#BecauseRaceCar Story and Build - M60 6-spd
  • ncrmtrsprtsE30
    • May 2015
    • 204
    #31
    Originally posted by ian e30 318is
    Hmmm sputtering sounds like a possible fuel pump?? Maybe try tapping on the top of the pump with a screwdriver when you hear it start to die. If it kicks back to life, there is your culprit. Any check engine light? With no light, I would find it hard to believe it's the DME, MAF, O2 sensor, etc., but I could be wrong. (Fault codes here: http://www.e30zone.net/e30zonewiki/i...ic_Fault_Codes) Good luck finding the issue. I hate the gremlins...I've been there man and I feel your pain.
    Side topic: I am local so we should definitely meet up sometime. You ever attend any local meets?
    I dont think its the fuel pump.. its getting fuel, it back fires like crazy.. unless fuel injector timing is off?
    no check engine light - 1987
    no i havent been to any of the meets yet, was gonna reveal the car when it was done.. lol
    The "Because Race Car" M60 V8 Build Thread
    On Instagram Straight Flexin' #BecauseRaceCar
    • ncrmtrsprtsE30
      • May 2015
      • 204
      #32
      Videos:
      Session 2 -
      Session 3 -
      • Jb325is
        • 2137
        #33
        Doesn't sound like too big of an issue. Check cap and rotor, crank sensor, coil. I didn't watch the video, just going off of your description
        Oh and the aero on that miata is a bit ridiculous and I seriously doubt it's doing much. I would be willing to bet it is slower than most spec miata's even with all of that
        - '88 m54 coupe
        <3
        • ncrmtrsprtsE30
          • May 2015
          • 204
          #34
          This morning I try to start it, it fires up right away and after about 5 seconds its dies.. does this about 3 times.. now it wont start at all, and i have a very strong odor of fuel..
          Tried my spare ECU = nothing
          Got a new coil = nothing
          now its getting no spark at all from the coil.. im about to pull this motor.. lol
          we will find out about the miata aero next month
          • Jb325is
            • 2137
            #35
            That sounds like fuel then. I don't know about early cars but is there any wiring you need to do when eliminating the dual pumps?
            Do some diagnosing before you go and pull the motor, seat time will make you a hell of a lot faster than a motor swap/turbo/20lbs of aluminum riveted to the back of your car at this point. I've made this mistake in the past and still regret it. The setup you have now should be pretty solid.
            I would recommend getting some camber plates, and some adjustment in the rear if you don't already have it. Also, with the weight reduction, be careful pulling all that weight off the back of the car, you kind of need it back there. Have you scaled and corner balanced the car yet?
            That Miata is just a huge facepalm
            - '88 m54 coupe
            <3
            • ncrmtrsprtsE30
              • May 2015
              • 204
              #36
              No I have already run the pump for a full track day with no problem.. and how is it fuel when I can smell fuel in the exhaust when cranking.. pulled the plugs and they are soaked in fuel.. i have no spark at all though..
              the motor i have now is very tired, i can feel it, and its a 2.7L, so not a lot of revs and not a lot of power..
              I am waiting on the suspension after I get my engine situation dialed in.. I was already planning to swap, but just not this early, i was hoping to finish the season..
              • Jb325is
                • 2137
                #37
                Check the crank sensor then. There is a great post somewhere by jlevie for troubleshooting no starts
                - '88 m54 coupe
                <3
                • stonea
                  • 2892
                  #38
                  Wow!!! Great build and great tittle! Hope you get it fixed soon!
                  My Garage
                  Feedback
                  Instagram: Stone.Hopkins
                  • kts
                    • Jun 2010
                    • 753
                    #39
                    http://spece30.com/forum/41-electric...-stumped#53139
                    +1 to checking the crank sensor. What you had happen to you sounds a lot like what happened to my E36 when my crank sensor started going. Replaced the crank sensor and all was well again.
                    Bentley should have the specs in it so you can test your existing sensor with a voltmeter to see if that's the culprit.
                    Sorry to hear the car is giving you trouble, but much better it's an electrical gremlin like this than the car is totally dead.
                    • FubarE28
                      • May 2015
                      • 15
                      #40
                      You getting power to the coil? Is there a ignition relay?
                      • ncrmtrsprtsE30
                        • May 2015
                        • 204
                        #41
                        Yeah that could possibly be the problem there.. It could be super glitchy and going out.. but it still doesnt make sense that it can idle fine when i was at the track, but sputter sometimes..
                        I have an extra crank sensor too.. because before when it wasnt starting I thought it was that, but checked it with a voltmeter and it was all good (it happened to be a spliced wire that was on an aftermarket alarm system)
                        I checked the resistance of the primary on the coil and it was a dead zero resistance.... and the secondary was 5,750 ohms.. i think the primary coil is gone..
                        Does someone want to come fix it? lol
                        • Sh3rpak!ng
                          • Jan 2014
                          • 2667
                          #42
                          What was the problem with the bassett wheels?
                          I noted them a while back as a potential option for track/autox wheels. Seeing your comment makes me wonder if there is a reason I should take them off the list.
                          Shadetree30
                          • RustyEuro
                            • May 2014
                            • 110
                            #43
                            I'm digging this build honestly
                            It makes me want to build myself a track car out of my eta
                            and I'm subbed for this progress.
                            89' 325i DD/project
                            86 325e rust bucket/future race car
                            "Just because you go fast in a straight line doesn't mean you go fast in corners"
                            • 2mAn
                              SeƱior Mod
                              • 21024
                              #44
                              Can you post links to the spoiler and VGs?
                              I hope to see this thing one day in person.
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              Make R3V Great Again -2020
                              • ncrmtrsprtsE30
                                • May 2015
                                • 204
                                #45
                                for one they are lug centric ONLY wheels.. so all the strain goes on the lug studs/bolts.. they actually ending up damaging my studs on the front..
                                also finding a shop to balance them is a pain..
                                they are fucking heavy, the wheel alone weighs more than my wheel/tire setup now..
                                but they are cheap..
                                BUT you can also find cheap wheel knock-offs that dont weigh a ton and are decent.. I got my Miro wheels for $260 for all 4, in a 15x8 that only weigh 13lbs each.. compared to the bassett 15x7 weighing in at whopping ~25lbs
                                The ducktail spoiler is actually for a S13 240sx coupe from fleebay, I wasnt sure it was going to fit the trunk so i got the cheapest one i could find.. and it ended up fitting the e30 trunk line perfectly with a small amount of filing and trimming the extra piece in the back.. :up: LINK TO SPOILER
                                VGs are also from fleebay.. but the delta wing shaped VGs are better than bump shaped.. LINK TO VG
