Econo gauge - by E30 Innovative Goods
  • E30 Innovative Goods
    • Jun 2014
    • 257
    Hi folks,
    There seems to be some interest in Econo gauges, so we decided to try to make it happen.
    We made some research...
    Made a few tests PCBs...
    This is our latest one, already cut to fit in its place :
    It looks good so far.
    Any thoughts on this?
    64
    up to 10 PSI (.5 bar)
    3.13%
    2
    up to 15 PSI (1 bar)
    20.31%
    13
    up to 20 PSI (1.5 bar)
    53.13%
    34
    above 20 PSI (1.5 bar)
    23.44%
    15
    Committed to excellence!
    If you don't know that there's a lot you don't know, you think you know everything.
    Our threads:
    E30 One-Touch windows
    E30 Intelligent wipers
    E30 Econo gauge - still R&D
    E30 SI Shift Lights
    E30 Hazard Switch Multigauge - still R&D
    Feedback thread:
    Our pages:
    http://www.e30ig.com
    https://www.facebook.com/InnovativeG
  • ba114
    • Sep 2015
    • 364
    Pic not working?
    RHD OBD2 M50b25 turbo build thread:
    http://www.r3vlimited.com/board/showthread.php?t=384800
    • mila325
      • Sep 2015
      • 82
      Show me da pics.
      Australians only in this thread.
        • Jun 2014
        • 257
        Apologies, hope you can see it now.
        Our threads:
        E30 SI Shift Lights
        Feedback thread:
        Our pages:
        • george graves
          • 20003
          We can see it - Cool!
          My only question, why do you use such weak little (8mill) traces on everything? I noticed that on some of your other work. It shows signs of a really bad engineering, and new to electronics. Classic mistake. EDIT: You said you made changes, but seem your products are failing often.
          Also, you want a booster circuit, the stock gauge is really slow to change running at 12 volts - good for a MPG gauge, but not for anything else that need fast deflection to show changes.
          Originally posted by Matt-B
          • dude8383
            • Jan 2005
            • 10387
            What is the function of this econo guage? I have your shift light in my car... love it :up:
              • Jun 2014
              • 257
              The majority of the traces carry really weak signals so this trace width is more than enough for this. Where it is needed wider traces are used.
              Thanks for the input.
              Of course we made some modifications. The setup we have now seems fast enough to handle fast changing signals. Still have to make some tests.
              Our threads:
              E30 SI Shift Lights
              Feedback thread:
              Our pages:
              • Northern
                I like cupcakes & sh!tboxes
                • 5253
                I assume this isn't just a replacement stock economy gauge? whuditdew?
                Originally posted by priapism
                  • Jun 2014
                  • 257
                  It is designed to replace the small stock analog gauge under the RPM gauge. Depending on your choice and connection it will be able to show you one value; for example boost, oil pressure or temp... maybe some other useful thing
                  Our threads:
                  E30 SI Shift Lights
                  Feedback thread:
                  Our pages:
                    • Jun 2014
                    • 257
                    It does replace the stock gauge but displays other values. Looks like boost is the most sought after, but pressure or temp is also an option...
                    Our threads:
                    E30 SI Shift Lights
                    Feedback thread:
                    Our pages:
                    • ba114
                      • Sep 2015
                      • 364
                      Get boost and oil pressure and you have my sale locked in!
                      • Northern
                        • 5253
                        • ocCube
                          • Dec 2015
                          • 5
                          in for boost gauge!
                          • Wishno87
                            • 6025
                            Also very interested!
                            • Mtriple
                              • 3139
                              Count me in. Any idea on when this will be available?
                              Originally posted by Simon S
