Lazurblau 325i project thread
  • TheWipprSnappr
    • Jul 2015
    • 477
    #61
    Not much to update on the 325i, but I was able to tackle a project on the daily that its been needing for awhile.
    The radiator has been leaking a bit for some time so I swapped it out with my spare that I had left over from swapping the z3m rad in. It actually looks uglier than the leaky one but function>form in this case.
    Hard to tell where the leak is because the whole thing is wet but it was leaking out of the seam on the side.
    I also pulled the overflow tank and gave it a much needing cleaning. This thing was full of sludge, it was disgusting. I read a trick online to use CLR, warm water, and ball bearings to shake around and pull the sludge off the inner walls. However, I didn't have any bb's so I just used hot water and some dish soap and it got most of it. Not perfect but 10x better than it was as you can tell by the pics.
    Yes that is electrical tape holding my coolant level sensor together. New one in route.
    Also started pulling apart my spare manual transfer case to get started on the rebuild to swap the iX to manual soon.
    1990 325iX - sterlingsilber metallic
    1991 325i - lazurblau metallic
    Originally posted by delamaize
    E30 = Lego for men.
    • ThatM20Guy
      • Aug 2014
      • 600
      #62
      How difficult was it to pull apart the case? I will be doing that this summer...
      89' 325ix Diamantschwarz/Black rattle can...
      Insta: r_moose_w
      Originally posted by flyboyx
      I imagine her smelling like spoiled milk and having a half inch crust of doodoo circumnavigating her butthole.
      • TheWipprSnappr
        • Jul 2015
        • 477
        #63
        Not terrible. Just make sure to get all the bolts removed and then you'll need to pull the rear output flange off and then pry it apart evenly. Takes a little time since there are guide sleeves and the gears will be pressed into the bearings. This will be the second one I've done. I didn't get into a lot of detail here either: https://www.r3vlimited.com/board/sho...d.php?t=397418, but this one was an automatic and I'll be using the chain, gears and vc from it. There is a good write up somewhere, ill have to find it.
        EDIT: found it https://www.r3vlimited.com/board/sho...d.php?t=277134
        E30 = Lego for men.
        • TheWipprSnappr
          • Jul 2015
          • 477
          #64
          My wife came through clutch this Christmas! Got me this Genuine E30 M3 one-piece shift boot.
          E30 = Lego for men.
          • TheWipprSnappr
            • Jul 2015
            • 477
            #65
            Long time no update. Its been a long winter here in Missouri and I have gotten kinda lazy and have been procrastinating a lot of things. The car has had a small vacuum leak for awhile now but recently its been getting worse.
            I narrowed it down to a cracked crankcase breather hose. So I ordered a new one and spent some time today installing it.
            The culprit:
            No wonder...
            Ordered a new genuine bmw one
            Cleaned out the ICV and TB while I had the parts removed.
            All back together
            I added some hose clamps to the ICV to TB hose. Probably not necessary but I feel like this thing has had vacuum leaks since the day I bought it due to one part or another so just didnt wanna take any chances.
            Also before I installed the new breather hose, I did something I've been meaning to do for a while and check/replace the injectors.
            Started by disconnecting the battery.
            Then I unplugged the harness.
            This plug is kinda tricky. Once you twist the plug off there is a plastic retainer on the bottom side of the bracket that needs to be twisted off as well.
            With that unplugged, next I unplugged the brown and blue sensors. After that its a matter of popping the harness off the injectors. You have to be a bit firm, and it might feel like youre going to break something but they will eventually pop out.
            Next, to remove the fuel rail I removed the 4 bolts mounting it to the intake mani and remove the fuel lines from the FPR. I actually ended up removing the FPR all together to maneuver it better. Made sure to drain the fuel from the rail. For this I just tilted the rail and poured it down and old radiator hose into my catch pan.
            Took quite a bit of maneuvering and was a bit of a pita but finally got it out.
            Old injectors were pretty bad.
            Replaced them with m52 green tops (17 lb).
            Everything back in including breather hose.
            Took a couple seconds for fuel to get pumped back but once it fired up, dropped down to 700 rpm. It was idling at about 1100 rpm with surges up to 1400 rpm with the leak. I took it around the block a few times to let the ecu dial back in and let it sat in the garage running for about 5 minutes and the idle didnt budge from ~750 rpm. Very satisfying to hear it purr like this!
            After fixing this I can already feel some motivation to get back to wrenching on it some more.
            E30 = Lego for men.
            • 2mAn
              Señior Mod
              • 20757
              #66
              Its so great fixing little things... Im so jealous of your color. I need to repaint mine back to Cirrusblau so I can appreciate the color
              Simon
              Current Cars:
              -1966 Lotus Elan
              -1986 German Car
              -2006 Volkswagen Jetta TDI
              Make R3V Great Again -2020
              • MB07
                • Jan 2018
                • 62
                #67
                Hats off to you for getting the fuel rail off without completely removing the intake manifold. I had a hell of a time getting the fuel rail and injectors to unseat from the intake and I had the head off and intake separated from the head. My injectors looked just like your, 30 years of grime. Probably why mine were so hard to remove.
                2009 BMW 328i xDrive (Daily/winter drift king)
                1987 BMW 325i (Currently torn apart)
                Instgram: @Ebola.30
                • TheWipprSnappr
                  • Jul 2015
                  • 477
                  #68
                  Now that your car has the appropriate amount of pedals, its only appropriate you celebrate by giving it a fresh PJ ;D
                  I had to change angles like 10 different times pulling it out of there, pulling intake was definitely a last resort.
                  E30 = Lego for men.
                  • TheWipprSnappr
                    • Jul 2015
                    • 477
                    #69
                    Got bored last night so I decided to deal with my sunburnt speaker deck. My rear speakers are old and one is blown so I needed to pull those as well.
                    Also when I bought the car it came with a non-ski pass seat back to replace the very worn ski-pass one.
                    I found an indigo speaker deck for a good deal last summer. When I finally pulled it all the way out of the box, something didn't look quite right...
                    I can't believe I didn't check if it was for early or late model! I felt so dumb. But I figured its here and its in good shape, it's going in!
                    It kind of looks goofy with the late model taillights (sorry for dark pics it was late), but to be honest I don't hate it. When I look at it, it actually kinda makes me chuckle. So I'm gonna leave it in.
                    Here is the new rear seat back installed. You can see the wear in the other one in an earlier pic.
                    Also freshened up the speaker covers for the new deck
                    Last, I reinstalled my momo wheel and e30 m3 shift boot. I seriously can't get enough of thing.
                    Dogleg wannabe
                    E30 = Lego for men.
                    • TheWipprSnappr
                      • Jul 2015
                      • 477
                      #70
                      Its been a very busy summer so far, but was able to accomplish a couple things this weekend.
                      Replaced rear rotors and pads
                      Replaced what was left of my fuel vent line cover lol. It looks super rough but the line hasn't corroded through. The wet spots are just wd-40.
                      Also I'm trying out another shift lever. I think I have an addiction.
                      Lever from an e90 330i
                      This lever is even longer than the x5 below the pivot point. So some modification will probably required for it to engage the selector rod joint squarely.
                      I bought a DSSR for my iX 5 speed swap, so I modified my iX single shear selector rod so hopfully it will transfer the force squarely onto the joint. It was made for the wide style rod joint so I had to cut it down and regroove it. Also prepped and painted it red because why not.
                      "Modified" aka beat the shit out of it with a hollow steel pipe.
                      Pretty damn effective
                      Hard to tell but I did mask off the pins so the bushings wont be rubbing on paint.
                      If I don't like the feel I might look at finding a way to mount to the chassis. Possibly similar to Jean's method here: https://www.r3vlimited.com/board/sho...0&postcount=31
                      I want to be able to use a bmw lever so I can keep the m3 boot and knob on.
                      E30 = Lego for men.
                      • TheWipprSnappr
                        • Jul 2015
                        • 477
                        #71
                        Got the 330i shifter installed and it is seriously the best shifter I've tried to date. Bending the lever i think definitely improved the way the selector engages. Its even smoother than the x5 was with an unbent selector rod. My only gripe is that 1st gear is a bit far forward for my preference. I think with an i selector rod it would be just right and mounting the lever to the chassis (akg style) would make it absolutely perfect. Still extremely impressed with it.
                        1st, N, 2nd
                        E30 = Lego for men.
                        • TheWipprSnappr
                          • Jul 2015
                          • 477
                          #72
                          Well, I was content to leave my shifter as previously shown for the foreseeable future but I came across a cheap ebay shifter (pic attached at bottom) that I bought a long time ago that I completely forgot about. I figured I would disassemble it to see if I could use anything with it and turns out the plastic cup is the exact same size as oem BMW shifters!
                          I did have to cut a bit a bit off of the bottom of the blue cup mount but this could be a perfect way for those with a super short shifter (e.g. this lever and Z4 and others) to raise there pivot point even to the rod joint to be able to use a straight dssr.
                          The cup fitment was a little loose so I drilled a couple holes with some set screws and that seemed to hold it in place really well.
                          Rod is now applies the force straight into the joint.
                          E30 = Lego for men.
                          • Pootis
                            • 636
                            #73
                            Good build man. I'm surprised I have never seen you around
                            1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
                            COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
                            • TheWipprSnappr
                              • Jul 2015
                              • 477
                              #74
                              Thanks dude. Not sure where youre located but, Overland Park is about as far west as I venture.
                              E30 = Lego for men.
                              • Pootis
                                • 636
                                #75
                                I live in Lenexa and my car doesn't get out much either
