Lira (euro DS mtech II 318is reshelled, 24v swapped, also now BAR'd)
  • KIRIEIW
    • Dec 2012
    • 3385
    #121
    Sweeeet man! Glad to hear it passed, I'll bring you back your smoke tester today after work if your around still (I get off around 7.30PM) otherwise the weekend.
    1992 e34 Touring- S50 Swap
    1992 325i-S50 Swap (SOLD)
    1991
    • kronus
      • Apr 2008
      • 13032
      #122
      I am at a lemons race this whole weekend. Hold on to it, I'll get in touch next week!
      cars beep boop
      • kronus
        • Apr 2008
        • 13032
        #123
        some small updates..
        cleaned up an painted a Sparco strut brace I had sitting around. interestingly, it doesn't clear the fusebox of my '83 323i but fits fine here with a bit of elbow grease.
        made a subframe bushing extractor helper thingy
        pushed the (very dead) bushings out of the old subframe, cleaned and primed it
        With the subframe swap I will also be removing the buzzy open 4.10 small-case diff, so I'm currently figuring out what I want to install in its place. I have a S3.46, a 3.46 Torsen, and a S3.23 available, and may have a line on a S3.15 as well. (yes, I have a problem) The main operative difference is whether I want to stick with the 260 in the car, or put in one of my 245/11s (told you I have a problem).
        A 3.46S is a bit low for the 260, going about 3100 RPM at 80mph, vs the 245/11+S3.15 combo's much more convenient 3500. However, putting the dogleg in involves locating a clutch for it, redoing the entire shifter setup, and it makes the car less attractive for an S5x motor down the line if the M50 goes, since the 245 will apparently have trouble keeping its shiny bits on the inside with that much power. Maybe I just want a 3.73.
        I have been driving the car as well now that it's street-legal, and am running into some cooling issues. Car sits at a tick to the right of the 1/2 mark on the gauge, but coming off the highway it will get as high as 3/4 before the fan can rein it in. The internet claims the M42 rad is pain in the ass to bleed, but I'm pretty sure it's fully bled by now. I have good heat coming from the core and everything seems to be circulating fine. I have the stock 92deg thermostat in the motor.. Is it possible that the M42 radiator is just not keeping up?
        cars beep boop
        • 86gt635
          • Jun 2012
          • 99
          #124
          This thread is titties.
          • kronus
            • Apr 2008
            • 13032
            #125
            did work!
            these Lemfoerders should last a decent amount of time. TABs coming up this week.
            swapped out the M42 radiator for an E36 unit. the size difference is substantial, but the effect on my running temperature was minimal. I need either an electric fan or a low profile euro diesel fan, but haven't decided which, yet. For now, my aux fan is rigged to be permanently on and the temperature is staying stable.
            I've also cleaned, sandblasted and stripped down the calipers that came off the Italian donor.
            They are getting painted and rebuilt with new bushings, o-rings and boots this week.
            The car itself, on a little trip down to the dealership.
            cars beep boop
            • bradnic
              • Jul 2012
              • 3554
              #126
              anything special about the calipers?
              HOWTOs:
              DB vert plastic bumpers
              OEM Keys
              MTech1 docs
              88 ix Lach/Card
              91 ic Calypso 3.1
              86 Cosmo 2.7
              OEM+ or bust!
              • kronus
                • Apr 2008
                • 13032
                #127
                nope, pretty typical ATE units. I like them better than the Girlings that are on the car, and after 270k miles a refresh is nice even if the brakes feel pretty great as they are right now.
                cars beep boop
                • alas
                  • Oct 2015
                  • 291
                  #128
                  Nice work, Kronus!
                  I wish I lived closer to come check out your car and shop, but maybe during the holidays as the fiancé has family up near you...
                  Totally SUB'd.
                  -E
                  -ALaS
                  • kronus
                    • Apr 2008
                    • 13032
                    #129
                    thanks! which holidays?
                    also, continued plugging away at it. Calipers got painted..
                    dried..
                    and rebuilt with new guide sleeves, o-rings and boots
                    replaced the TABs with new Lemforders.
                    now I'm trying to get the axles out.. might need to use the press, since they're being complete assholes.
                    last puzzle piece is the diff, which I should be getting to this week. I'm thinking to put the torsen unit from the 3.46 into the 3.25 and install that.
                    cars beep boop
                    • bradnic
                      • Jul 2012
                      • 3554
                      #130
                      aluminum paint? that's the way it's done.
                      HOWTOs:
                      OEM Keys
                      MTech1 docs
                      88 ix Lach/Card
                      91 ic Calypso 3.1
                      86 Cosmo 2.7
                      OEM+ or bust!
                      • kronus
                        • Apr 2008
                        • 13032
                        #131
                        Duplicolor silver caliper paint. The choices were red, black, blacker black, and silver. It goes with the black/silver theme of the car decently well!
                        cars beep boop
                        • Reichart12
                          • Aug 2012
                          • 2165
                          #132
                          Cars looking clean. How was the fitment switching your radiator up?
                          Instagram: Reichart12
                          • kronus
                            • Apr 2008
                            • 13032
                            #133
                            late-model cars hold the sides of the radiator instead of the bottom, using little clip-in plastic cups. the M42 radiator is about an inch narrower than the M50 one, and the little cup is different enough that the M50 radiator didn't drop right in. I did not know this until I was in the middle of the swap, so I had to trim the cup a bit instead of using the correct one.
                            also M42 cars don't have provisions for mounting the M20 overflow tank, so it's currently held in with zip ties.
                            otherwise, it was fine.
                            I think I'm going to go back to the M42 radiator for the somewhat cleaner setup and lack of zip ties, since my cooling problems seem to mostly be related to the lack of a fan, not cooling capacity.
                            cars beep boop
                            • Reichart12
                              • Aug 2012
                              • 2165
                              #134
                              Cool, that all makes sense. I never realized how much of a size difference there was with m42 and m50 radiators. Thanks
                              • kronus
                                • Apr 2008
                                • 13032
                                #135
                                so today was going fine and then after lunch this thing fell off
                                sighing, I rounded up all the crap I had piled in a corner and went to work. pile of crap:
                                contents of pile:
                                subframe with new Lemfoerder bushings
                                trailing arms with new Lemfoerder bushings, good bearings, OEM bent trailing arm delete mod
                                new rear sway bar end links
                                new half-shafts
                                new e-brake cables
                                new e-brake shoes
                                cleaned-up e-brake hardware
                                new(ish) rotors
                                UUC SS brake lines
                                pictured in a previous post:
                                4 rebuilt ATE brake calipers
                                here's the gaping maw of Lira's ass end
                                these are kind of cake to do when the subframe is out..
                                subframe went in straightforwardly-like. it's painted, a lot.
                                trailing arms followed.
                                being stupid, I had filled up the tank the day before deciding to do this whole thing, so in order to get the right-most trailing arm bolt in, I had to drain about 5 gallons of gas out of the tank fill tube into a gas jug, while on my tippy toes. most of the gas did not get everywhere. However, being not the stupidest, I did remember to preload the trailing arms before torquing the bolts.
                                diff went in. It is a S3.46, but it is only temporary while I swap a torsen unit into a 3.25 case. sorry about the 80s porn filter, I think some diff juice got on my phone.
                                by this time it was about 6pm, so I cleaned up and went home. just need to re-torque some stuff, reassemble the driveshaft, exhaust, and drive to Oregon. easy. I wish it would stop overheating..
                                also, what could this be.
                                cars beep boop
