Melon's E30 Build.
  • Melon
    • Mar 2018
    • 1311
    #391
    Originally posted by Secniv
    Love your work.
    Colour reminds me of my old 74’ 2002Tii. Friends use to call it “jelly bean” [emoji3]
    Sent from my iPad using Tapatalk
    The guy who worked on my axles has a '74 2002 in his shop.
    They're such beautiful cars.
    I do things.
    • Melon
      • Mar 2018
      • 1311
      #392
      Originally posted by Mazdayasna
      Incredible to see the before/after! How do you feel, having come so far?
      Sent from my PH-1 using Tapatalk
      Pretty fucking awesome.
      Honestly it hasn't been on big success, sure driving it again felt like it, but it's been hundreds of little successes along the way, with some failures mixed in there too.
      I do things.
      • Melon
        • Mar 2018
        • 1311
        #393
        Ordered new pads.
        This is the dust from the DTC-30 pads after 150 miles, and is ridiculous. Going to try a set of Wilwood BP-10 pads.
        Sent from my Pixel 2 using Tapatalk
        I do things.
        • Melon
          • Mar 2018
          • 1311
          #394
          Couple of videos.
          I do things.
          • Melon
            • Mar 2018
            • 1311
            #395
            200 miles on the car.
            Finished up a lot of the punch list over the weekend.
            Got the sunroof back in, but one of the pieces that connects to the wire snapped, and broke. I epoxied and reinforced it back together, but this severely limits my ability to use the sunroof. It works, but could break. Such frustration.
            I do things.
            • Melon
              • Mar 2018
              • 1311
              #396
              Had, and still have a clunk, I can feel it in the shifter.
              Checked the driveshaft, center support bearing all is well.
              Mounts, and everything is bolted up. No idea.
              Car is running great! It's a true joy to drive.
              Going to get the A/C charged soon, and after that only issue is to get the ABS working. Have a feeling the relay under the dash needs to be replaced
              I do things.
              • Melon
                • Mar 2018
                • 1311
                #397
                Put the exhaust tip on.
                I do things.
                • efficient
                  • Feb 2012
                  • 3312
                  #398
                  tip looks good. how come you didn't weld the holes shut from the diving boards?
                  • Melon
                    • Mar 2018
                    • 1311
                    #399
                    Idk how to weld.
                    I do things.
                    • Melon
                      • Mar 2018
                      • 1311
                      #400
                      A/C charged and cooling!
                      I do things.
                      • econti
                        • May 2014
                        • 1151
                        #401
                        Bet it feels amazing to get it out and about
                        • Melon
                          • Mar 2018
                          • 1311
                          #402
                          You know it!
                          I need to take some really nice photos now.
                          I do things.
                          • Melon
                            • Mar 2018
                            • 1311
                            #403
                            Almost to 500 miles, and a few things are going to need some attention.
                            Transmission is going to need a hose on the vent tube, having a little bit of seepage. Should have installed the updated vent piece, had I known.
                            Hopefully I can do this without having to pull the transmission from the car.
                            ABS isn't working, got a new relay coming in for the inside computer, replaced the ones on the ABS unit itself. I also have a spare unit.
                            Fuel pressure is leaking down, I'll pull the plugs and check for a fuel smell when I do the valve adjustment, but not really sure how to check other items in the fuel system. Don't want to just go throwing parts at the car.
                            Other than that, it's doing well.
                            Been driving it to work all week, it's cold but sunny.
                            I do things.
                            • ak-
                              • 12422
                              #404
                              Can you elaborate on what you mean by the fuel pressure is leaking down? Are you losing fuel pressure?
                              1991 325iS turbo
                              • Melon
                                • Mar 2018
                                • 1311
                                #405
                                The immediate symptom is a long crank time.
                                When it's running it's 100% fine, it's leaking down after I turn the car off.
                                I do things.
