Matracer's project: BRONZIT S52 - DYNO RESULTS P.8
  • MatRacer
    • 562
    #61
    New steering wheel!
    Also, when to a track event last week! Everything held! Was really awesome to finally hit a track day!
    E30 now S52
    2008 Suburban LTZ (Family and TT hauler)
    325xiT (Sold)
    • MatRacer
      • 562
      #62
      Way to much roll
      Knew my suspension setup wasn't optimal for track usage and that I got quite a lot of body roll, but zooming at this picture made me realize that it was worst than I thought...
      Basically, I have 300# fr and 500# rear with stock sway bars... since our roads are really bad, its good not have too stiff spring... but for track it sucks... We will see what I will do...
      E30 now S52
      325xiT (Sold)
      • MatRacer
        • 562
        #63
        One more from track day.
        E30 now S52
        325xiT (Sold)
        • MatRacer
          • 562
          #64
          Liked how it was sitting in the driveway this morning
          E30 now S52
          325xiT (Sold)
          • MaxBell
            • 1391
            #65
            Wow, looks like you're having fun with this thing! :D
            My S52 goes in soon, are you enjoying yours?
            REMEMBER: Be safe and have fun is Rule Number 1.
            The Epic Unbuild of Clint Eastwood
            • MatRacer
              • 562
              #66
              Sure do!!!
              Really like the S52! The sound, the power curve, just enough to have a lot of fun on track event!
              However, I'm running it with OBD1 and I have slight pinging between 4 and 5k rpm at WOT.... My chip is form TMS. My guest is that I'm a bit too lean in this range (vs fire timing advance)... Will probably go with a custom tune next spring.
              But else than that, its a blast!
              E30 now S52
              325xiT (Sold)
              • MatRacer
                • 562
                #67
                Another one!!
                E30 now S52
                325xiT (Sold)
                • MatRacer
                  • 562
                  #68
                  Update
                  Driveshaft in the trunk means broken driveshaft... had it rebuilt like 1000 miles at a local shop but they apparently installed ATV joints... that combine with wheel hop was enough to destroy one of the needle bearing... also, they machine it a bit so it's now not possible reinstall oem type joints...
                  Fortunately, scored an e36 328 driveshaft for 40$!! Will get it this weekend. If I'm lucky I will be able to just throw it under the car without rebuild...
                  Wheel hop it really annoying and probability hurting more stuff that just the driveshaft... sublease is solid mounted and got poly TAB... the rear end is on 500 pound spring and bolstering sport shocks... will replace them with Koni. Hope it will help.
                  Is poly engine and tranny mount would really help reduce wheel hop? Read that somewhere but really not sure about it...
                  E30 now S52
                  325xiT (Sold)
                  • 2mAn
                    SeƱior Mod
                    • 21014
                    #69
                    Were you drag racing to get wheel hop?
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    Make R3V Great Again -2020
                    • MatRacer
                      • 562
                      #70
                      never been to the drag strip... I get wheel hop when it break loose on hard accel at like 5000rpm in 1st and a bit higher in 2nd when its cold outside (running 225 RS3). If I lauch very hard, no wheel hop but if I lauch semi hard, then I get some.
                      Also, when I get a taste of sideway fun, if I don't hammer it, I also get wheel hop.
                      Its worst on wet pavement.
                      Its, possible to avoid it, except when your getting good traction and it break loose at higher rpm in second gear... pretty annoying...
                      My bilstein are not new, got them used with unknown mileage... So it wont hurt to replace them anyway. Also planning on increasing spring rate.
                      E30 now S52
                      325xiT (Sold)
                      • 2mAn
                        SeƱior Mod
                        • 21014
                        #71
                        I'm trying to think if I've had that problem with mine, and I think with the new Konis I got I haven't noticed that issue.
                        Sucks when you break stuff but it gives you an opportunity to make things stronger
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        • MatRacer
                          • 562
                          #72
                          Yeah, the koni are harder than the bilstein... hope it will help my case
                          how do you know that??
                          E30 now S52
                          325xiT (Sold)
                          • MatRacer
                            • 562
                            #73
                            Got my 328 driveshaft... inspected it: pretty tight... one on the four joints is kind of harder to move when you go max travel on each side... like is you bring it where it never been...
                            I will run it as is for a while and get it rebuilt if not good or in the next years...
                            A bit of cleaning:
                            E30 now S52
                            325xiT (Sold)
                            • MatRacer
                              • 562
                              #74
                              Installed and reved it to 80mph on jack stand before putting the exhaust back... it vibrates ... Will send it to rebuild shop...
                              E30 now S52
                              325xiT (Sold)
                              • MatRacer
                                • 562
                                #75
                                Meanwhile, received 90mm studs and open end nut!! Test fitted with the addition of 20mm spacers!! Final offset of et0 on 15x8 with 225/45 RS3
                                Pretty happy with the results! We will see if it rub or not...Also have a pair of 15mm spacer... maybe I will have to use then instead of the 20mm
                                Had rolled the fenders and cut the inner side back when I attended to fit too large wheel...
                                E30 now S52
                                325xiT (Sold)
