e30 323i N54 teaser
  • ahrensNW
    • Mar 2015
    • 1716
    #91
    I can not wait to see this car completed.
    Hank Ahrens
    1984 Alpine Coupe
    1978 911sc
    • j4jo
      • Jan 2016
      • 21
      #92
      Originally posted by nando
      There is no ews delete. There is an ews4 emulator that might work, but otherwise you have to do it the same way as the imitator. That mean full harness swap and all neccesary modules.
      Deleting dtcs is easy, you just zero out the type code (requires a dme flash). But your first and main problem is getting around EWS.
      Nando, can you please tell me more about this ews4 emulator ...
      Thanks
      • the imitator
        • May 2013
        • 1006
        #93
        Thanks
        Go for it Nando, I think me and you may share similar thoughts here though..
        The proper ways to go about this is with either a true EWS bypass/delete; Or
        Use the OEM harness. When an ews solution is found, it will definitely save you a few hours of time with wiring, and you dont have to tear apart your dash to install the OEM wiring and modules.
        I like the OEM body harness because I plan to use the abs/dsc, also not to forget about are the wheel sensors, and stuff for creature comforts..
        Different goals, different paths, which is awesome.
          • 34847
          #94
          I might have a way to do it on ews4, but you still need the emulator. It basically acts like a cas that doesnt need a key or anything else. But you need a way to read the isn and secret key.
          A software delete means full program disassembly - not a light task...
          • j4jo
            • Jan 2016
            • 21
            #95
            This sounds great since I dont have intention to install the OEM wiring. Only get the engine runing, upgrade brakes, stearing and supension.
            @imitator ineed different ways are always good ;)... when build will start I will open new thread to show progress
            @nando can you please provide me some links where to buy everything... if that is not a secret and explain what exactly needs to be done so that I can talk with my mechanic and car electrician friend. If this wont work than only way is to wait for EWS delete for this engine like we did it for s54...
            Thanks
            • 808AWD325xi
              • Sep 2007
              • 359
              #96
              Sub'd. Hope your project gets off the ground. Using the OEM wiring harness is the right way to start. It will be a lot easier to reduce the number of modules once they have been coded out. CAS and FRM store the vehicle order (FA) which is key to coding out unnecesasary modules, I doub't you will want to get rid of either.
              Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms/OFT
              • Yellow13
                • Mar 2014
                • 12
                #97
                Sub'd to this as I am almost done doing my E30/S62 Swap. I am staying 100% CANbus and I have a good idea of what I need and don't need. I am interested in how you wire everything up. I understand though, these are two different CAN systems but they work virtually the same.
                SO MANY WIRES!!
                  • 34847
                  #98
                  S62 should be cake. the only real CAN connections are to the DSC system and the instrument cluster. but you really don't need either of those on an S62..
                  • the imitator
                    • May 2013
                    • 1006
                    #99
                    Thanks
                    I hope you guys can team together and find a way to tackle an EWS delete.
                    Here's some information straight out Rheingold Regarding the EWS4, and how it works. I surely wish I had this program sooner, there's a lot more than just the EWS in regards to a delete.
                    This section is the same for every E9X model, seems like there is a bit more work to be done, than initially thought. Latest reviews on Emulators show hit or miss on bricking the FRM.
                    The electronic immobiliser (EWS) of BMW vehicles is integrated in the CAS/FEM/BDC.
                    Function:
                    Data transfer between CAS/FEM/BDC and engine control unit
                    CAS/FEM/BDC interface to the engine control unit:
                    A secret key, protected against manipulation, is stored in the CAS/FEM/BDC control unit and in the engine control unit.
                    From this point onwards, engine control units and CAS/FEM/BDC control units can only be replaced with control units specifically ordered for each vehicle. An EWS adjustment in the vehicle is not possible.
                    Important
                    Trial exchange of the engine control units and the CAS/FEM/BDC control units is not possible!
                    Key identification and starting operation:
                    The following procedure takes place after identification of the vehicle key:
                    - The vehicle key transmits the key data to the CAS/FEM/BDC control unit.
                    - The CAS/FEM/BDC control unit checks the correctness of the key data and only then enables activation of the starter motor by the engine control unit.
                    - The engine control unit calculates a request from a random number and the secret key. The engine control unit transmits this request to the CAS/FEM/BDC.
                    - The CAS/FEM/BDC uses the request and the secret key to calculate the confirmation. The confirmation is transmitted from the CAS/FEM/BDC to the engine control unit.
                    - The engine control unit itself also calculates the confirmation that the CAS/FEM/BDC expects. The engine control unit then checks that the confirmation it receives from the CAS/FEM/BDC matches the confirmation it has calculated itself.
                    - If the confirmations match, the engine start is enabled.
                    Fault recognition in engine control unit
                    The following faults are monitored in the engine control unit:
                    - The engine control unit monitors both the signal transmission and the signals themselves.
                    Engine start is blocked if a fault is detected.
                    I have to agree, I'm quite confident the hiccups should be minimal now that I have ISTA-P, and Rheingold to answer my questions without any doubt; It also has plenty of information regarding EWS 4 on all models, and has really helped me out regarding some doubts.
                    SO MANY WIRES!!
                    I agree with the amount of wires, though! At first you sort of think "is this worth it?" for me about 15 minutes into it I was like "hell ya it is!"
                    Everything was easy to identify after it was spread out..
                    As Nando said you should have an easier time if you're looking for a delete of some sort, or looking to sort wires.
                    Totally agree.
                    • SLEEPYDUB
                      • 658
                      #100
                      Any updates? Anyone have any fitment pics? Any 6speed Trans mount pics or engine mounts, hard parts?
                      Imitator do you think a single turbo manifold would fit easier than stock twins?
                      Sent from my SAMSUNG-SM-G900A using Tapatalk
                      - AXIS POWERS - 2JZ E30 Build
                      Current Project - 87 325is 2JZ Swapped with M4 DCT
                      • the imitator
                        • May 2013
                        • 1006
                        #101
                        Yes, update coming soon.
                        PM'd Sleepy, I do think a top mount single turbo manifold will have better fitment, With stock twins the fitment is questionable, and I know you wont be able to fit bigger twins in there.
                        • bobaflesh
                          • Mar 2016
                          • 69
                          #102
                          Can't wait to see the complete car, subscribed!
                          • the imitator
                            • May 2013
                            • 1006
                            #103
                            Sorry for the slight delay folks, I'm an insurance adjuster for Homeowners, and the Dallas/Plano area was hit quite hard, I'll be returning home mid April. Then I must relocate my swap as I have moved from the currently location in resides.
                            That's pretty much the bad news, just some more delays due to work and relocation.
                            Good news:
                            Relocating to a bigger garage with better lighting, in the country, with drill presses, oxy torch etc, but still using basic tools.
                            Back to the swap for just a few seconds here..
                            This is an obvious... although it appears at this point the arc asylum S54 subframe will clear the stock oil pan given a massage of the firewall, similar to that of an m30 swap; The downpipes pose an issue if we are talking about STOCK fitment.
                            Choices are pushing your firewall in similar to what HakenTT has documented, go single turbo, or make a new product involving stock fitment to move us forward into new generation swap.
                            • DesertBMW
                              • Aug 2011
                              • 1043
                              #104
                              I finished my N55 to E36 project, so here are some details, maybe it helps you
                              N55 + 6HP21 rules. This engine will become more popular than S54. My car:
                              Video:
                              • SLEEPYDUB
                                • 658
                                #105
                                How difficult was the n54 swap into the e36?
