'70 2002 widebody & M10 turbo project
  • 2mAn
    Señior Mod
    • 20920
    #61
    Not sure if anyone else felt the heat wave but middle eastern people battle heat with heat. Some Turkish coffee and wafers
    Then we work. Copper spray on the MLS headgasket.
    Had to realign the rocker shaft arms but eventually got the head on.
    After this we started looking for the nuts and washers but they weren't to be found. We blamed the heat and called it a day...
    Went inside and ordered some other parts instead. I'll be back there in August and should have more heat but less distractions so hopefully the engine will be assembled and ready to drop in. Meanwhile, I'm getting him ready for a big purchase from Ireland engineering.
    Until then, stay cool
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • Sh3rpak!ng
      • Jan 2014
      • 2667
      #62
      Sick build! At first I thought you bought an '02 I was like whatttttttttt no way...
      but even better, building a sick car and spending none of your own money :P
      Shadetree30
      • kid325e
        • Sep 2007
        • 6422
        #63
        Nice update! Can't wait for the next.
        clutchCTRL!
        Move with a purpose.
        - 1991 325iX 4dr/5spd
        - 2000 323i AT
        2016 Mazda CX3 Sport AWD
        • AdOz
          • Jun 2015
          • 114
          #64
          Loving seeing that engine come together! This is epic! Keep up the good work!
          TURB'02
          INSTAGRAM
          • indecline
            • Sep 2007
            • 244
            #65
            Super Sweet
            1989 325I(M20B25US)|KAMotors CAI|Bilstein Sports|H&R Sports|ST Sways|SSSquid Tune|Red46 Sump Armor|
            • obes
              • Apr 2012
              • 1156
              #66
              super wet
              -1986 S50Turbo Sedan (475WHP/417WTQ) Castromotorsport Built (Sold)
              -1987 Coupe (17x10.5"/17x14")
              Castromotorsport / Buddha_Concept_designs Built *UnderConstruction*
              Follow me on Instagram: obes_sebo
              For more updates:)
              Purchase FeedBack http://www.r3vlimited.com/board/showthread.php?t=278838
              • 2mAn
                Señior Mod
                • 20920
                #67
                Originally posted by indecline
                Super Sweet
                Originally posted by obes
                super wet
                thanks everyone. We're both pretty excited to see it come together.
                As usual, we made some progress and hit some hiccups, but thats why its called a project.
                Good news is that we found we the nuts and washers for the ARP stuff. Was pretty nervous we lost them. Unfortunately I didnt bring my torque wrench with me so we couldnt torque the head down, but its ready to do on my next trip.
                cylinderhead3_zpsss0sy5at by 2mAn
                Last time, we placed a small order to get a few odds & ends. Still need to make that big purchase with Ireland, which Im hoping to get done very soon.
                goodies_zpsoc4yorgb by 2mAn
                Heres a comparison of the old water pump bolts and the new ones that were included with the 02again trigger bracker
                bolts_zpsfgx9cb4d by 2mAn
                And heres a pic of the spacer installed. We needed this piece because the way the turbo mounts to the manifold, it was hitting the valve cover. I eyeballed and guessed we needed another inch. Luckily it was enough
                spacer_installed_zps6wxlee66 by 2mAn
                The spacer worked perfect as we got the clearance over the valve cover we needed, but I discovered another problem. No idea how we can get the 4th nut & bolt to hold the turbo to the manifold.
                problem_zpsjholwupc by 2mAn
                Heres how it all looks somewhat completed
                almost_done_engine1_zpsigl9en2z by 2mAn
                another angle
                almost_done_engine2_zpsf5at9g4f by 2mAn
                and finally, the painted engine bay eagerly waiting for the motor
                enginebay_painted_zps6sn8o3fn by 2mAn
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • iwantspeed
                  • 3164
                  #68
                  nice work Simon.
                  Can you install the 4th bolt in the opposite direction?
                  lower the turbo assembly with the bolt already on, and lower that onto the spacer setup?
                  like this?
                  or is there not enough room to install a bolt from above?
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
                  • iXguido
                    • Nov 2009
                    • 730
                    #69
                    ^The bolt would be too long to drop in from above.
                    Use a piece of threaded rod long enough to use a nut on each end. put it in the hole then drop on the turbo and put a nut and (lock) washer on each end. Problem solved!
                    • ThatOneEuroE30
                      • Dec 2013
                      • 8626
                      #70
                      lookin good man
                      1991 318i 4dr slick top
                      Mtech 2 turbo restoration
                      • 2mAn
                        Señior Mod
                        • 20920
                        #71
                        Genius! One of my favorite things about forums. Thanks for the idea.
                        Problem solved indeed!
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        • iXguido
                          • Nov 2009
                          • 730
                          #72
                          Glad to help, project looks like it's coming along great!
                          • kid325e
                            • Sep 2007
                            • 6422
                            #73
                            Any updates? Simon, I need the motivation! Hope all is well with you bud.
                            clutchCTRL!
                            - 2000 323i AT
                            • 2mAn
                              Señior Mod
                              • 20920
                              #74
                              Nothing yet, I might be able to get some work done this weekend. We still need to place that big order with Ireland. I keep forgetting to bug him about it. It would be easier if I had his credit card... but probably more dangerous too haha
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              • 2mAn
                                Señior Mod
                                • 20920
                                #75
                                SUCCESS!! No time for anything else but we got this done.
                                I'm not the smartest when it comes to turbo but I think this Wastegate is welded shut, so we can remove it and we'll need an external, yes?
                                edit: deleted giant pic thats very similar to the pic of the welded wastegate above
                                Also, is there a place that I can buy the flange so we can start the downpipe? And is there a gasket that needs to go between the turbo? Newbie turbo questions, go easy on me
                                And we celebrate with some drank, Assyrian style
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
