'89 318i 6 speed m50b32tu turbo swap build
  • Vincenze
    • Apr 2019
    • 916
    #196
    Does the E36 325i drive shaft fit well? Some people say it's short.
    Do you prefer the ratios of the 2.93 or 3.15 differentials?
    How reliable is the transmission?
    • ba114
      • Sep 2015
      • 364
      #197
      325i auto shaft fits fine, no issues with it. 2.93 is far better suited to the diesel box than the 3.15. 3.15 would be best with the petrol 6 speed. Sent from my SM-G973F using Tapatalk
      RHD OBD2 M50b25 turbo build thread:
      http://www.r3vlimited.com/board/showthread.php?t=384800
      • ba114
        • Sep 2015
        • 364
        #198
        New Gearbox has arrived. GS6-53BZ from e82 135i.
        Custom twin disk clutch from adamat will be mated with this.
        • ba114
          • Sep 2015
          • 364
          #199
          Build summary updated on first page
          • Slovik
            • Jan 2010
            • 198
            #200
            Could you post a picture and details on the flywheel, I'd like to use a later 6 speed on my s52 swap and couldn't find a flywheel for my s52 that would work on the later gearbox with internal pilot bearing. Thanks
            • ba114
              • Sep 2015
              • 364
              #201
              This is what i am getting:
              https://adamat.com.pl/n54-n55-turbo-...2x-kevlar.html
              They are making a custom version of this with a starter ring gear position to suit the m50 starter motor. You could use any 8 bolt N54 clutch setup, as long as you use the n54 starter with a 10mm spacer.
              • ba114
                • Sep 2015
                • 364
                #202
                • Northern
                  • 5056
                  #203
                  Beautiful
                  Originally posted by priapism
                  Originally posted by shameson
                  • 2mAn
                    Señior Mod
                    • 20167
                    #204
                    Love shiny new bottom end parts!...
                    Simon
                    Current Cars:
                    -1966 Lotus Elan
                    -1986 German Car
                    -2006 Volkswagen Jetta TDI
                    Make R3V Great Again -2020
                    • ba114
                      • Sep 2015
                      • 364
                      #205
                      You guys have basically the same avatar...
                      • Northern
                        • 5056
                        #206
                        We were separated at birth, but reunited through r3v. Our father is FredK
                        • FredK
                          • 14749
                          #207
                          I like what's goin on here.
                          • ba114
                            • Sep 2015
                            • 364
                            #208
                            Fitted the e46 accelerator pedal and the oil pump chain tensioner today.
                            Despite all the evidence out there of different ways to mount the pedal bracket that involve cutting, welding, epoxy etc. I just found that if it notched the metal mounting plate on top of the pedal bracket, that i could just use the stock mounts as is and use a hex head bolt to secure it to the old pedal stop.
                            • Northern
                              • 5056
                              #209
                              I want to see how this oil pump chain tensioner goes. Which one is that? The VW one or the S54? Something else?
                              • BUDNUNTA
                                • Apr 2005
                                • 996
                                #210
                                where did you get the head modded to suite Dual Vanos? i want to run a m52b28 in my e46 touring
                                We're out there in here.
