325ix
  • GJ@GA_US
    • 46
    #61
    Previous owner here. Julien, hats off to you. Super thankful for your ambition and patience to see it through. Great Job!!
    • Julien
      • 7471
      #62
      Originally posted by fresh_TD
      Leave the wheels stock color..black would be too much
      Sent from my Samsung Note 4
      Yeah, I would stay stock color. However I think the steering wheel would look better with a black center.
      Thanks Glenn! Luckily a job change gave me a two week window to get a lot of this work knocked out!
      Build Threads:
      • kmushu
        • Aug 2014
        • 36
        #63
        I almost bought this car
        Julien, this looks incredible. Was going to try and pick this up in ATL if you passed it on, but the work you've done looks much, much better than anything I could have hoped for.
        I've got a white 4dr IX right now that I was dreaming about swapping into that 2dr, very glad to see that you've got it all sorted the right way with the transmission.
        • Julien
          • 7471
          #64
          some progress...
          Wet sanding
          1500 grit before, during, after. After section has not been polished yet, just cut
          Then I decided to finish off the wetsanding with 2000 grit to get rid of some minor scratches
          turns out I was waffleswaffleswaffleswaffleswaffles-footing the buffer. After RTFM'ing the bottle of megiuars m105 it turned out I had to hit it at 1500-2000 rpm, versus the 750ish i was doing
          selfie:
          Overall, I must admit I HATE wetsanding- lol. Results are ok, but I'll go back to a few areas when I get free time.
          Also installed euro bumper trim:
          I forgot to mention, I pulled the tint off last weekend because e30 = fishbowl ftw.
          Door trim and several other goodies are coming in very soon :)
          Build Threads:
          • fresh_TD
            • Aug 2013
            • 2457
            #65
            No tint is the right look on e30s..good job on the car btw, looks good.
            '91 318i (Alpine) - daily
            '88 325ix (Zinno) - drive here and there!
            • rzerob
              • Jun 2013
              • 2315
              #66
              Where did you get the door trim? Is it the one with the chrome strip? I like your IX and thanks to you making this build thread I am now aware I can easily swap the front of my manual and automatic transfer cases. I am now glad I never got rid of the automatic transfer case.
              • Julien
                • 7471
                #67
                I got my black door trim from someone on here who was parting a 2 door IX. The IX trim is different than the normal trim because of the body kit.
                No problem, glad you're enjoyed the thread :)
                Build Threads:
                • jeenyus
                  • Aug 2011
                  • 2064
                  #68
                  I called my BMW Motorcycle dealer here in town when I was putting back together the driveshafts and they just said they use a mixture of anti-seize and moly-grease. So i just mixed some up and put that on mine. Figured it would be fine. It's so easy to check those splines and re-lube them if you need to, especially the front.
                  your car is looking so good considering where you were when you got it!
                    • 34839
                    #69
                    Yeah.. I wouldn't trust that.
                    The biggest reason is it will tend to oxidize and wash out. When it does that you have metal on metal and the splines will turn to dust. It can take as little as a year to happen.
                    Get the proper grease - its not expensive, but a new driveshaft, or worse, front output sprocket is like $300-$500.
                    • Julien
                      • 7471
                      #70
                      Lowered her last night using a less conventional method:
                      (i'll fix the overspray at some point)
                      bam:
                      also tossed on some 14.5mm rear spring pads and euro smiley headlights:
                      Build Threads:
                      • audiquattrot
                        • May 2008
                        • 3836
                        #71
                        Awesome! Love the new height!
                        www.instagram.com/snwmble
                        #snwmble
                        Current:
                        '05 BMW M3 - Silver Grey/Imola Red
                        '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
                        '15 Mini Countryman - Blazing Red/Carbon Black
                        Past:
                        '01 Audi Allroad - Light Silver/Platinum Saber Black
                        '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
                        '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
                        '90 BMW 325i - Schwarz/Tan sport *Sold*
                        '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
                        • Julien
                          • 7471
                          #72
                          Put in some more work today. I did belts, fuel/air filter and engine/transfer case mounts. The later where a bit of a challenge.
                          Motor mounts:
                          I unbolted the mounts and jacked up the motor from the oil pan using a 2x4 to spread the load on the pan.
                          Taking the old ones out wasn't all that hard, but as you can see they had settled a bit:
                          To get the new ones in I removed 3 bolts from the motor mount arms and loosened the 4th, which allowed me to sneak the mount in. It may be possible to do them one at a time and get them in, but I was past that point.
                          Now onto the transfer case mount. I removed the exhaust for clearance and pivoted the drivetrain down. Using a ball joint tool I rented from advance auto and a gland nut (same OD as bushing) from my struts I had laying around I pressed the old bushing out (I did use a 2 prong for the last 1/2ish inch):
                          I guess someone had tried hacking at the old bushing before me:
                          oh and took the rack off since I'm taking her on a road trip tomorrow:
                          Doing all this to get her sorted since I'll be daily driving her for a bit while my 335d is in the shop. I did spot this little guy at the body shop, not every day you see one:
                          Getting fully restored. And I thought this e30 was a project!
                          Happy Holidays Y'all :)
                          Build Threads:
                          • stonea
                            • 2892
                            #73
                            Man, I've found 3 new ix threads today! Also amazing looking car, my car definitely needs more low in its life.
                            My Garage
                            Feedback
                            Instagram: Stone.Hopkins
                            • bradnic
                              • Jul 2012
                              • 3554
                              #74
                              SUB'D! love the build and the lazurblau. almost bought a cali car in the same color - it was seriously beat though.
                              can't wait to get back to my IX project.
                              HOWTOs:
                              DB vert plastic bumpers
                              OEM Keys
                              MTech1 docs
                              88 ix Lach/Card
                              91 ic Calypso 3.1
                              86 Cosmo 2.7
                              OEM+ or bust!
                              • kronus
                                • Apr 2008
                                • 13032
                                #75
                                damn, so this is what you've been doing while not eating waffles. well done! come color sand my 318!
                                cars beep boop
