Bronzit E30 - OBDII S52 shaved bay - weekend/autox toy - Journey
  • Sh3rpak!ng
    • Jan 2014
    • 2667
    #121
    Originally posted by XwalkerX
    nice. im actually taking my car to get AC put in this week too lol.
    Yea, I decided to wait on it after the swap to let my wallet recover a bit. I figured I would wait until it got hot. Well, it got hot. It also got very uncomfortable.
    Let me know how your AC install goes. I'll do all of the install and wiring, but I'm on the fence whether or not to take it to a pro to get it filled. I'll need to visit a shop at least to get the lines modified.
    Shadetree30
    • pandaboo911
      • 2070
      #122
      I'm doing AC also since Cali summers are unbearable without it. I've got everything installed, just need a shop to crimp my lines and fill it up
      • MatRacer
        • 562
        #123
        What did you used to do the white lettering?
        E30 now S52
        2008 Suburban LTZ (Family and TT hauler)
        325xiT (Sold)
        • Sh3rpak!ng
          • Jan 2014
          • 2667
          #124
          Yea, it's a must on at least one car. Any idea what it costs to have AC flushed and filled these days?
          I used a white sharpie paint pen from home depot. I tested it on one wheel. It held up very well over 2 months of abuse: rain, dirt, autox, mud etc. The trick is to make sure the surface is perfectly clean. I wiped it with brake cleaner until the rag came up clean.
          Shadetree30
          • MatRacer
            • 562
            #125
            Thanks for the fast answer!
            Very nice build!
            I like your Bronzit a lot! maybe because I own one also...!
            E30 now S52
            325xiT (Sold)
            • Sh3rpak!ng
              • Jan 2014
              • 2667
              #126
              Very nice build!
              tapatalk helps ;)
              Thank you! I never liked bronzit prior to owning this car. I still didn't like it until I installed the coilovers and wheels. The headlights improved it further. I bet after I get the window tint redone, paint all the window trim black, get new grills, euro trim, rear euro plate filler, and lightly smoke the taillights it will look KILLER. Bronzit isn't bad when you do it right!!!
              Do you have a build thread?
              Shadetree30
              • Sh3rpak!ng
                • Jan 2014
                • 2667
                #127
                So the motor started to make some ticking noises a couple of days ago. It sounds like one lifter ticking intermittently. Then it became a little more pronounced and sounded like another lifter joined the orchestra, again intermittently. So I changed the oil (needed it anyway). Forgot what was in it before, either the 0w-30 or 0w-40 european formula castrol.
                Anyway, I filled it with 7 quarts of 0w-40 european formula castrol. We'll see if that changes anything. Also got an automotive stethoscope to help pinpoint it.
                This is what the magnetic oil drain bolt looked like after removal
                Shadetree30
                • MatRacer
                  • 562
                  #128
                  Originally posted by Sh3rpak!ng
                  tapatalk helps ;)
                  Yeah, me to, at first, really didn't like it, but it's start to grow on me! Yeah really like the smoked headlights... You pretty much described what I'm aiming for... with a few variants ;)
                  Yeah, I do have a build thread; I started it this week and its more a overview of my e30 story... will try to update it with more details.
                  E30 now S52
                  325xiT (Sold)
                  • Sh3rpak!ng
                    • Jan 2014
                    • 2667
                    #129
                    Full set of AC lines from an e30 and e36. Still debating whether or not to have a shop just make a full set of flexible custom lines so I can hide them behind the fender, or just adapt the small portions of the e36/e30 lines
                    All new premium oem hardware minus the condenser (arriving today via amazon)
                    Couple other odds and ends "while you're in there"
                    new vanos line (mine is leaking), power steering pump rebuild kit, 80c whaler thermostat
                    Shadetree30
                    • Sh3rpak!ng
                      • Jan 2014
                      • 2667
                      #130
                      http://www.r3vlimited.com/board/showthread.php?t=359473
                      What variants do you have in mind?
                      I'll check it out! Support the bronzit!!!
                      Shadetree30
                      • pandaboo911
                        • 2070
                        #131
                        Bronzit E30 - OBDII S52 rebuild + goodies swap - DD / autox Journey
                        Looks like you got the e36 m3 compressor -> condenser AC line. The one with the black end that bends down will be hard to use. Since the e30 line goes over the compressor instead of under like the e36.
                        Also what does the pump rebuild kit include? Mine is totally broken from boiling the fluid.
                        • Sh3rpak!ng
                          • Jan 2014
                          • 2667
                          #132
                          yea, I saved all the lines from when I took it out of my e36 ages ago. I noticed that too. Would that still be an issue after it's been adapted to fit the e30 fittings?
                          pump rebuild kit includes the main shaft seal, and a bunch of other gaskets/seals p/n 32 41 1 135 880
                          Shadetree30
                          • Sh3rpak!ng
                            • Jan 2014
                            • 2667
                            #133
                            The koyorad 48mm radiator started to leak at the end tanks. FRsport was quick to replace it free of charge. I have a new one waiting to install. I know others have used these without issue.
                            Passenger engine side was where it leaked the worst.
                            Driver engine side showed beginning signs of leakage.
                            Front passenger side leakage
                            APDI parallel flow condenser
                            This is to show how much space is still available WITH a/c condenser and a spal fan. Hard to tell, but I still have at least an inch clearance between the front of the fan and the bumper. I am running the 30101517 spal, pusher, 2.48" deep, 1610 cfm, with a rubber gasket between the fan and condenser. The next fan size up (3.39" deep would probably be tight, but I bet it could fit)
                            Fan mounted to the condenser.
                            Backside.
                            I used these zip tie thingys. I had them on hand, and I didn't see a simple way to bolt the fan somehow somewhere.
                            My "to do" / reminder board. It needs some updating/cleaning. But I've been doing well. The e30 side was erased and filled once already
                            Shadetree30
                            • 2mAn
                              SeƱior Mod
                              • 21035
                              #134
                              Damn, that radiator leaked?? Ugh...
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              Make R3V Great Again -2020
                              • Sh3rpak!ng
                                • Jan 2014
                                • 2667
                                #135
                                Yuppers.
                                Hopefully the replacement doesn't
                                Shadetree30
