What did you do to your E30 today?
This is a sticky topic.
  • ttrousdell
    • Nov 2009
    • 1770
    #5206
    ^Sweet wing. From E28?
    Getting the last few things done before starting up my recently swapped S14B23
    The Build:
    • thebutcher37
      • 2877
      #5207
      Replaced my Trunk seal, and by the looks of it right before the rain.
      Transaction Feedback
      • Verdi
        • Jan 2015
        • 30
        #5208
        Currently cleaning my window switches.
        • thebutcher37
          • 2877
          #5209
          Installed most if not all of my new parts.
          Custom wire cup holder
          new air intake boot
          m42 mess under intake/heater plate delete
          replaced broken stud on upper and lower intake manifold/new gasket
          fuel filter/oil filter and oil change
          New fuse box cover
          drivers side inner/outer window weather seal.
          Fresh parking break shoes and spring kit.
          New rear Wheel bearing kit.
          • rzerob
            • Jun 2013
            • 2315
            #5210
            Fixed passenger turn signal, driver fog light and washer jets.
            • rzerob
              • Jun 2013
              • 2315
              #5211
              I got it inspected.
              • PiercedE30
                • Apr 2005
                • 4220
                #5212
                Ordered a cam and a set of pistons from Paul Burke, order half of my fuel system from Summit.
                My 2.9L Build!
                • petrolhead
                  • 421
                  #5213
                  Ordered yet more parts for the diff rebuild.
                  • Gunner_1886
                    • Feb 2015
                    • 58
                    #5214
                    New passenger low beam. Got busted on 220, somewhere. New timing chain tensioner and radiator this week, hopefully.
                    1998 M3 - Sold
                    1991 318i - Sold
                    1998 323is - Daily
                    1986 325es - Project
                    • IceWhite
                      • Jan 2015
                      • 945
                      #5215
                      Bought a few items (All from the Dealer):
                      Top Radiator hose
                      Airflow Boot hose
                      Rubber antenna grommet
                      Clutch Master Bottle Cap
                      Rear Original Mudflaps
                      Driver side knee bolster plastic screws.
                      1990 325i
                      2004 330i Individual 6-speed
                      • LateFan
                        • May 2013
                        • 4415
                        #5216
                        Replaced motor mounts.
                        Replaced those stripped adjuster bars on the PS pump and Alternator. Looks like mechanics who don't know any better just crank the adjuster nut without loosening anything - it just strips the one tooth you need to tighten the belt.
                        • slammin.e28
                          שמע ישראל
                          • 12054
                          #5217
                          I just bought a new one for the E34 M30 because I can't get my PS pump to move far enough. My hoard from parting engines has run dry.
                          • shootnjunky
                            • Aug 2014
                            • 506
                            #5218
                            Took mine for a spring spin, after all the winter work to it.
                            • AwakenNoMore
                              • Dec 2010
                              • 1291
                              #5219
                              Changed out my engine mounts, forgot to change them last week when I did my manual swap.
                              1991 325i - "Scambles" The Daily Driven lightly modded.
                              1988 Mazda RX-7 TII "Mako" The Free Dorito
                              bacon by Jared Laabs, on Flickr
                              • Gunner_1886
                                • Feb 2015
                                • 58
                                #5220
                                New K&N air filter, new spark plugs. Radiator job is turning into a whole cooling system "project".
                                1998 M3 - Sold
                                1991 318i - Sold
                                1998 323is - Daily
