Do you know if the wires that are running to the front door tweeters are hooked up to the front kick panel speakers already? I see waiting there but not too sure . Mine has blanks at the moment
1990 325is restomod project aka "Klaus"
Originally posted by prisonerofdoom83 View PostDo you know if the wires that are running to the front door tweeters are hooked up to the front kick panel speakers already? I see waiting there but not too sure . Mine has blanks at the moment
Originally posted by prisonerofdoom83 View PostLet me know when you are going to sell your headlights! That is if you are still going back to sealed beams
Originally posted by Staszeknot going to sealed beam, I have Euro Hella Smileys.'86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
Albie325 Build Thread | Albie325 COTM Jan 2021
So a few things happened. I finished my OE stereo install, waiting on my Bluetooth board to really complete it.
Bad pic I will have to take a few more after the board is in.
Also bought these, I like the Depo's but decided to go OE, I will get pics of them installed with LED bulbs.
Last but not least I did a flooring project in the garage. I couldnt stand the crappy concrete. Went with flexible interlocking vinyl, its nice and quiet unlike the plastic and its easy to clean.
Crazy how the floor makes such a difference to the garage, looks great man'86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
Originally posted by jeenyus View PostDang I like that! Do you have a link to the flooring you used? What happens if fluid gets under it? We get a good amount of snow here.
Here is the link! They have lots of options.
Our Smooth Flex Tiles offer a fast and easy way to cover your garage or room in your home. These interlocking tiles come in several great colors and are mold and mildew-resistant.
Hey Staszek, I don't remember if you added cruise control, but I updated the DIY Here so that you can use the correct TE MQS AMP plugs and pins for the cruise control module as well as adding the Cruise Control Clutch cutout switch with correct wiring/housings so that now cruise control will not only work, but cancel on speed differential, brake AND clutch disengagement!
Originally posted by R3Z3N View PostHey Staszek, I don't remember if you added cruise control, but I updated the DIY Here so that you can use the correct TE MQS AMP plugs and pins for the cruise control module as well as adding the Cruise Control Clutch cutout switch with correct wiring/housings so that now cruise control will not only work, but cancel on speed differential, brake AND clutch disengagement!
