Matracer's project: BRONZIT S52 - DYNO RESULTS P.8
  • MatRacer
    • 562
    Somme more cleaning!
    Since I'm converting an obd2 engine to obd1, I need to adapt the coolant hose of the obd1 engine to to the obd2 one. My s50 timing cover is broken so I managed to remove te little adapter...!
    From here
    To go there
    Also started the e34 oil pan cleaning!
    The one on the s50 was also broken...
    First degreasing
    That's it for now
    E30 now S52
    2008 Suburban LTZ (Family and TT hauler)
    325xiT (Sold)
    • MatRacer
      • 562
      checked my post on my pc... Tapatalk upload way too big pics!!
      E30 now S52
      325xiT (Sold)
      • efficient
        • Feb 2012
        • 3312
        Pics look fine to me and I'm on mobile. Keep the updates coming
        • MatRacer
          • 562
          Progress on the pan!
          E30 now S52
          325xiT (Sold)
          • Sh3rpak!ng
            • Jan 2014
            • 2667
            +1 nice work!
            Sent from my SM-G920T using Tapatalk
            Shadetree30
            • kingston
              • Jun 2010
              • 2669
              Keep it coming, man!!
              Originally posted by LJ851
              kingston is the play by play announcer for this thread.
              ‘Tis by the grace of God that my cars run!
              Originally posted by unloadedak
              #teamross
              Siobhan's Build Thread - UPDATED!
              • 2mAn
                Señior Mod
                • 21011
                bummer about the engine explosion....
                Im curious why that shop said the aluminum block wasnt a good idea for the track? Was it the block PLUS the M54 internals or are they paranoid about just the block itself??
                I was paranoid about the harmonics because I was initially going to use a S52 crank as well, but thought I should stay with the 2.8 because its a balanced 84mm crank and 84mm stroke.
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • MatRacer
                  • 562
                  If I remember correctly, they talked about the thermal capacity of the block and their experience with race engine. There was a class where they were running a 330 e46 and they had to keep the "stock" engine and they were limited to 300hp. I think they ran into many problems with that engine... but dont quote me on that. I talked to thwm like 6 months ago...
                  E30 now S52
                  325xiT (Sold)
                  • MatRacer
                    • 562
                    About to paint!
                    E30 now S52
                    325xiT (Sold)
                    • Cephas
                      • Apr 2012
                      • 878
                      The engine pic. Ouch! Keep after it!
                      • MatRacer
                        • 562
                        Just dropped the pan to replace the oil pump, secure the nut, pan...etc. while there I removed the baffle and look into the cylinder from the bottom end and rotated the engine. I definitely hear air coming out of the cylinder between piston and cylinder. It's leaking by the rings... the engine has been sitting for 2 years... hard to do a compression test with engine out... video will come.
                        Is it normal?
                        E30 now S52
                        325xiT (Sold)
                        • MatRacer
                          • 562
                          E30 now S52
                          325xiT (Sold)
                          • spiDmang
                            • 3941
                            damn, that block carnage is nutty! but cant wait to see the progress!
                            91' 318iS - S54/6MT Swapped
                            08' E90 M3 6MT - Daily
                            Originally posted by IronJoe
                            Originally posted by 2mAn
                            • MatRacer
                              • 562
                              Yeah... pretty bad! Bent a rod during cranking because of a leaking injector... didn't notice... 2 weeks later broken Rod on the "local" track... same cylinder than the one that had hydraulocked. ..
                              E30 now S52
                              325xiT (Sold)
                              • MatRacer
                                • 562
                                Now on the good things!
                                E34 pan on, and replacing the valve seal this week. Wanted to do this because Like 3-4 years ago I did the valve retainers on my s50... while there I also did the seals. The old ones where all dried up and cracked...
                                After the first cam up, inspected the seal and they seams in pretty good shape... but will probably do them anyway since my timing is already messed up and one cam is removed... will sleep on this!
                                E30 now S52
                                325xiT (Sold)
