My e30 Project... Mtech II sedan, Jlines, Vaders, M50 and much more...
  • rafiki
    • 245
    #346
    damn
    • motorsports_3
      • Mar 2007
      • 1058
      #347
      I got a little bit of work done the past days.
      Since I had modified the stock tranny brace to accept the tilt with the new motor. I had to re weld it back to its stock location.
      I also decided to change the Rear main seal, Pilot bearing, and throw out bearing. The clutch has been changed before and is in good condition.
      Tranny off
      Old RMS out, new one in
      I took out the wire harness finally, does anyone know what this harness connects to? It was connected and I could follow it, but I am limited in space right now.
      The pilot bearing was too small
      The throw out bearing was also wrong, so thats it for today.
      • e30m20beast
        • Aug 2009
        • 176
        #348
        nice work man!!!! I have read every single page and it's getting better and better.
        BTW In what part of Miami are you?
        • Slick92GS-R
          • Apr 2005
          • 662
          #349
          Go man Go... i hope that this recent rain is not holding up progress.. let me know when you going to install and i'll come by..
          --Hayden--
          '87 325 coupe- Trak Rat
          '93 318is- 4cyl's of fury
          '92 Integra GS-R--yeah, its fast..
          www.G2IC.com
          • motorsports_3
            • Mar 2007
            • 1058
            #350
            Thank you. I am in Kendall near the Hammocks, you?
            Lol, this rain is killing me, plus this weekend I am booked so I dont think it will be in till next week. I have to install the throwout bearing and pilot bearing, then its ready to drop in
            • motorsports_3
              • Mar 2007
              • 1058
              #351
              I got the harness, or should I say prelim harness done the past two days (Thanks to my friend Frank). I hope it works (knocks on wood)
              • e30m20beast
                • Aug 2009
                • 176
                #352
                [quote=motorsports_3;1886309]Thank you. I am in Kendall near the Hammocks, you?
                I am right south of the Miami int. airport. I still can't belive that the car you started with is the same car you have now!!! it looks awesome:up:
                • motorsports_3
                  • Mar 2007
                  • 1058
                  #353
                  I decided to change my oil filter housing gasket since they tend to leak.
                  New gasket
                  Alternator off
                  Old gasket
                  Old and new. Good thing I changed it, because the old one was really hard
                  New gasket on
                  Housing back on
                  P/s pump on
                  Alt on
                  Done
                  I figured out how to mount the spring clip in the tranny
                  Fork and new throw out bearing on
                  Old pilot bearing and new one
                  New one installed
                  All done for the day
                  • motorsports_3
                    • Mar 2007
                    • 1058
                    #354
                    Sorry for the lack of updates. This damn swap is taking me forever for no reason.
                    So I got the flywheel on
                    Locktite on those bolts
                    Bolted down
                    Clutch alignment tool being used
                    Done
                    I also cleaned out the bell housing and lubed it up
                    Tranny bolted back up. That is pretty hard to do alone
                    Now on to placing the motor
                    Demodified tranny mount
                    Mounted up
                    In place
                    Changed this
                    Connecting the shifting components is so much easier with no driveshaft in the way
                    Fuel lines connected
                    Motor had to be lifted to get the booster in
                    Mounted
                    Now I am stuck here. I am waiting to get the bar shortened and welded. Next update should be soon.
                    • motorsports_3
                      • Mar 2007
                      • 1058
                      #355
                      I went to install my fan and found my resistor to be broken. Great another thing to replace. I considered soldering it, but decided to just replace it
                      New one
                      Installed
                      I got the booster shortened
                      Finally installed
                      Lines attatched
                      I installed the slave cyl
                      Fabbed a dipstick bracket
                      Installed the condensor
                      New valve cover seals
                      Installed
                      Temp oil in
                      Throttle cable installed
                      Exp tank installed
                      Rad installed
                      Test start #1
                      I found out the starter power was not connected
                      Test start #2
                      Still no start WTF!!
                      Turns out I was missing a ground for the relays.
                      Vac line installed
                      P/S res on
                      Ran the lines
                      P/S works great. Thats it, till next time
                      • dude8383
                        • Jan 2005
                        • 10387
                        #356
                        Nice progress!
                        • SamE30e
                          • Sep 2007
                          • 4319
                          #357
                          Everyone I've know has forgot to ground the relays. I did it too lol.
                          1985 325e 2.8 Turbo VEMS
                          • moving3e
                            • Dec 2008
                            • 268
                            #358
                            Upddatte please!
                            • motorsports_3
                              • Mar 2007
                              • 1058
                              #359
                              So I had to remove the radiator to mount the aux fan
                              When I replaced the coolant, I used half of the container of Water Wetter, with a 50/50 mix or water and antifreeze.
                              I got my A/C lines mocked up
                              I mounted the driveshaft.
                              That was the only pic, because the guy gave me the wrong CSB when he sold me mine, and I installed it. So I had to run a mission to get the correct one, and I didnt have a chance to take pics of the progress.
                              A/C lines got done
                              I ended up getting a custom one from the comp to the condenser because my adapter was too large.
                              I noticed the SS kit was very close to the Drive shaft so I lowered the tranny a bit
                              I made a little bracket to hold the bottom of the e36 radiator
                              At this point I was at Friday last week. All that was left to do was bleed the brakes and clutch to drive the car. While bleeding the clutch I noticed fluid coming out of the front of the trans. I figured out that the slave cylinder rod was stuck in the trans. I got really discouraged and stop working on the car until Weds, when I duck taped a name tag magnet to a cloths hanger and got it out after a few hours.
                              I also decided to go with a remote brake fluid reservoir. Look at the clearance, or lack thereof
                              I introduce you to 2002ti res
                              Where it will mount
                              Draining fluid
                              Res off
                              Grommets off
                              New ones on
                              Mock fitting the res
                              I am still waiting on BMW to get me the 90 degree adaptors so I found some temp ones
                              Lines ran
                              Clutch line adapted
                              This needed to be extended
                              Done
                              Look at the clearance now
                              Making the bracket for the res
                              All mounted and happy
                              As soon as I get those fitting from BMW I will add fluid, install the new slave cyl, and bleed the system.
                              • raafhimself
                                • Dec 2008
                                • 451
                                #360
                                that looks effing awesome! i gotta check that ish out.
