I would assume you would want it completely sandwiched between the cover and diff to get any actual heat transfer. As long as you could seal it up and get the speedo sensor to read 1/8" or so out from stock it would be boss.
*!Build of the year candidate!* Strange PNW Build: E30+Volvo
In theory (which is all I know) it’s mostly about contact patch surface area, so probably not a lot of heat transfer in this design. If I decide to spend any time on a V2 down the road I’ll try to increase the contact patch somehow. Fins attached to the main pumpkin would cool just as well as fins on the back cover. I’m pretty sure my car will never get the diff fluid to the point where it needs much cooling.Comment
Once the fluid/diff gets to temp, the whole mass will have a similar heat profile. The steel pumpkin won’t heat/cool as fast as the aluminum back cover, but cooling any part of the “network” cools all parts of the “network” since the heat is generated internally. It doesn’t need to be physically touching the fluid. Cool the diff, you cool the fluid.Comment
Congrats on your Jalopnik article!! Very well deserved, your fabrication skills are absolutely inspiring.Comment
Still a ways to go, but it’s a start.Last edited by adam.nonis; 06-09-2018, 08:18 PM.Comment
