777- Kamotors E23 Turbo Build + E38 content and a hint of e32
  • kamotors
    • Nov 2007
    • 7102
    #106
    Sent from my SM-N920T using Tapatalk
    7speedshop.com
    • kamotors
      • Nov 2007
      • 7102
      #107
      some good noises.
      7speedshop.com
      • Dj Buttchug
        • Jun 2010
        • 7648
        #108
        my lawd
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • stonea
          • 2892
          #109
          Originally posted by Dj Buttchug
          my lawd
          V12 the e34
          My Garage
          Feedback
          Instagram: Stone.Hopkins
          • delamaize
            • Nov 2013
            • 1436
            #110
            Dear god yes.
            Originally posted by stonea
            V12 the e34
            Also, Yes.
            This world needs another Gristle hammer.
            Dumpster Fire Pilot
            • kamotors
              • Nov 2007
              • 7102
              #111
              7speedshop.com
              • kamotors
                • Nov 2007
                • 7102
                #112
                New How to Boost it.
                7speedshop.com
                • kamotors
                  • Nov 2007
                  • 7102
                  #113
                  Lovin' that 7 life.
                  7speedshop.com
                  • kamotors
                    • Nov 2007
                    • 7102
                    #114
                    Almost drivable. Decided to make some videos showing the 7 series and will be doing 7 vs. 7 comparisons. This video is just on the brown e32 as somewhat of an intro for it to my channel.
                    Also
                    E23 has been started!
                    And my brothers e32 is cleaning up very well.
                    7speedshop.com
                    • kamotors
                      • Nov 2007
                      • 7102
                      #115
                      Also test fit some new rear flares and decided to p-shop how it would look w/ wide wheels
                      test by kamotors@y, on Flickr
                      7speedshop.com
                      • kamotors
                        • Nov 2007
                        • 7102
                        #116
                        Its alive
                        7speedshop.com
                        • efficient
                          • Feb 2012
                          • 3312
                          #117
                          Cool. What do you do for a living if you don't mind me asking?
                          • kamotors
                            • Nov 2007
                            • 7102
                            #118
                            So car has some sort of electrical issues now... i haven't touched the electrical yet so not sure what has caused this, possibly a mouse or something.
                            As soon as the key is put it the car starts reading an rpm signal and the coil starts firing constantly. Sometimes it will very slowly crank over without me turning the key. Car no longer starts, the coil stopped firing for a bit and I got it to almost start but no luck.
                            I've been looking into the wiring but haven't found an issue yet, going to pull all the 12v power wires/look into the fuse box and trace them as the starter should not be able to turnover on its own without a signal from ignition switch.
                            7speedshop.com
                            • kamotors
                              • Nov 2007
                              • 7102
                              #119
                              So discovered the car has been pretty molested in its past life, found all this wire under the rear seat with 99% leading no where and 2 wires tapped into my body harness. This looks like the remnants of an old alarm system and an old stereo system. Car does work now but not sure why as this was all dead weight wiring that was not connected to anything.
                              I also sanded, used,
                              rust reformer and repainted the battery tray.
                              Before-
                              After-
                              7speedshop.com
                              • Coyote_ar
                                • Sep 2009
                                • 175
                                #120
                                so that E23 ... thats an AT right? with a 4HP22? are you keeping it or are you going to go manual?
                                im really interested on how much power/torque you can put through that.
                                ---E30 320i Hennarot 1984 Sedan---
