Question is whether to stick with the 944 booster or change to a Clio booster or another more compact option.
                  Also toying with the idea of relocating the ABS unit.
                  Shadetree30
                  • 328ijunkie
                    • May 2007
                    • 3961
                    #309
                    we use v8 boosters on all our swaps. Work amazing and clear manifold just fine.
                    • Sh3rpak!ng
                      • Jan 2014
                      • 2667
                      #310
                      Which boosters are those?
                      Shadetree30
                      • wilholl
                        • May 2012
                        • 518
                        #311
                        Yes... Do tell!
                        1988 325 non-letter Seta "Bronzit"
                        1991 325ic "Laguna Green" (Sold)
                        1993 325i "Laguna Green/Silver" (Sold)
                        1998 528i "Artic Silver" m-sport(totalled by drunk driver)
                        2000 528i Titansilber/gray m-sport
                        2000 528i Titansilber/black m-sport(sold)
                        2001 525i Anthracite m-sport(sold)
                        2013 750i Black/Black m-sport "Beast"
                        • ST1G
                          • Oct 2012
                          • 6689
                          #312
                          They are e32 break boosters, with a remote reservoir.
                          Just read through your whole thread, superb work mate. Good read.
                          • 328ijunkie
                            • May 2007
                            • 3961
                            #313
                            We use E34 V8 booster/MC setups with direct res mount. No dealing with remote res BS.
                            • Sh3rpak!ng
                              • Jan 2014
                              • 2667
                              #314
                              Gotcha, it just threw me off that he said "v8 booster" - kinda sounded like there was some other option
                              Thanks man!
                              Thanks. First I need to check if my booster is leaking (pretty sure it is), and then decide if I want to go with a different option. That looks pretty tight though.
                              Any experience with the clio booster?
                              Shadetree30
                              • Sh3rpak!ng
                                • Jan 2014
                                • 2667
                                #315
                                Anyone run into this issue? The new OEM replacemen brake switch is too short. On the left is an e36 switch (which also works in the e30 btw - you just put the e30 plug into one side of it), middle is the new e30 switch, right is a "new" e30 switch of some unknown aftermarket brand.
                                I wound up wrapping the pedal with electrical tape at the spot where the switch contacts to build the surface up and make up for the height difference. I got 2 switches (one for a spare) and both were the same.
                                Shadetree30
