Project finished - 'MY22' 318is - bare metal, nut and bolt restoration
  • getouth
    • Jan 2010
    • 3343
    #61
    I'm impressed .......
    FEEDBACK:
    http://www.r3vlimited.com/board/showthread.php?t=316212
    BMWCCA #398608
    IG @yagayo38
    "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
    • JGood
      • Jan 2004
      • 7959
      #62
      Incredible build! Please keep the pics coming, we love this stuff.
      e30 restoration and V8 swap
      24 Hours of Lemons e30 build
      • burkey001
        • Feb 2011
        • 608
        #63
        Let’s do some trim
        Half the trim has gone NLA, so whilst some is new, some of the left hand side I had to cast the search net far and wide… here is a NOS part from 1988
        Hard to fathom why some stuff is still made – when it’s the same thing – i.e. door trim… right side no worries. Date stamp 2017…. Right side.,.. sorry
        Love new clips
        Took a while to track down the part number for the headlight speed clips. Realoem is not obvious
        Back onto the doors for tick… new weather stripping for the top of the door
        Complete with lil clips
        Back to the front guards… indicators in and the insides given a good shot of 3M cavity wax. I know this stuff is messy, but the factory does a similar thing so I need to do something similar.
        Test fitting a few things.. some of this stuff gets a little trim here and there so it doesn’t sit hard against surfaces.
        Test fitting some mud flaps… needed a little trimming where they meet the bumper
        Back to the doors… time to fit some more new seals and some clips so the shadowline can go back on
        This factory b pillar has some blu-tak like shmutz holding it on (across 3 cars I checked), interesting. Also had some felt and some foamy stuff… so lets try & recreate it..
        Door locks (not brand new, replaced 1 year ago in old car)
        New keys… molte bene!
        Latch in… missing the little rubber bung in this pic.. later added
        Starting to look like something
        New clips going on
        Old V new
        Fitted
        New shadowline …
        and that will do for now :)
        88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
        90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
        • Rob
          • 8166
          #64
          Holy cow, what an incredible build!
          BEERTECH
          • Melon
            • Mar 2018
            • 1311
            #65
            Aw dang, I have some of the headlight clips that are Zinc, they look amazing.
            I've been digging into tidbits over the past few months, if you have a question, feel free to ask. If I can save someone from buying something unnecessary I'd be glad to do it.
            Thanks for posting the pics of the door trim, that's going to be super helpful when I put mine back together.
            I do things.
            • Jokester
              • Sep 2016
              • 1818
              #66
              I have a brand new, OEM driver side headlight cover if you are in need of one.
              • burkey001
                • Feb 2011
                • 608
                #67
                Nothing terribly earth shattering happening
                Test fitting some new ZKW fogs into the valance.
                To get them to sit flush I will need to make some 3-4mm spacers installed on the top 2 bolts of the foglight mount. Just doesn’t quite sit as well as I want
                Need to get a feel for the face, so stuck in some trim to see.
                Debating black or silver headlights. I think silver (no crosses in high beam) but black trim rings is how we’ll roll.
                There was some other stuff to tie off on the doors… The little clips that hold the shadowline trim on. The originals looked OK but proved to be very brittle in use. So new clips and harmony is restored
                Got some door pulls and they don’t come with the little plastic bungs for the tie rod… kind of slack of BMW… lucky have spares
                Where’s the bung?!?
                These little things
                And done & dusted
                Speaking of bungs… the little hole in the door needs one
                This one
                I was waiting on some galvanised hardware before I could finish up the other door… got that underway and tucked in.
                And now we have two closing doors
                Trims on, keys workin, lookin good
                • burkey001
                  • Feb 2011
                  • 608
                  #68
                  Also began the process of hanging the bumper bars.
                  I thought it might be easiest to mount the reinforcement first, and then push the cover on top so it’s less weight to manhandle about as you line up the mounts… I think it worked OK.
                  Love new bits
                  I did replace those non-shiny bolts with something shiner
                  This is how I have it sitting right now.
                  I have some regular M3 and Evo bumper seals in the air right now, so will wait and see how we can make those fit before I worry too much more about the gap. Pretty even right now though, so probably OK
                  Bungs and gaskets on the inside
                  Get them all aligned
                  And a little tappy tap tap and we’re good
                  Yes, that’s a boot seal working as an engine bay seal. I want to see how that pans out
                  Onto the rear bar, same same pretty much
                  Sitting not too bad
                  There is one tiny high spot on the LHR under the tail light. The plastic cover is sitting a little high. I don’t have it clipped down yet, and I could always dob a little Sikaflex there to stick it to the reinforcement to take care of it
                  Here’s something else. To get this piece of trim to sit perfect against the body, I had to undo the glue and push this little clip along a few mm… I hope these small things will all add up
                  Onto the boot lid and I made some paper templates to apply some sound deadening, hopefully neatly and in an OEM looking way.
                  Base layer
                  Top layer trial
                  Starting to look like a car??
                  • econti
                    • May 2014
                    • 1151
                    #69
                    Boot insulation fitment is joocy
                    • Melon
                      • Mar 2018
                      • 1311
                      #70
                      Beautiful build man!
                      I do things.
                      • Jokester
                        • Sep 2016
                        • 1818
                        #71
                        How much of each type of sound Deadener did you use in total? Seems super clean and OEM+.
                        • burkey001
                          • Feb 2011
                          • 608
                          #72
                          Well I haven’t finished yet, but I ordered seven boxes of the buytl/alloy stuff. Each box 1.8 sq metre. 15 sq m of the 6mm and 12 of the .12mm.
                          I don’t believe I will use it all
                          • jeenyus
                            • Aug 2011
                            • 2064
                            #73
                            5 series bumper grommet to place in between the front bumper and front balance.
                            • Simon S
                              • Oct 2004
                              • 3758
                              #74
                              Builds like this are straight pornographic to me..
                              Nice work !
                              -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                              • Jokester
                                • Sep 2016
                                • 1818
                                #75
                                What are you doing for the body harness? I have to find a new one because my vehicle's previous owner is an asshat.
