OMG's Personal S54 Build :)
  • dude8383
    • Jan 2005
    • 10387
    #46
    Got the oil pan on and the top end is pretty much all buttoned up as well. Waiting on the harness to be completed and then I gotta start figuring out the small annoying details of the build haha.
    • moatilliatta
      • 6152
      #47
      Exciting!
      You should prime the pump before tossing the pan on? - After oil filter housing.
      Spotted, Fan party hat.
      @Zakspeed_US
        • 34844
        #48
        you can just pack it with a bit of assembly lube so it doesn't cavitate. crank it over a few times with the FP relay disconnected to get some oil built up and you should be good.
        • moatilliatta
          • 6152
          #49
          Should. ;)
          @Zakspeed_US
          • dude8383
            • Jan 2005
            • 10387
            #50
            Originally posted by moatilliatta
            Exciting!
            Hehe. I actually did what nando suggested. i dropped assembly lube in it and will definitely prime the sucker before allowing the car to fire up.
            • dude8383
              • Jan 2005
              • 10387
              #51
              Starting to look like a motor. The oil filter housing is not mounted fully yet because I need to modify the E46 M3 heater pipe to integrate a coolant pipe to the reservoir. The Z4M piece is like $230 O_O for a metal pipe. That's not happening... S54 bits are expensive enough as it is... would rather spend that on something I actually need.
              • KIRIEIW
                • Dec 2012
                • 3385
                #52
                This things going to be insane good work so far man.
                1992 e34 Touring- S50 Swap
                1992 325i-S50 Swap (SOLD)
                1991
                • Motheye99
                  • May 2018
                  • 853
                  #53
                  You should check out the csl replica intakes or S54 velocity stacks both require a Alpha N ish tune of some sort and add 20-30 hp. I believe Kassel will preload the tune for the upgraded intake on to there swap dme. If that's the route your taking.
                  Sent from my SM-G950U using Tapatalk
                  91' 318is 90' 325is
                  Originally posted by Sonny
                  Buy the E30s, they ain't gonna last long
                  E30 can make you, E30 can break you
                  "He who controls the Nova's, controls the Boomers"
                  • dude8383
                    • Jan 2005
                    • 10387
                    #54
                    I can hardly wait :devil:
                    I have actually explored that... It's a little over $1800 for the one that is designed to fit the E30. That's not in the cards currently lol. I can do a lot with that kinda money. Maybe later on though because I do definitely want that plenum!
                    • dude8383
                      • Jan 2005
                      • 10387
                      #55
                      Modified the E46 coolant pipe to integrate the E30 coolant reservoir.
                      Now its a proper M motor LOL:
                      Transfer pipe:
                      I couldn't justify the $240 Z4 M coolant pipe from BMW... with this route I can keep my E30 reservoir and not worry about any interference with the A/C lines once I reach that stage in the build.
                      • wworm
                        • Dec 2016
                        • 1719
                        #56
                        Are pics working for anyone? I cant see these.
                        Cant wait to see that engine in the bay...
                        1984 Delphin 318i 2 door
                        • jeenyus
                          • Aug 2011
                          • 2064
                          #57
                          Not working for me either.
                          Sent from my Pixel 2 using Tapatalk
                          • dude8383
                            • Jan 2005
                            • 10387
                            #58
                            gimme a sec... gotta do it through flickr
                            • jeenyus
                              • Aug 2011
                              • 2064
                              #59
                              Pictures work now and the pipe looks so nicely done! Great work.
                              • wworm
                                • Dec 2016
                                • 1719
                                #60
                                yep all works now. Good stuff man!
