777- Kamotors E23 Turbo Build + E38 content and a hint of e32
  • kamotors
    • Nov 2007
    • 7102
    #121
    Originally posted by Coyote_ar
    so that E23 ... thats an AT right? with a 4HP22? are you keeping it or are you going to go manual?
    im really interested on how much power/torque you can put through that.
    I have clutch flywheel and trans, but no pedal box,driveshaft etc so it'll be auto for a while. All the e23 745i cars were auto so it should be good for a while. I've decided on getting an entire parts car for when the time comes to swap as it's hard/expensive to find and buy parts for these e23s
    Sent from my SM-N920T using Tapatalk
    7speedshop.com
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      #122
      Buddy has 4hp22 on his m106 thats been tinkered with. It hauls ass and has held up really well.
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • bangn
        • Sep 2011
        • 760
        #123
        time to chuck that starter motor!
        also why does it sound like a truck? Is that straight out the dump?
        P.S really digging that brown 7!
        Boris - 89 E30 325i
        84- E30 323i
        • kamotors
          • Nov 2007
          • 7102
          #124
          So about ready to give up on this chassis the electrical problem came back and left me stranded and pushing the car home.
          I've traced it to the obc security box but even with that bypassed it has the issue, if I simply unhook the grn and grn/red box wires all the symptoms go away but then there is no fuel. If I hook them up then it's the tach freaking out, coil firing, starter turning issues again.
          Going to replace ignition switch and hope for the best
          7speedshop.com
          • kamotors
            • Nov 2007
            • 7102
            #125
            Ok so determined it's multiple issues found the door jam switch was missing its insulation and rubbing on bare metal causing a relay to click and get hot. Fixed that....
            Then I got the car started and as soon as I shut it off the coil and starter issue started up again. I pulled apart ignition switch wiggled some wires and it stopped doing it. Since it's a 2 piece ignition switch it still requires a key to drive but I should be able to put a switch panel w/push start and fix the issue .
            7speedshop.com
            • kamotors
              • Nov 2007
              • 7102
              #126
              7speedshop.com
              • kamotors
                • Nov 2007
                • 7102
                #127
                Video of issue
                7speedshop.com
                • kamotors
                  • Nov 2007
                  • 7102
                  #128
                  ok so problem follows the turbo chip... switched back and forth twice to confirm.
                  7speedshop.com
                  • delamaize
                    • Nov 2013
                    • 1463
                    #129
                    Miller WAR chip time?
                    Dumpster Fire Pilot
                    • kamotors
                      • Nov 2007
                      • 7102
                      #130
                      Tcd is sending me a replacement
                      7speedshop.com
                      • bangn
                        • Sep 2011
                        • 760
                        #131
                        oh really? what a pain in the ass!
                        Boris - 89 E30 325i
                        84- E30 323i
                        • kamotors
                          • Nov 2007
                          • 7102
                          #132
                          My E38 740i Msport vs my brothers modified E32 740i.
                          7speedshop.com
                          • TheTacoMan
                            • Nov 2011
                            • 2308
                            #133
                            • Bimmer_man
                              • Jan 2013
                              • 1478
                              #134
                              okay that e32 has beat kamerons 7s time and time again. impressive. I wonder what new toys youll have.
                              Float like a cadillac sting like a Bimmer!:)
                              • kamotors
                                • Nov 2007
                                • 7102
                                #135
                                With a good brake stall I can hold him off till like 80mph in the msport but no denying how fast it is. Pulls pretty good on an 01 e39 540i msport as well. Can't wait to see how the e23 compares and making a few changes to the e30 in preparation as well.
                                7speedshop.com
