What did you do to your E30 today?
This is a sticky topic.
  • quasi mofo
    • Dec 2016
    • 107
    #5806
Name:
    Finally installed my trunk lid trim and tool box.
    • jgilber0
      • Nov 2016
      • 457
      #5807
      Cleaned the greasy mess off of the bottom of my engine and replaced my ABS pump with this beauty from our own Jordan Sarette.
      Specializing in the restoration, rebuild and remanufacturing of the ABS2 topology anti-lock brake hydraulic units.
      Click image for larger version  Name:	CF97B99A-D5FD-449D-B0D4-7A99A984A015.jpeg Views:	0 Size:	67.2 KB ID:	10019785 Click image for larger version  Name:	29F312A9-DFE2-45FC-816B-89F33B37148A.jpeg Views:	0 Size:	58.5 KB ID:	10019786
      Jon (OO=[][]=OO)
      1992 325ic white, stock with a 5-speed swap
      Palm Beach County
      • jgilber0
        • Nov 2016
        • 457
        #5808
        Replaced my oil pressure sender, cleaned all the oil out of the connector, changed the oil and put everything back together. My drip pan is bone dry once again.
        After that, I changed my brake fluid, bled the system, and took the car out for a test drive. Thanks to Jordan I now have working ABS again!
        Jon (OO=[][]=OO)
        Palm Beach County
        • It's Soda Not Pop
          • Jan 2022
          • 877
          #5809
          I installed a Heckblende the other day. I've been wanting to put one on for a long time. I finally got around to doing it.
          88' Seta 2.7i Zinno
          https://www.r3vlimited.com/board/for...430-my-88-seta
          • moatilliatta
            • 6158
            #5810
            Thought about what to do to it next.
            Send back damaged ATI Crank Damper in hope they can fix it...
            Plan on to try and get 7* of caster this weekend from E36 uprights / knuckles. .
            Stared at it.
            @Zakspeed_US
            • roguetoaster
              Biggus Tippus
              • 7830
              #5811
              I also stared at mine, then I decided it needed a wash and vac.
              • moatilliatta
                • 6158
                #5812
                @Zakspeed_US
                • 808ETA
                  • Nov 2018
                  • 436
                  #5813
                  I snapped four bolts on my rear seal carrier. I thought the click from the 1st 3 bolts was my torque wrench until the 4th bolt came off after it snapped.
                  sigpic84 325e
                  • roguetoaster
                    Biggus Tippus
                    • 7830
                    #5814
                    Nice.
                    • Ghosty
                      • Jun 2011
                      • 52
                      #5815
                      New tires, refreshed hoses under intake, two fuel hoses under manifold, replaced coolant pipe, switched to BMW blue coolant. cleaned ICV, M44 timing chain tensioner, oil change, new air filter remove tint from front windows, new blower motor.
                      • roguetoaster
                        Biggus Tippus
                        • 7830
                        #5816
                        Sounds like a normal M42 maintenance day.
                        • Ghosty
                          • Jun 2011
                          • 52
                          #5817
                          Definitely, just long over due for mine!
                          Car sat for years in the garage.
                          • iansane
                            • 1343
                            #5818
                            Originally posted by ddm-j
                            Attempted removal of passenger side front valence bolt via my friend the welder. Thing is rusted in, stripped out, and features broken off extractor tip compliments of previous owner's attempt at removal. We broke off a grade 8 bold (sheer failure brittle fracture surface) that was welded in! Now I have the task of trying to remove the bolt that was welded on and broken off. Hopefully I can get it out and test another extractor. If that doesn't work I may try welding again with a stainless steel bolt. If that don't work it'll be full drill out and re-tap.
                            In the meantime my r134 conversion will be on hold unless I decide to drain the cooling system and go at the condenser from the radiator side.
                            Damn dude. Hardcore.
                            I installed solid adjustable control arm bushings.
                            I'm not impressed with how far out the back of the heim joint the control arm sits and Garagistic says my car is messed up and all theirs are fine with more extension, but cannot provide a picture to show that. Weird. We'll see how long they last in the PNW with no boots.
ID:	10049443 Click image for larger version
                            84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
                            • It's Soda Not Pop
                              • Jan 2022
                              • 877
                              #5819
                              Did a valve adjustment and I believe I have finally stopped the valve cover from leaking. Also flogged the hell out of it in the twisties.
                              88' Seta 2.7i Zinno
                              • travis_e30
                                • Jun 2022
                                • 15
                                #5820
                                Cleaned up some old school stainless headers and installed them
