m3anderings
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4506
    #166
    Originally posted by Northern
    amazing wheel decision
    thanks man, I am hoping the looks mute the ride quality delta #r3versover30
    Originally posted by moatilliatta
    Damn SON. Where did you find those!
    So good! This is an excited project an an exciting time.
    I really enjoy your service bay backdrop.
    Keeping it motronic?
    The quiet calm of a clean tail light stack overlooks the chaos
    Jake said he'd make a pnp standalone if I wanted to use my car to test- crank signal from bellhousing pickup doesn't play nice with standalone so would have to convert to front trigger wheel. Need to get the car running on motronic first so I can test my spare bits. Wish I could go standalone from the get go so I could put a light flywheel on it w/o reference tab for significant savings over the sport evo flywheel that is now $1k. Can't win em all. Have to do stock flywheel for now due to general cost of the project
    Cleaned up housings and unwrapped the front sub I had coated/reinforced for the car a while back.
    Learned my lesson with front 51mm Konis- 8641-1210 vs 8641-1021
    Ordered 1210s, went to install them with the GC plates and H&R Sports (50406) and was confused why the piston wouldn't release all the way. Then found out the 1210 extended height is much shorter than 1021s, requiring a terrifying amount of pressure to compress the springs to get it all assembled. Spring compressors kept sliding around under pressure on the fresh springs until I used fiber paste from the MTB tool kit. I have an upright spring compressor for things like this and it wouldn't compress the spring enough so I entrusted my life to maddox. Required every bit of thread they had.
    Koni notes the 1210s have "minimally stiffer dampening than the 1021s" and an internal rebound spring that limits unloaded extension height.
    No mention of internal bump stops, and both 1210s and 1021s are externally adjustable, so I think next time I'll stick with the latter for ease of installation.
    Used new dust shields, 9mm M3 upper spring pads, and lowers. GC touring camber plates, e36m3 bump stops. Had to buy Vorschlag bolt rings for the camber plates since I bought the plates used and the GC bolt rings were badly distorted.
    Broke down and bought the s14 valve bucket tool so once that's here I can lash the spare engine, change a few gaskets, install a water pump, and generally get it prepped for installation.
    Almost done pulling the rear subframe, which will get refreshed with new bushings/bearings/lines/etc. Looking forward to the car being a roller again.
    Untitled by bimmertown, on Flickr
    • AWDBOB
      hooptie connoisseur
      • Aug 2013
      • 4506
      #167
      A clean separation.
      I've neglected to consider other things that I should replace like fuel tank and ebrake assemblies... I guess now is the time
      • patrick88m3
        • Nov 2025
        • 54
        #168
        I've been told you can use a flywheel like this with a standalone. Last year I emailed for a price and it was around $500.
        • AWDBOB
          hooptie connoisseur
          • Aug 2013
          • 4506
          #169
          A few s14.net guys had the TTV flywheel delete its ring gear teeth- my plan was to do a front trigger wheel setup and run the RHD flywheel since it's chromoly and affordable if I end up going standalone. I need to test my spare parts on the stock ecu for a while anyway, so it'll be down the road if that happens, and shaped more like an s54 than an s14 standalone
          Ordered a tank. Replaced the diff plug housing (1378416). Heatin up
          • AWDBOB
            hooptie connoisseur
            • Aug 2013
            • 4506
            #170
            I lashed the spare S14 that I am going to install while my other engine is at the machine shop.
            The head on the spare engine looks fresh, and none of the shims were worn from their stamped values, but it was gapped pretty tight overall.
            I'm shooting for .30mm lash. On the intake side where I need to go up or down .5mm I'm going tighter (a couple will be .28mm), and the exhaust I'm going looser (a couple will be .33mm).
            Thoughts on the aforementioned lash plan of action are welcome. I also stuck a borescope in each cylinder turned 180* to look at the valves- they all looked okay.
            • JasonWilson48
              Not my real name
              • Jan 2025
              • 254
              #171
              did the parking brake cables fight you, or come out easy after the blaster? Dreading dropping my rear subframe this winter
              89' Build
              2009 Honda Element (Daily/Beater)
              • AWDBOB
                hooptie connoisseur
                • Aug 2013
                • 4506
                #172
                Surprisingly disassembly has been agreeable thus far- i've been getting lucky. Sprayed for a few days before vise grippin though
                I wouldn't stress about rear sub- get prepped for a lag bolt extraction and it'll come right out! I use a 5/8" shank lag bolt, 6" long. Thread in from the bottom w hammer, then impact, then give it a few snug turns after with a breaker bar. Hit down on it from above with a long 3/8" extension you don't like.
                It can be a PITA to set the subframe up in a press to get the old bushings out if you don't have the tool.
                If you're doing rubber trailing arm bushings, don't order Febi- they're like 1-2mm too big and 50% of the time fold over internally during installation.
                Meyle TA bushings are the correct size. Drill one side of the old ones out with a hole saw bit and a normal threaded sleeve puller gets them out/in without much of a fuss.
                Those are all the tips I have, grip n rip
                • AWDBOB
                  hooptie connoisseur
                  • Aug 2013
                  • 4506
                  #173
                  I scrubbed the wheel wells with purple power and a tire brush so I could start suspension reassembly. Painted some brake lines, measured/ordered new hardware for most of the car, assembled front suspension (twice), had rear axles rebuilt at Indy Rack&Axle.
                  Most of this stuff was purchased many years ago, so it's nice to see it all start to come together. Low mile stock M3 steering rack and steering joint, reinforced front subframe, etc made the reassembly pretty smooth. I installed a new clutch master while the steering linkage was out.
                  I had a spare rear sub powdercoated, which ended up being cracked under the paint. I didn't catch it despite inspecting it, nor did the powdercoater, so I have to have another one done
                  I have a bunch of stuff to clean up/paint for the rear suspension before it goes back together, but it's nice to have the front done.
                  • AWDBOB
                    hooptie connoisseur
                    • Aug 2013
                    • 4506
                    #174
                    It felt wrong not doing stainless lines now that I'm in this deep, so I bought the Bimmerworld kit and finished up the front brakes.
                    ATE pads, Zimmerman Rotors, and rebuilt calipers I got from an s14 member.
                    • AWDBOB
                      hooptie connoisseur
                      • Aug 2013
                      • 4506
                      #175
                      Coming along! Assembling all of this stuff on the ground is pretty funny. I have nice fill/drain plugs I forgot to install before you yell at me for painting over them
                      Powder guy really finessed the tape work. I had to redo this and every other taped area in a fuel resistant paint, should've just painted the tank myself.
                      Bought a new Genuine supply hose, used Gates Barricade 27348 for the tank line to pump, and Cohline 2134.0400 for small plastic Evap connections. I have new evap hoses as well for when it goes back together. I unfortunately found rust that needs to be repaired in the passenger rear wheel well so I'm going to have to take the car up to Jake's over winter to get it right.
                      I'm not far from getting it rolling at this point. Taking some extra time to repaint all of this small stuff, finding nice hardware, etc.
                      Need to finish up resealing the spare s14 and might toss it in and try to get it running before it heads north depending on their schedule.
                      Secretly hoping the s54afari car for sale on here drops low enough to justify buying so I can drivetrain swap it into the M3
                      ​Untitled by bimmertown, on Flickr
                      • 2mAn
                        Señior Mod
                        • 21031
                        #176
                        Secretly hoping you buy it and do that so I can secretly slide into your DMs about the suspension.... lol
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        Make R3V Great Again -2020
                        • AWDBOB
                          hooptie connoisseur
                          • Aug 2013
                          • 4506
                          #177
                          We shall see- pretty sorted e46m3 verts in my area regularly sell for ~10k so an e46 part out for a drivetrain is also an option. Won't be for a while unless a smokin' deal comes along.
                          With gumption refueled I started assembling the rear suspension this week. Rebuilt ebrakes, replaced all bushings/bearings, painted a bunch of stuff, etc. I bought a bunch of new hardware for the project but it didn't give me the warm fuzzies like clean genuine hardware so I spent a late night sorting through old Zionsville hardware boxes to find the best stuff.
                          Got the fuel tank in, and redid the external fuel pump assembly with a clean bracket I got from an S14 member.
                          It takes quite a bit more bandwidth to make things shiny, but I think I'll be glad I took the time to do it this way.
                          Waiting for some front wheel spacers and for some paint to dry before I finish up f/r swaybars, at which point the car will officially be a roller again!
                          • JasonWilson48
                            Not my real name
                            • Jan 2025
                            • 254
                            #178
                            Damn. The refinishing of the rear subframe/suspension/diff looks so good
                            89' Build
                            • AWDBOB
                              hooptie connoisseur
                              • Aug 2013
                              • 4506
                              #179
                              Thanks man- I think it's definitely worth it on something you're going to own for a long time. Breaking down the trailing arms, diff and fuel tank to repaint/powdercoat seemed to make the biggest difference over past rehabs.
