*!Build of the year candidate!* Strange PNW Build: E30+Volvo
  • adam.nonis
    • Apr 2017
    • 755
    #196
    This part takes forever. Ugh. [emoji13]
    • oekundar
      • Sep 2007
      • 964
      #197
      Any reason you didn't use a more dense foam/filler on the steering wheel? The pipe foam you're using doesn't seem ideal.
      BMWCCA #389756
      • adam.nonis
        • Apr 2017
        • 755
        #198
        It’s not pipe foam. It’s adhesive backed closed cell 1/8” foam. Should be good. You want a little squish to get the suede tight
        • adam.nonis
          • Apr 2017
          • 755
          #199
          • iXguido
            • Nov 2009
            • 730
            #200
            Bump! I wanna see how that steering wheel turns out!
            • adam.nonis
              • Apr 2017
              • 755
              #201
              Still stitching. A little here and there in my free time. Already planning a V2.
              • adam.nonis
                • Apr 2017
                • 755
                #202
                • 2mAn
                  Señior Mod
                  • 21053
                  #203
                  Yes!... I like this destruction
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • adam.nonis
                    • Apr 2017
                    • 755
                    #204
                    Sometimes you gotta break it down before you build it up.
                    • adam.nonis
                      • Apr 2017
                      • 755
                      #205
                      Test fit in an E30 to check seat clearance
                      Drop in E46 cupholder
                      • 2mAn
                        Señior Mod
                        • 21053
                        #206
                        Love the ingenuity!
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        • adam.nonis
                          • Apr 2017
                          • 755
                          #207
                          With cupholder
                          Relocating the battery to the back. This will replace the battery in the stock location
                          • adam.nonis
                            • Apr 2017
                            • 755
                            #208
                            Out with the old...
                            Boring, I know. I’ve just got several things at 80% completion and I need to wrap stuff up. I want to focus on getting the engine bay wrapped up which means finishing sheet metal work, which means relocating the battery, oh and while I have the ECU out, I may as well do the Motronic 1.0 to 1.3 swap.
                            I think I’m going to paint the bay to match the cardinal interior. Might only be temporary, but for now at least. Like this....
                            (except not bright red)
                            Funnily enough, I was looking through an old photo album my parents had and turns out my dad had his “project car” parked in the same place mine is and they were kind of similar colors.
                            • adam.nonis
                              • Apr 2017
                              • 755
                              #209
                              No pics of this weekend’s work. More boring stuff.
                              -Converted from 1.0 to 1.3 (that was actually more complicated than I thought)
                              -Relocated battery to hatch (Haven’t bolted it down just yet. Need to verify location)
                              -Converted to late model headlight switch (only for availability purposes)
                              -Thinned out the front harness and put Amazon ends on stuff so I can get the front lighting working.
                              I now have a working 073 DME if anyone needs one.
                              • flyboyx
                                • 8371
                                #210
                                i think its the 173 that people want for purposes of installing a chip.
                                Gigitty Gigitty!!!!
