Finally installed my trunk lid trim and tool box.
What did you do to your E30 today?
This is a sticky topic.
Cleaned the greasy mess off of the bottom of my engine and replaced my ABS pump with this beauty from our own Jordan Sarette.
Specializing in the restoration, rebuild and remanufacturing of the ABS2 topology anti-lock brake hydraulic units.
1992 325ic white, stock with a 5-speed swap
Palm Beach County
- Likes 1
Replaced my oil pressure sender, cleaned all the oil out of the connector, changed the oil and put everything back together. My drip pan is bone dry once again.
After that, I changed my brake fluid, bled the system, and took the car out for a test drive. Thanks to Jordan I now have working ABS again!Jon (OO=[][]=OO)
Palm Beach County
Originally posted by Ghosty View PostNew tires, refreshed hoses under intake, two fuel hoses under manifold, replaced coolant pipe, switched to BMW blue coolant. cleaned ICV, M44 timing chain tensioner, oil change, new air filter remove tint from front windows, new blower motor.
- Likes 1
Originally posted by ddm-j View PostAttempted removal of passenger side front valence bolt via my friend the welder. Thing is rusted in, stripped out, and features broken off extractor tip compliments of previous owner's attempt at removal. We broke off a grade 8 bold (sheer failure brittle fracture surface) that was welded in! Now I have the task of trying to remove the bolt that was welded on and broken off. Hopefully I can get it out and test another extractor. If that doesn't work I may try welding again with a stainless steel bolt. If that don't work it'll be full drill out and re-tap.
In the meantime my r134 conversion will be on hold unless I decide to drain the cooling system and go at the condenser from the radiator side.
I installed solid adjustable control arm bushings.
I'm not impressed with how far out the back of the heim joint the control arm sits and Garagistic says my car is messed up and all theirs are fine with more extension, but cannot provide a picture to show that. Weird. We'll see how long they last in the PNW with no boots.
84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350
Manual swap all the things!
