Melon's E30 Build.
  • Melon
    • Mar 2018
    • 1311
    #256
    Originally posted by efficient
    little by little but its coming along. i wonder how quiet your car will be with all the mat you put in.
    I wonder this myself. When I bought the car it had several missing pieces of interior trim, and solid engine mounts. I'm hoping with everything in, harder than stock, but not solid mounts, and extra sound deadening I'll be able to hear music from the stereo I put in.
    Sent from my Pixel 2 using Tapatalk
    I do things.
    • Melon
      • Mar 2018
      • 1311
      #257
      I took the day off from the car to rest, but I had to try sometime after seeing a few DIY videos.
      It wasn't too bad at all, now I need my lockstrip tool to come in.
      I do things.
      • Melon
        • Mar 2018
        • 1311
        #258
        Windshield in, and restored the parcel shelf today, and got it installed with my bitching seat belts.
        I do things.
        • majdomo
          • Jun 2018
          • 449
          #259
          seat belts look fn rad
          Current flame: E30 318iS Alpinweiss II slicktop / LSD - Joanne
          The old man: 1970 2002 Polaris(ish) slicktop / rat rod - Wallace
          The ex: E92 335i 6MT M-Sport - Betty
          The heavy: 2001 4Runner SR5 Sport (3rd Gen) - Fred
          • Melon
            • Mar 2018
            • 1311
            #260
            Thanks! I was stoked to find out I could get them redone, in orange, for less than other places were charging.
            I do things.
            • Melon
              • Mar 2018
              • 1311
              #261
              Got the rear end out, taking all the parts to a shop to have the bearings and bushings pressed out of.
              One axle is fucking stuck, even with a jaw puller, and heat on it, it wouldn't budge.
              Also, got the UUC calipers on.
              I do things.
              • Melon
                • Mar 2018
                • 1311
                #262
                I do things.
                • Albie325
                  • Jul 2016
                  • 515
                  #263
                  This is exactly where I was not long ago, it's definitely a PITA, but once it's all done the car with look and (I hope) feel a hundred times better
                  '86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
                  Albie325 Build Thread | Albie325 COTM Jan 2021
                  • Melon
                    • Mar 2018
                    • 1311
                    #264
                    Thanks man. I've been using your thread as reference!
                    Fortunately the PO (with my help) installed the new gas tank and re-worked all the fuel lines. All I need to replace are a few small ones to the overflow tank in the wheel well. Not having to drop the tank will save me a lot of time.
                    I do things.
                    • Melon
                      • Mar 2018
                      • 1311
                      #265
                      Weather was great, so got a lot of cleaning and painting done.
                      Painted the pop out windows.
                      I had plans to replace all the diff seals and paint the housing, but it cleaned up really well, doesn't leak, and since it only takes minutes to remove, I'll send it as-is (admittedly I'm getting near the end and want to hurry things up a bit.)
                      Got the underside of the rear coated and ready to receive it's new rear end.
                      I do things.
                      • haaken675
                        • Sep 2016
                        • 601
                        #266
                        How was pulling the window trim pieces for painting? I am getting closer and closer to the point where I can start thinking about paint and bodywork and taking those trim pieces off worries me a little.
                        • Melon
                          • Mar 2018
                          • 1311
                          #267
                          Just go slow, and take your time. They're made of aluminium and can break easily.
                          Mine are slightly bent here and there, and it's easy to straighten them out with a little work, and besides, the clips will hold them in place once they're back on the car.
                          There's a great guide on E30Zone Wiki about how to remove them, I used that and it was pretty simple.
                          I do things.
                          • Melon
                            • Mar 2018
                            • 1311
                            #268
                            Got the new shocks installed, sway bar with IE reinforcements. But the most photogenic item was the vent windows, rear panels, and the rear seat, complete with bitching seat belts.
                            I do things.
                            • Nick_S
                              • Apr 2011
                              • 3658
                              #269
                              Those seat belts look sooooooo good. Killer build and a great read!
                              91 318is M50 swapped
                              05 Honda Pilot
                              24V swap thread
                              • Melon
                                • Mar 2018
                                • 1311
                                #270
                                Thanks!
                                I do things.
