#BecauseRaceCar Story and Build - M60 6-spd
  • semaj4712
    • Mar 2012
    • 3069
    #106
    Awesome build man, just when I get skeptical of something you say your going to do you knock it outa the park
    29 Model A // 55 GMC 100 // 66 C10 // 72 BMW 2002 2.7 M20 Turbo // 75 CB500T Custom // 04 BMW M3 // 13 BMW 328i Sport
    72 BMW 2002 2.7 M20 Turbo Build Thread // INSTAGRAM
    Gewerkschaft der Polizei Sticker/Clings For Sale $8
    • Staszek
      • 2533
      #107
      Originally posted by ncrmtrsprtsE30
      its the M60b40.. it wasnt exactly what i wanted..
      i did want the m62b44 but i couldnt pass this deal for this 740i for $300 running and driving LOL.
      Holy crap $300!!! You can sell two parts off that car and make that back!
      I'm trying to think if I need anything for mine lol
      • ncrmtrsprtsE30
        • May 2015
        • 204
        #108
        Let me know soon! i might be junking it!!
        Thanks man!
        The "Because Race Car" M60 V8 Build Thread
        On Instagram Straight Flexin' #BecauseRaceCar
        • staysideways
          • Dec 2013
          • 373
          #109
          UPDATE:
          She's running, and better than ever.
          I go to check my fuel today..
          I have fuel pump going, injector are getting pulsing.. so i pull a fuel line and to my suprise there is no fuel pressure in the line..
          i jump the FP relay terminals and I test the pressure and flow.. it has flow but very low pressure.. and after i turn it off it doesnt even hold pressure, within a couple seconds its zero pressure...
          So i get into the fuel tank and while running the pump look inside through the level sender hole.. and there is a lot of fuel moving around in there.. so I remove the whole fuel unit and...
          what do you know, I guess the hose i used could not handle being in the fuel.. replaced it with one that is specifically for fuel only.. and put it back in the tank.. a couple cranks and she fires up running smoothly.. let it warm up and go take it for a spin, and it has more power and throttle response than before.. i was getting sideways in 2nd gear! (prob because I cleaned the AFM and adjusted the TPS and cleaned out the throttle body..lol)
          Video of her back from the dead
          So now look forward to more Race Car updates!
          Sorry to bump this post but were your symptoms like stalling and idling really rough?
          1989 E30 325i Sedan Alpine
          • ncrmtrsprtsE30
            • May 2015
            • 204
            #110
            stalling when pressing throttle..
            and a weird idle.. sometimes rough.. sometimes smooth..
            under load it would totally stall out and misfire..
            • staysideways
              • Dec 2013
              • 373
              #111
              Yea my cars doing the same but it has 40 psi fuel pressure no vacuum leaks but 13 psi going towards the fuel pressure regulator
              • ncrmtrsprtsE30
                • May 2015
                • 204
                #112
                maybe a leaky injector?
                • ncrmtrsprtsE30
                  • May 2015
                  • 204
                  #113
                  Tear Down of the M60
                  Tearing down the m60.. not too many surprises, which is good..
                  - Intake manifold complete gunked up, so will have to clean that all up
                  - One of the cam chain tensions has failed, causing slack and noise when running
                  - removed the lower oil pan and no bolts in there, good so far! but when i removed the oil pump chain cover a bolt fell out of there that was all chewed up. Appears to be rubbing against the chain, but the chain was ok, just loose. The bolt that wiggled itself loose was the one that locked in the tensioner.
                  - I will be replacing all the gaskets, seals, and timing chain tensioner.
                  6-SPEED in the house!
                  and IF ANYONE has a trick to get this jesus bolt off while on the engine stand, that'd be great... other wise i gotta do it by the book and wait until i have it mounted in the car.... which i would rather not do..
                  • LoneWolf
                    • 402
                    #114
                    ^ a good impact driver. Used a 1/2" drive Milwaukee to get it out. had tried breaker bars and holding the engine up with a hoist, plus making a flange that fit those outer smaller holes with a long piece of angle, to stop me turning the bolt from turning over the engine. None of that worked, 10 seconds with the big impact and an impact socket, it was done. Don't reuse the old one once it's out.
                    • James
                      • Oct 2004
                      • 335
                      #115
                      X2 on a good impact. Cool build
                      • ncrmtrsprtsE30
                        • May 2015
                        • 204
                        #116
                        i tried that, i might need a stronger impact though, ill have to borrow one from work and ill try to soak in wd40 for a couple days.
                        • LoneWolf
                          • 402
                          #117
                          Yeah most impacts only do around 300-400 ft/lbs. the one I used pounded at 400 then ramped up after a few hits to 700. And had a higher setting of 1100. It was a beast. I think we just kept it on low and let it hit a few times.
                          • staysideways
                            • Dec 2013
                            • 373
                            #118
                            All you need is an ingersoll rand impact and a compressor
                            • JGood
                              • Jan 2004
                              • 7959
                              #119
                              With my m62, I tried a 700 ft lbs 1/2" impact on 150psi, with lots of heat, hammered on it for probably 30 minutes, taking breaks to refill my 60 gal compressor. Didn't budge. My m60's bolt came off after about 5 seconds with the same impact.
                              Had to do this, which mathematically gave me 900 ft lbs of leverage with my body weight, but I had to jump on the 6' bar, so who knows what peak I actually had to hit to break the bolt loose...
                              I was most impressed that my $15 Duralast brand breaker bar from AutoZone took the abuse...
                              e30 restoration and V8 swap
                              24 Hours of Lemons e30 build
                              • ncrmtrsprtsE30
                                • May 2015
                                • 204
                                #120
                                Thanks for the input guys! I got it off tonight! borrowed one of the 500ftlbs impacts from work and in about 30 seconds of gunning it, it came off smooth!
                                Its now time to for new seals and gaskets and some paint.. ;D
