777- Kamotors E23 Turbo Build + E38 content and a hint of e32
  • kamotors
    • Nov 2007
    • 7102
    #151
    Originally posted by Coyote_ar
    Those are the ultra wide E30 flares?
    Nope completely new design
    Sent from my SM-N920T using Tapatalk
    7speedshop.com
    • kamotors
      • Nov 2007
      • 7102
      #152
      Occasionally running lean at high rpm, gonna replace fuel pump,filter then injectors with 24lbers if that doesn't remedy the situation.
      7speedshop.com
      • kamotors
        • Nov 2007
        • 7102
        #153
        Quick little sketch,some 295s will fit nicely
        7speedshop.com
        • kamotors
          • Nov 2007
          • 7102
          #154
          7speedshop.com
          • kamotors
            • Nov 2007
            • 7102
            #155
            Have to rebuild the begi fuel pressure found one ripped diaphragm and one very stretched. In the mean time cleaning up the exterior.
            7speedshop.com
            • kamotors
              • Nov 2007
              • 7102
              #156
              quick update-
              7speedshop.com
              • kamotors
                • Nov 2007
                • 7102
                #157
                7speedshop.com
                • kamotors
                  • Nov 2007
                  • 7102
                  #158
                  Getting quicker now. Able to spin tires from a roll.
                  7speedshop.com
                  • kamotors
                    • Nov 2007
                    • 7102
                    #159
                    Backyard dyno?
                    7speedshop.com
                    • kamotors
                      • Nov 2007
                      • 7102
                      #160
                      7speedshop.com
                      • kamotors
                        • Nov 2007
                        • 7102
                        #161
                        7speedshop.com
                        • BMW_TUNER
                          • Jul 2006
                          • 1386
                          #162
                          Any E30 fitment coming for those flares? I can't put my power down so I need more tire or less power, but less power hurts my heart so more tire it is.
                          1989 332IS -S-Fiddy Four-Some weight removed.
                          5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
                          • delamaize
                            • Nov 2013
                            • 1465
                            #163
                            I'm in the same boat, and I kinda dig these new flairs. :D
                            Dumpster Fire Pilot
                            • kamotors
                              • Nov 2007
                              • 7102
                              #164
                              I've done a test fit on my e30, they allow a lot more upward travel but they do not fit 4dr e30s and they don't cover the lower holes my current flares use. So if you could live with a visible hole above the rocker panel than these could fit an e30 no issue. This was the inspiration, car not level here, other side is tucking tire.
                              7speedshop.com
                              • kamotors
                                • Nov 2007
                                • 7102
                                #165
                                Front done
                                7speedshop.com
