E34 550iT....The Gristle Hammer
  • bostonvert
    • Oct 2015
    • 233
    #91
    This is so cool, one of my favorite builds!
    Instagram : makeitsnap
    1985 e28 520i
    • slammin.e28
      שמע ישראל
      • 12054
      #92
      Thanks guys!
      More progress...
      Got the fuel system all done up. M73 rails converted to only have an inlet. E46 fuel filter under the car. It's got the built in 3.5BAR regulator, so we'll see how that setup works. I'm using the old return line as the vacuum supply to the regulator.
      Got a new windshield installed yesterday. Hype!
      ....and ended up making a crank holder tool for torquing the M18 crank bolt. It's a stretch bolt.
      More tonight. I should have the thing driving this weekend. All this piddly little shit it taking me forever.
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        #93
        • slammin.e28
          שמע ישראל
          • 12054
          #94
          Guys, you know from my track record I can barely get a project car done.
          Really think I'm gonna try to turbo this v12?
          (I bought my v8 e30 back BTW)
          • delamaize
            • Nov 2013
            • 1460
            #95
            guys, you know from my track record i can barely get a project car done.
            Really think i'm gonna try to turbo this v12?
            (i bought my v8 e30 back btw)
            buy all the v motors!!!
            Dumpster Fire Pilot
            • BlackSpeed66
              • Apr 2008
              • 618
              #96
              I love everything about this. :mrgreen::mrgreen::mrgreen:
              My wagon on the other hand.... is quite jealous. :giggle:
              -Geno
              '87 325is (s52'd)
              '95 525iT
              '02 Range Rover 4.6 HSE
              '98 Disco 1
              • slammin.e28
                שמע ישראל
                • 12054
                #97
                Got the engine started last night around 8:30pm. Rode that victory wave through to get the driveline all installed. Drove it out of the shop this morning.
                To do:
                -Tie up the cooling system
                -Exhaust, install O2 bungs/sensors/harness
                -PS pump, mine broke, so I've got to mod a spare pump to disable the SLS function.
                • Swanny
                  • Mar 2012
                  • 2834
                  #98
                  Swanny!
                  SUCKERS.
                  • mtekjosh
                    • Mar 2017
                    • 8
                    #99
                    That touring....amazing.
                    • M-technik-3
                      • 18946
                      #100
                      New Windshield !!!!!! to be able to see clearly is huge.
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        #101
                        Lol....seriously. I put a huge star in it with a kayak back in September. Forgot my roof rack when picking it up.
                        Today I'm wrapping up the cooling system and getting the exhaust on. Then the last thing will be the power steering pump. I somehow broke the one on the car, so I took my spare and modded it....removed the SLS pump guts so it won't blow out when I plug the SLS outlet. Waiting on the reseal kit to get here, probably Tuesday, then I'll have my brakes back (hydroboost) so I can actually drive the thing on the street.
                        • slammin.e28
                          שמע ישראל
                          • 12054
                          #102
                          It's all together. It's got one big issue I'm trying to smooth out...exhaust is incredibly rich.
                          Fuel pressure is perfect, 42-45 when running. Coolant temp sensor for the DMEs is good, good signals, etc. Good signals FROM the ECUs to the sensor. The pressure regulator is a 3.5BAR one with the e46 fuel filter....OE, I was mistaken, is 3.0BAR, but 7psi shouldn't make THAT big of a difference...especially when the rail pressure is still perfect in spec.
                          SO....I decided to look more into if it's BURNING the fuel it's getting instead of over fueling. The entire ignition system is new, well....a year old with barely any use over that year...except the plug wires. So I began ohming them out. Not good. #2 was totally open circuit. Of the others only two more were in spec. So I'm going to go through and replace the faulty ones and see what happens. These wires are in pretty bad shape, someone has been all into them, electrical tape, etc. I read one thread where someone had the same problem and it turned out to be the wires, after swapping everything else out, etc, etc.
                          • slammin.e28
                            שמע ישראל
                            • 12054
                            #103
                            Dumbass me. Had #4 and #6 wires swapped on bank two.
                            She's all better now.
                            ^_^
                            • MR E30 325is
                              • Dec 2008
                              • 3300
                              #104
                              ^ Glad it was an easy fix
                              My previous build (currently E30-less)
                              http://www.r3vlimited.com/board/showthread.php?t=170390
                              A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                              • slammin.e28
                                שמע ישראל
                                • 12054
                                #105
                                Believe me, so am I. Still going to swap out the bank 1 wires as several are in pretty poor shape, but this was a HUGE relief. I was gearing up to start leakdown testing, etc....
