*!Build of the year candidate!* Strange PNW Build: E30+Volvo
  • adam.nonis
    • Apr 2017
    • 755
    #1126
    Sent from my iPhone using Tapatalk Pro
    • adam.nonis
      • Apr 2017
      • 755
      #1127
      If it's not one thing, it's another. Hope this swap is worth it. I've replaced basically every part you can that's not disassembling the head or rotating assembly. Now it's the eccentric shaft and sensor. Also, designed a mount for using a three chamber Tilton reservoir for brakes and clutch. Strictly because the factory reservoir is NLA.
      The same cats we adopted when I started the body swap.
      And my favorite spray oil to use on the blackstone (available on Amazon)
      • Panici
        • Dec 2009
        • 2575
        #1128
        Love the airbox! hoping for some ram-air effect?
        • adam.nonis
          • Apr 2017
          • 755
          #1129
          The bumper and airdam cover it, but it is out of the engine bay.
          • adam.nonis
            • Apr 2017
            • 755
            #1130
            Mostly wrapped up. Need to swap cooling fans, get an alignment and take it for dyno tuning on the 4th.
            • adam.nonis
              • Apr 2017
              • 755
              #1131
              Just a couple N52 swapped E30s
              • adam.nonis
                • Apr 2017
                • 755
                #1132
                269 WHP @ 6500 and 235 WTQ @ 4500
                • OSAH racing
                  • Apr 2022
                  • 244
                  #1133
                  Amazing work and execution ! What is it like to drive ?
                  • adam.nonis
                    • Apr 2017
                    • 755
                    #1134
                    Well, so far I've only driven it home in rush hour traffic. But even that was nice. The trans is so buttery. I'll be putting some miles on it soon.
                    • Donkeyshins
                      • 34
                      #1135
                      I was worried for a minute that you were using it for assembly lube. :D
                      • lukeADE335i
                        • Apr 2013
                        • 1389
                        #1136
                        Just went back and read through the N52 swap section of your thread Adam - awesome fab work as always, and it must be great to have it back on the road now. The N52 / GS6 combination should be quite the transformation vs. the M20 / Getrag you had before.
                        My e30: OEM+ with M30B35
                        • adam.nonis
                          • Apr 2017
                          • 755
                          #1137
                          It's so much better. Sounds amazing too. Reminds me of an L24 w/individual carbs. I will FOR SURE need an LSD too. 😆
                          • lukeADE335i
                            • Apr 2013
                            • 1389
                            #1138
                            Sounds great - I love the GS6 transmission in my e92. A LSD would be essential I think. When I did my M30 swap the open diff made the car a bit of a handful - it was fun but felt like a swapped car. Once I fitted the LSD it drove like it came that way from the factory. You have a lot more power than I do!
                            • adam.nonis
                              • Apr 2017
                              • 755
                              #1139
                              Since the party never stops, I'm piggybacking onto Hoveringuy's EPAS and getting power steering finally. I bought some parts, made a jig for the factory (early) column and started chopping things up.
                              Made a little fixture to hold the spring pre-load at the right length.
                              F
                              First bracket version. Second one is waiting to be cut
                              • Northern
                                I like cupcakes & sh!tboxes
                                • 5284
                                #1140
                                I'm liking the EPAS stuff around here recently, following Hoveringuy's stuff here and FB as well.
                                If we can really nail the implementation, the simplicity of one of these would be awesome.
                                Originally posted by priapism
                                Originally posted by shameson
