Lira (euro DS mtech II 318is reshelled, 24v swapped, also now BAR'd)
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    #151
    Man you hauled ass with this car. Good work dude.
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • phreshkid
      • 4655
      #152
      Great job. You've inspired me to find a nice Dschwarz 318iS.
      Ok I just bought one.
      • kronus
        • Apr 2008
        • 13032
        #153
        Originally posted by 2002jm
        Glad this car is on the road. One of my favorite builds!
        thanks guys! it came together really well and I'm enjoying it throughly.
        lol goddammit
        cars beep boop
        • 2002jm
          • Sep 2005
          • 2077
          #154
          the original car
          Do you remember the original car that you took all the parts off of???:) Sure has come a long ways. Are you going to make any changes, or just drive it for now?
          jm
          • rzerob
            • Jun 2013
            • 2315
            #155
            I enjoyed your build and the car turned out awesome. I thought you mentioned before that there was another set of wheels you were going to put on it. I am curious to see what you have in mind. And now thanks to the pics of your car, you have me considering a Mtech II kit. Keep up the good work.
            • kronus
              • Apr 2008
              • 13032
              #156
              jm
              it's actually very similar to the car that donated all the fun stuff, except for having a real motor and being significantly less worn down.. and being legal to drive in CA.
              for changes, I am continuing to waffle back and forth on installing the 245/11 dogleg it came with. the flywheel rattle is driving me bonkers, so the solid disc needs to come out for a sprung one no matter what I do. after some shenanigans I'll have a 3.25 Torsen. That diff and trans works out to be a fancier version of a 260 and a 3.73, gearing-wise.
              and yeah, wheels. need to get them to KIRIEW to get the lips refinished, and then I'll show em off. not a common set ;)
              I didn't like mtech II for a long time, but it's grown on me. definitely better in some colors than others.. I think I've seen enough poorly-maintained Alpine tech II verts that look like beat-up marshmallows to not like it in that color.
              cars beep boop
              • kronus
                • Apr 2008
                • 13032
                #157
                I had an oil leak coming from the oil filter housing, so the whole shebang had to come off. turns out, it was the o-rings, not the profile gasket, but everything was replaced and is now dry.
                off:
                on:
                I put this off until the first oil change. The car has now officially done 4000 mostly-functional miles with its new powerplant!
                I also put in a thermostat with a hole drilled in it while everything was out. This solved the majority of my overheating issues, so that's good. Unfortunately, the M42 radiator's bleed screw housing cracked while I was bleeding it, so now I need a new one. It's currently held closed with a hose clamp, but is liable to blow at any time.
                cars beep boop
                • 2002jm
                  • Sep 2005
                  • 2077
                  #158
                  This is a great project. Thanks for posting all the information....I know it takes lots of time, but it is appreciated!!
                  jm
                  • kronus
                    • Apr 2008
                    • 13032
                    #159
                    bump from the dead and a tiny update.
                    My passenger side headlight stopped working a few days ago, and last night I spent two hours tracing everything, thinking that something shorted in my harness. The harness was fine, so I reluctantly dug into the fuse box. It was most of the way apart when I got curious and looked at the ellipsoid connector.
                    yup, that's the power and ground wires connected together with solder. I think something got hot, it gooped down and the current made more of it melt and get even more connected.
                    So that was dumb. FYI.
                    Also, coming soon - S50 cams, a torsen diff and a dogleg transmission.
                    cars beep boop
                    • kronus
                      • Apr 2008
                      • 13032
                      #160
                      Wee update, I cracked the oil pan :(
                      I did mange to get the dogleg in, which fucked me over since they don't have access holes for the oil pan in the bellhousing. (neither do 260s, though)
                      So, out it came.
                      After installing a clean oil pan and slapping my other 245/11 on it (gotta test em), everything went back in. Not sure if this counts as a motor swap.
                      Of course, the very last thing I was tightening broke off. As fortune would have it, it was the bleed screw in the radiator, in which it is now stuck. Sigh.
                      cars beep boop
                      • iwantspeed
                        • 3164
                        #161
                        Can you use the brass bleeder screw upgrade?
                        Project
                        Parts for Sale
                        Feedback
                        YouTube Channel
                        • kronus
                          • Apr 2008
                          • 13032
                          #162
                          you can, but I ordered the plastic one. With my luck, the brass one would chew up the plastic threads.
                          cars beep boop
                          • wworm
                            • Dec 2016
                            • 1719
                            #163
                            Glad that oil pan finally made it onto a car! Keeping my fingers crossed that it doesnt get smacked
                            1984 Delphin 318i 2 door
                            • raj
                              • Oct 2013
                              • 100
                              #164
                              Spotted you in SOMA today.. car looks amazing
                              • kronus
                                • Apr 2008
                                • 13032
                                #165
                                thanks! I'm weeding out some issues still but it's been driving.
                                did you see it in the alley? are you the guy with the fjord roundie that's started parking around here recently?
                                cars beep boop
