777- Kamotors E23 Turbo Build + E38 content and a hint of e32
  • Bimmer_man
    • Jan 2013
    • 1478
    #136
    What are you doing to the E30 now?
    Float like a cadillac sting like a Bimmer!:)
    • kamotors
      • Nov 2007
      • 7102
      #137
      Working with some wood to make my panels for radio delete, start switch mount, my boost gauge and wideband gauge plate.
      Sent from my SM-N920T using Tapatalk
      7speedshop.com
      • kamotors
        • Nov 2007
        • 7102
        #138
        7speedshop.com
        • kamotors
          • Nov 2007
          • 7102
          #139
          Ok so the car is losing spark at 5krpms under any load, it'll just peg full rich and cut out. All sensors are new except for the crank/flywheel sensor. Is it possible for that sensor to cause the car to have a high rpm cut out but run fine everywhere else or should I look elsewhere?
          7speedshop.com
          • kamotors
            • Nov 2007
            • 7102
            #140
            Finally got to drive it, only half throttle and lie 4psi. anyone know what is wastegate pressure on the M106 is?
            7speedshop.com
            • Bimmer_man
              • Jan 2013
              • 1478
              #141
              Looks like the e32 wants a piecr of it
              • kamotors
                • Nov 2007
                • 7102
                #142
                Replaced ecu and that didn't fix it. Checked reference pins dies any one know if it's normal for them to be at different heights.
                7speedshop.com
                • CorvallisBMW
                  Long Schlong Longhammer
                  • 13039
                  #143
                  0.3bar, which is just over 4psi.
                  • kamotors
                    • Nov 2007
                    • 7102
                    #144
                    http://www.745i.avulan.eu/
                    Ok perfect that's what it's hitting
                    7speedshop.com
                    • kamotors
                      • Nov 2007
                      • 7102
                      #145
                      change of plans, I think I'll be selling the entire m106 setup and going to a custom setup with stand-alone ecu.
                      Anyone interested, I'm pretty sure my stock/factory wiring is my issue and ditching that, doing a motoronic 1.3harness and pnp ms2 would solve my issue and then open up potential to run more power than what the m106 setup can safely produce.
                      Looking to sell everything, injectors, chip, begi, manifold, turbo, wastegate etc.
                      7speedshop.com
                      • kamotors
                        • Nov 2007
                        • 7102
                        #146
                        Got it running good enough to take on the road.
                        7speedshop.com
                        • kamotors
                          • Nov 2007
                          • 7102
                          #147
                          So the increased fuel pressure from the rrfpr has caused 2 fuel lines to split. Going to be replacing all soft line pre regulator with some new high pressure line, possibly braided line.
                          7speedshop.com
                          • kamotors
                            • Nov 2007
                            • 7102
                            #148
                            New alternator in the daily 740i.
                            7speedshop.com
                            • kamotors
                              • Nov 2007
                              • 7102
                              #149
                              Can't wait to start cosmetics/wheels/suspension
                              7speedshop.com
                              • Coyote_ar
                                • Sep 2009
                                • 175
                                #150
                                Those are the ultra wide E30 flares?
                                ---E30 320i Hennarot 1984 Sedan---
